head gasket
Anyone have a head gasket failure? Experiencing engine misfire on #2 cylinder on start up. Started using small amount of coolant and now get flashing check engine light at start up with a engine miss. Vagcom showed #2 misfire.
Removed plug and coil pack from #2 and switched with #1 cylinder no change. Now water pump is dripping coolant. (only 30K on it.) I think there is too much presure in system and damaged water pump seal! |
