I have $50,000 to spend on an engine and transmission, going into a b5 a4 what do i do?
I want this f*^&ing car to be so fast the front tires lift off the ground like that awd drag porsche i saw a while back. I want to keep it in a b5 a4 body and it has to be quattro dont care if I use some kind of 911 mid engine awd setup, but above all The thing HAS to run 800+hp and run in the 9's any suggestions?
This is what i would do.
I would first do All Carbon Fiber Body Parts from AWE. Lighter Exhaust, suspension components. Lightweight wheels and brembo brakes front and rear. Gut the Interior and just leave dash console and two seats. Then call MTM and get a 650HP 2.7T RS4 Engine with a 6 Speed.
Re: I have $50,000 to spend on an engine and transmission, going into a b5 a4 what do i do?
why not a RS6 engine RS4 manual with a set of turbos, cams and intercoolers you will have 750hp/1000nm
