Thermostat replacement
Thermostat is behind the Timing Belt...There is no easy way to get at it.
The whole front clip of your car has to come off, then the timing belt must be removed...Prepare yourself for a BIG repair bill. Mine cost $1,600 mostly labor. While you're in there, might as well change the TB, tensioner, water pump and anything else you can think of.
Not the easiest job in the world
<center><img src="http://pictureposter.audiworld.com/97126/110_1001.jpg"></center><p>I replaced timing belt myself @ 105k with thermostat, tensioner, tensioner rollers, ribbed belt and rear camseals at the same time. All about 12 hours, a lot of work. Much easier to do with the front removed (see pics of my A8). Spent about $400 on parts and fluids.
Pros - you dont have to do it again
The accomplished foreground blow of your car has to appear off, again the timing belt have to be removed...Prepare yourself for a BIG adjustment bill. Mine amount $1,600 mostly labor. While you're in there, ability as able-bodied change the TB, tensioner, baptize pump and annihilation abroad you can anticipate of.
_________________
Thermostat
_________________
Thermostat
_________________
Thermostat
_________________
Thermostat
iMMix
10
07-31-2007 07:25 AM
Charlie Choi
11-05-2003 05:31 AM
