ACC stoped working after retrofit and operating
Greetings
after my successful retrofit of my ACC on my All road A4 ,i had an engine fault (under pressure turbo) that disable my ACC,(i guess ) i have since then erased the problem and still my ACC is shown as" not available" the 00234 erro i had before and it is within limits therefore was operational before .. I disconnect fuse ,reset system and reconnected the ACC but it is still not operational. I can see it in the mmi screen and adjust the parameters. Any suggestions? thx ARI Wednesday,01,October,2014,15:14:31:19623 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.2.0 Data version: 20140212 VIN: WAUZZZ8K0AA001410 License Plate: Mileage: 68700km-42688mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8K (8T0) Scan: 01 02 03 05 08 09 10 13 15 16 17 19 1B 20 36 3C 42 46 47 52 53 55 56 57 5F 62 69 6C 6D 72 VIN: WAUZZZ8K0AA001410 Mileage: 68700km/42688miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1B-Active Steering -- Status: OK 0000 20-High Beam Assist. -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (CL0MA-CDNC) Labels: 06H-907-115-CAB.clb Part No SW: 8K2 907 115 P HW: 8K2 907 115 D Component: 2.0l R4/4V TF H14 0008 Revision: E1H14--- Coding: 010C000C240F0A60 Shop #: WSC 00004 207 97528 ASAM Dataset: EV_ECM20TFS8K2907115P A01010 ROD: EV_ECM20TFS0118K2907115AJ.rod VCID: 3C7C37D8B72700FE87F-8069 No fault code found. Readiness: 1110 0101 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb Part No SW: 8K1 927 156 AE HW: 0B5 927 156 E Component: 0B5 20TFSIRdW H04 0004 Revision: --H04--- Serial number: 0000000043 Coding: 000001 Shop #: WSC 04742 780 00200 ASAM Dataset: EV_TCMDL501 A02087 ROD: EV_TCMDL501.rod VCID: 78F4EBC8C39FECDEA37-802D No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: None VCID: 55AA827CBC4DF1B6981-FFFF No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 BQ HW: 8K0 907 064 BQ Component: BCM2 1.1 H90 0247 Revision: 00002001 Coding: 050200 Shop #: WSC 06335 000 00000 VCID: 80040328134F241E1B7-80D5 Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H36 0041 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AL HW: 8T1 820 043 AL Component: KLIMA 3 ZONEN H08 0171 Revision: C202H000 Serial number: 16009008003671 Coding: 66100002 Shop #: WSC 00004 207 97528 VCID: 7BFEF4C4FAA9C7C6CE5-802E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 C HW: 8K0 907 063 C Component: BCM1 1.0 H24 0253 Revision: 04024001 Serial number: 00000000221528 Coding: 260058910174BF311701000000001D0D4F9CE7480001014500 0000 Shop #: WSC 00004 207 97528 VCID: 2F6610947E51EB6632D-807A Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 160309 H06 0070 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB Component: RLS H04 0003 Coding: 024B2D Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA Component: E1 - LDS H07 0090 Subsystem 4 - Part No SW: 8K0 959 772 HW: 8K0 959 772 Component: SLR-B8 H05 0002 Coding: 4F0000 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb Part No SW: 8K0 919 475 G HW: 8K0 919 475 A Component: PARKHILFE 8K H06 0040 Revision: 11001001 Serial number: 40040906410102 Coding: 310104 Shop #: WSC 00004 207 97528 VCID: 3D7A3ADCA43D09F6B01-8068 No fault code found. ------------------------------------------------------------------------------- [B]Address 13: Auto Dist. Reg (J428) Labels: None Part No SW: 8K0 907 561 HW: 8K0 907 561 Component: ACC2 H08 0080 Serial number: 00000000000000 Coding: 00C7D9 Shop #: WSC 06777 128 28888 VCID: EFE650943ED12B66F2D-80BA 1 Fault Found: 00234 - Sensor for Automatic Distance Regulation Misadjusted 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 125 Mileage: 68701 km Time Indication: 0 Date: 2014.10.01 Time: 15:09:14 Freeze Frame: Temperature: 59.0°C Voltage: 13.82 V Bin. Bits: 00011 Hex Value: 0x0941 Hex Value: 0x0001 Speed: -3.6 km/h Lateral Accel.: 0.00 m/s^2 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H27 0410 Serial number: 0038JD1ENG1C Coding: 30343435363030303030554A304C384B3053 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 3C7C37D8B72700FE87F-8069 Crash sensor for side airbag; driver side: Serial number: 6334MSME452371634 Crash sensor for side airbag; passenger side: Serial number: 6344MSME4462433BB Crash sensor for side airbag; rear driver side: Serial number: 6352QSME641D3008C Crash sensor for side airbag; rear passenger side: Serial number: 6362QSME6D1B3C14T Crash sensor for front airbag; driver side: Serial number: 63732SME261B1200M Crash sensor for front airbag; passenger side: Serial number: 63832SME6B1C51384 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 G HW: 8K0 953 568 G Component: Lenks.Modul H09 0011 Revision: -------- Serial number: 90304GF8000AI Coding: 00003F Shop #: WSC 06745 123 28888 VCID: 3E783DD0A93B12EEA9B-806B Component: E221 - MFL H02 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 930 A HW: 8K0 920 930 A Component: KOMBIINSTR. H18 0224 Revision: 00200000 Serial number: 9DZ420K29 Coding: 03DF11822F001008810101 Shop #: WSC 00040 207 97528 VCID: 2B5E04844A4997461E5-807E No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 Q HW: 8T0 907 468 L Component: GW-BEM 5CAN-M H10 0095 Revision: FB600048 Serial number: 4800F0921880BC Coding: 000303 Shop #: WSC 06335 000 00000 VCID: 4FA670141E918B6652D-801A Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H06 0160 No fault code found. ------------------------------------------------------------------------------- Address 1B: Active Steering (J792) Labels: None Part No SW: 8K0 907 144 C HW: 8K0 907 144 C Component: DYNAMIKLENK. H06 0500 Revision: 50001005 Serial number: -------------- Coding: 020000 Shop #: WSC 06335 000 00000 VCID: 2F6610947E51EB6632D-807A No fault code found. ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb Part No SW: 8K0 857 511 C HW: 8K0 857 511 A Component: FLA H04 0003 Revision: AA001002 Coding: 02019164747464545425363E Shop #: WSC 06335 000 00000 VCID: 316216EC6865FD96249-8064 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb Part No SW: 8K0 959 760 A HW: 8K0 959 760 A Component: MEM-FS H05 0043 Revision: AA000000 Serial number: 00001001197246 Coding: C0585B402F0044540404 Shop #: WSC 12345 123 12345 VCID: 38742BC88B1F2CDE637-806D No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: None Part No SW: 8K0 907 566 D HW: 4L0 907 566 B Component: J0769_SWA_MasterH01 0010 Revision: 00H01000 Serial number: 6PZ 009 014-17 Coding: 0000106 Shop #: WSC 06335 000 00000 VCID: 38742BC84B1F2CDE637-806D Subsystem 1 - Part No: 8K0 907 568 D Component: J0770_SWA_Slave_H01 0010 Subsystem 2 - Serial number: 6PZ 009 014-37 Subsystem 3 - Serial number: 5F19.02.0900H010003CT10613ÿ Subsystem 4 - Serial number: T10613ÿ No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 D HW: 8K0 959 793 D Component: TSG FA H11 0250 Revision: Serial number: 0000008546624 Coding: 031E12205E00410001 Shop #: WSC 00004 207 97528 VCID: 4182462CD8C56D16D49-8014 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 BQ HW: 8K0 907 064 BQ Component: BCM2 1.1 H90 0247 Revision: 00002001 Serial number: 0117444679 Coding: 015E1E20003D348503B0028826000000 Shop #: WSC 00040 207 97528 VCID: 80040328134F241E1B7-80D5 Subsystem 1 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 1301 Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591 Component: J245 PS133 H06 0041 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb Part No SW: 8T0 035 223 H HW: 8T0 035 223 H Component: DSP Prem H04 0120 Revision: 00004001 Serial number: 34880004607903 VCID: 336E1CE49279CF86565-8066 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 D HW: 8K0 959 792 D Component: TSG BF H11 0250 Revision: Serial number: 0000008605353 Coding: 031C12205C00410001 Shop #: WSC 00040 207 97528 VCID: 40844328D3CF641EDB7-8015 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 G HW: 8K0 907 801 G Component: EPB Audi B8 H08 0080 Revision: 00000003 Serial number: 10000000197041 Shop #: WSC 00000 000 00000 VCID: 336E1CE49279CF86565-8066 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 8T0-907-357.clb Part No SW: 8H0 907 357 A HW: 8H0 907 357 Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000019 Shop #: WSC 06334 000 00000 VCID: 306413E8A36FF49E2B7-8065 Subsystem 1 - Part No: 8K0 941 329 Component: AFS-Modul links H01 S001 Subsystem 2 - Part No: 8K0 941 329 Component: AFS-Modul rechtsH01 S001 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4F0 035 053 B HW: 4F0 035 053 Component: Radio U Basic H45 0020 Revision: AB001007 Serial number: 341CU097557209 Coding: 010003010000000001 Shop #: WSC 06335 000 00000 VCID: 1C3CD7581FE760FE67F-8049 No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner (R78) Labels: None Part No SW: 4F0 919 129 C HW: 4F0 919 129 Component: HybridTV-DVB H06 0390 Revision: R0060000 Serial number: 76300802460102 Coding: 0E020000 Shop #: WSC 00003 207 91381 VCID: 2C5C07984F47907E17F-8079 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb Part No SW: 8T1 035 666 D HW: 8T1 035 666 Component: H-BN-EU H64 0047 Revision: -------- Serial number: 321CO097561219 Coding: 010100050306E9FF75001F1E000000030000 Shop #: WSC 00004 207 18087 VCID: 3B7E34C4BA2907C68E5-806E Subsystem 1 - Part No: 8R0 060 884 C Component: EUROPE 2008 5608 Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604 Component: DU7 High H43 0306 Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G Component: E0380 Bedient H08 0100 1 Fault Found: 01043 - Control Module; Incorrect Software Version 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 125 Mileage: 68701 km Time Indication: 0 Date: 2014.10.01 Time: 15:09:28 Freeze Frame: Bin. Bits: 00000000 00000000 Bin. Bits: 00000000 00000000 Bin. Bits: 00000000 00000000 Bin. Bits: 00000000 00000000 Bin. Bits: 00000000 00010000 ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HL H10 0251 Revision: Serial number: 0000008620155 Coding: 010C12204000210001 Shop #: WSC 06335 000 00000 VCID: 448C4F38C7D7783EFFF-8011 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels: 8K0-907-383.clb Part No SW: 8K0 907 383 HW: 8K0 907 383 Component: Anhaenger H14 0080 Coding: 0100000000000000 Shop #: WSC 00000 000 00000 VCID: F1E256EC28E53D96E49-80A4 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4L0-910-441.clb Part No SW: 8T0 907 441 B HW: 4L0 907 441 A Component: J772__Rearview 0070 Revision: --H12--- Serial number: 525PA8-J86908I Coding: 1030006 Shop #: WSC 00004 207 180878 VCID: 377628F4460123A66AD-8062 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels: Redir Fail! Part No SW: 8K9 827 851 HW: 8K9 827 851 Component: J605 Master H24 0290 Revision: -------- Serial number: 8K9827851 VCID: FBFE74C47AA947C64E5-80AE Subsystem 1 - Part No SW: 8K9 827 852 HW: 8K9 827 852 Component: J756 Slave H24 0290 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HR H10 0251 Revision: Serial number: 0000008620143 Coding: 010C12204000210001 Shop #: WSC 06335 000 00000 VCID: 448C4F38C7D7783EFFF-8011 No fault code found. End --------------------------------------------------------------------- |
