S4 peelers on AR?
S4 peelers on AR?
Hi all-
First mod to my 2015 AR is considering to add 19 x 8.5 x 43et peelers with stock tyres(255 35 19).
Questions are with the offset difference ( 17mm), what should I consider in mounting these?
Would a spacer and or wider tire fill the opening? Perhaps a slight drop as well? Sline or HR sport maybe?
Or should I be looking for a different wheel altogether?
Found a local set for a good price but if they aren't ideal, I'll keep looking.
Many thanks,
Many thanks,
B8 allroads can swallow wide wheels with low offsets. Instead of S4 peelers, I would get a set of S5 peelers. They are 9" wide and et33. From there, you could run a 10mm spacer and still be fine. I have a set of S5 peelers and was running 10mm spacers front & rear with 255/35/19 PSS. I'll probably be selling them soon if you're interested.
BlackAce
Q5/SQ5 MKI (8R) Discussion
20
08-18-2013 04:10 AM
Jonnyz1245
S4 (B8 Platform) Discussion
10-13-2011 04:02 PM
