034 Motorsport Springs - real world experiences
#21
So after a couple days of bombing around I am pretty happy with the ride. Im not sure if I will keep it forever but that is purely because of where I live, not the setup. Keep in mid I'm coming from a truck with 35in tires and a foot of suspension travel and I live in practically a 3rd world country down here in NOLA. I was honestly a bit worried but it is tolerable down here so I wouldn't hesitate with halfway decent roads. I do see what people are talking about with the bit of bounce in comfort mode but on rough roads it is worth it and not out of hand. I had 4 passengers in the car last night and I didn't have any complaints. I'm also on 20s so if you stay in 18-19 range you should be even better off. The car handles beautifully and feel like it is on rails but again, I haven't owned a proper handling car in years. I will eventually get it on the track and will then probably start questioning the rear sway because practically every VW/Audi needs one but time will tell. In the mean time the stance is just about perfect imho and it will be hard to go to anything else.
The following 4 users liked this post by Turboale:
#25
You are probably better off than the adaptive honestly...
I obviously haven't ridden in a non-adaptive Allroad but I would guess that the valving is between the two adaptive settings. Maybe reach out to 034 and see if they have any knowledge of factory shock valving?
#26
Painted Gloss Black. Holding up so so. Some flex chips that annoy me. They could have done a better job. I would take somewhere else next time. Likely will be re-doing or going with another option *cough* *cough* if I can just find the time to dedicate.
#27
rear sway bar and subframe mounts will really help firm up the backend. It will feel less top heavy and more grounded.
Front strut brace really helps up front too, definitely recommend. I'd also suggest the transmission mount insert it also makes for a smoother/better ride.
#28
#29
Thanks Bob. Need to get a few more things in the pipes going before Spring springs for this season!
