2017 Coolant Leak Systemic Problem
So I found my coolant tank completely empty about a month ago and filled it up. Thought that maybe the fill bottle lid was too loose and made sure to tighten it down. Couple of days ago I checked and noticed that my tank was half full and brought it into the dealer.
They checked it out and said the thermostat housing cover was leaking pretty badly and that another B9 A4 was in their shop for the second time with the same issue. They told me it is a known design flaw and that this is happening so frequently that there are no replacements available in the country (as they are all spoken for to other dealers) and it will be about two weeks until a replacement shipment arrives. They gave me a free loaner so its not that big a deal (although I miss my HUD and adaptive cruise control) but just something for other B9 A4 and Allroad owners to keep an eye on.
Lastly they said that our DSG has lifetime fluid and requires no maintenance which was news to me as it was an expensive procedure on my '13 s4's DSG.
How did you notice the coolant leak? Curious if you were just poking around and noticed (as in should i keep my eye on it) or did you see fluid somewhere?
Additionally, any Audi dealership technicians that told me the DSG transmission fluid was set for life would raise red flags with me pretty quickly.
I too have had the coolant tank go dry a few times. Three times so far in 40k miles. It's roughly 1 liter of coolant to refill. WIll probably get that fixed before the warranty's out.
The DSG fluid is at 40k, it was a much simpler job than I thought, compared to DSG fluid changes in older Audis.
I just had the exact same issue. I received a low coolant warning from the MMI one day, checked and the reservoir was almost empty. I took it in to the dealer and they confirmed the same thing. I've been waiting for three weeks now because the part is back ordered everywhere. They gave me a new A6 as a loaner so it's not costing me anything, but I much prefer my own car.
I would have thought the engine would have immediately overheated and seized up - with the associated damage when the coolant gets anywhere near empty. Good to know that did not happen. But it is something I will be opening up the engine for once and a while and taking a look.
What is the recommended antifreeze for the A4's?
Antifreeze recommendation
more choices
[QUOTE=breadbooze;25132593]The car will automatically kill the engine if coolant temps ever rise high enough for boilover. You will get lots of flashing red warnings in the VC. If the coolant level low warning comes on it takes about 1L of coolant in the overflow to bring it back the the minimum level mark, and about another 0.5L to max. OE coolant is G13, part number GA13A8JM1, or Pentofrost E is the same under the manufacturer's label. Dilute 1:1 with distilled water.[/QUOT
So with your recent experience, are you carrying antifreeze in your trunk?
