91 OCTANE NON ETHANOL GAS
Is there any benefit to using non ethanol gas? And if so , is 91 octane sufficient. I guess the real question is : whats better, 93 octane with ethanol or 91 octane without ?
I sure would not be afraid to use the E0 91 AKI gasoline. It meets the mfr's recommendation.
Do you have to travel far to buy that fuel? |
Its right here in Waitsfield , where I live and its only $3.09 per gallon. So, you would use it? Whats the benefit ?
Avoid the corrosive effects of ethanol and potentially higher MPG.
Can you say what brand it is? |
No ethanol means maybe 10% better gas milage.. so if its less than 10% more cost then you win.. here in portland its over $4 a gallon while regular super is $3.25... :( |
Originally Posted by jcallip1
(Post 25145358)
I can write an essay about this, the condensed form would be use the non-ethanol 91 octane gas whenever you come across it. The new england states tend to have more E0 gas scattered around than other parts of the country.
Yes, Audi has engineered the fuel system to withstand E15 but that doesn't make phase separation a non-issue. |
Originally Posted by breadbooze
(Post 25149240)
(Post 25149240)
There is a local gas station near me that tries to market to millennials with growler station etc. Well, they have a non-ethanol 100 Octane grade... supplied by Marathon. I've never seen this one before and its about a dollar more than the traditional premium gas... so it would make it about 4.50 a gallon. I haven't used this yet, and not sure I will because i have no clue what it may do to the engine, or other components. Would you try it?
