A4 allroad (B9 Platform) Discussion Discussion forum for the B9 Audi A4 allroad quattro 2017-
Coding the tailgate
Old 08-30-2017, 11:34 AM
Seth Fiermonti's Avatar
Default Coding the tailgate
Is there a way via VCDS to code closing the tailgate with the key fob and/or button in the interior by the driver seat?
Old 08-30-2017, 12:59 PM
FLkiwi's Avatar
What did you want to change? I have a 2017 and it generally just works, both from the key fob and from the switch in the driver's door. One thing I've seen people code is the delay on the key fob to prevent it being opened by an accidental pocket click, but I haven't had this issue so haven't needed to. There's a thread about it somewhere if you search.
Old 08-30-2017, 01:01 PM
I want to close the tailgate with the FOB. It's not working in my model. I can open it no problem but closing it doesn't seem to work.
Old 08-30-2017, 05:38 PM
archrenov8's Avatar
I think that the reason you cannot close it from the FOB is that there would be no assurance that you were actually there close enough to make sure it wouldn't hurt someone if it closed.
Old 08-31-2017, 04:06 AM
I was being stupid. Wasn't holding the button down long enough. It closes with the fob
Old 09-03-2017, 12:14 PM
archrenov8's Avatar
That is strange. Now it is working. In the past, when I tried closing it with the FOB, it did not work.
Old 09-04-2017, 11:07 AM
FLkiwi's Avatar
I have seen threads describing the fob only working from behind the car, and within a very limited range (for the safety reason you describe).
This has not been my experience - I haven't tested the range, but for me, it works from at least 25-30 ft away from any angle of the car.
Make sure you hold the button down for a second or two. You might want to try doing it from directly behind the car, too, in case that's something that applies to specific build batches. Mine is a 2017, built around April 2017.
Old 09-04-2017, 01:21 PM
archrenov8's Avatar
Actually, I tried it again today, and it only worked if I was behind the AR, not alongside it.
Old 09-04-2017, 02:19 PM
Dan in St. Louis's Avatar
The Owners Manual has specific information about the distance from the car, whether the key fob is INSIDE the car, etc. Look around pages 41-44 (if your manual is the same version as mine).
EuroCK
Audi A3 / S3 / RS 3
09-25-2008 01:33 PM
Imola Ghost
VAG-COM Discussion
12-18-2006 06:51 AM
tehA8PIMP
11-19-2004 03:44 PM
SSSScargo
02-24-2004 12:59 PM
Bruuster
01-15-2003 08:24 PM
Quick Reply: Coding the tailgate
