* HELP ! 98 1.8T 65K Oil-cooler leaking..dealer says new oil-cooler, coolant + engine flush......
Old 08-04-2001, 10:45 AM
Phil's Avatar
Default * HELP ! 98 1.8T 65K Oil-cooler leaking..dealer says new oil-cooler, coolant + engine flush......
Anyone else have this happen ?
Old 08-04-2001, 10:54 AM
Junior Member
A4orce CJ's Avatar
Default seen it 3 times...
oil leaks into the coolant, and sludges up. you need a really good coolant flush(after you replace the oil cooler), might as well replace the t-stat while you're there. use shout spot remover(shout it out!) in the coolant system, and run a garden hose thru it with the engine running, and a good oil change. how much is the dealer charging for the repair?
sucks, doesn't it?
Old 08-04-2001, 11:36 AM
RKA
AudiWorld Uber User
RKA's Avatar
Default A question regarding your flushing method...
I've never flushed the coolant in my car, so bear with me...
You're suggesting that he open up the drain for the coolant, run the garden hose wide open into the coolant tank, and start the car? Isn't there a possibility that the water pump could run dry (even if only intermittently). Couldn't that damage your water pump??? Wouldn't it be safer to drain, tighten drain plug, fill with water, run engine, and repeat those procedures until you're satisfied that you've flushed it well?
Sorry for being a nitpick, it just seems to me that he could do damage to his car if he does this wrong...then again, I could be completely wrong!
Old 08-04-2001, 12:03 PM
Phil's Avatar
Parts are going to be around $210 I assume it may take 4 hours for a $ 500. + bill.
Old 08-04-2001, 12:26 PM
James R.'s Avatar
Default Hmm never tried the garden hose technique on the audi...but I have on other cars
and usually you'll find that the garden hose will more than keep up...
Regards,
James R.
Old 08-04-2001, 07:08 PM
Junior Member
A4orce CJ's Avatar
A garden hose with decent pressure will provide more than the pump can handle... It will be fine...
SkiBum2
01-26-2011 04:09 AM
VR_Life
Audi Original "S" Cars
10-15-2008 08:39 PM
greenbird
10
01-04-2008 03:42 PM
Couper
10-04-2001 07:33 PM
Quick Reply: * HELP ! 98 1.8T 65K Oil-cooler leaking..dealer says new oil-cooler, coolant + engine flush......
