01 a4 ticking noise
ok so i have a 01 a4 1.8t quattro. its making a weird ticking noise while at idle. the noise goes away when i drive or when i just give it gas but it resumes when i come to a stop/idle. i have no clue what it is. any ideas?
Originally Posted by '01audia4quattro
(Post 24340315)
Originally Posted by TheChenga
(Post 24340420)
does this happen only on cold start up ?
(Post 24340576)
no. and its driving me crazy not knowing what it is.
if its more of a clack its your rear cam tensioner. You could have bad lifters as well.. check your oil.
Check for leaks around the rear of the engine where the cam chain tension is. If it seems to be running OK I'd just keep it well oiled and try to ignore it. If it gets much noisier I'd take it to a shop if you aren't a DYI sort of guy. Good luck. |
no oil pressure warning ever or anything? I would really get it looked at, noise is caused by somthing, and its probably wearing out fast
oil light every once in a while. and it is coming from the back of the motor and yes it is more of a clack
I have the same problem in my 96. My car shut off one day and now it makes a lounder knocking noise but I'm taking my car to a garage tomorrow to finally figure out what's wrong with it.
(Post 24341786)
STOP DRIVING IT!!!!! Your oil pump pickup is clogged. STOP!!!! you will throw a rod and destroy the engine. have it towed to a shop and the oil pan removed and bearing inspected, if there good, clean the pickup, replace the feed line to the turbo, and fill with fresh synthetic. Change at 5k miles ALWAYS ON TIME! I see this frequently and people need to take that oil warning seriously. The dynamic oil pressure system is smart as hell and knows theres not enough pressure
