1996 A4 B5 Rear Window Defroster stopped working
Hi,
Just had my engine ECU replaced (with a second-hand one) due to loss of power to the fuel pump. Having just picked up the car, I noticed that the rear window defroster is now not working.
Does the ECU have any control over the function of the rear defroster? If so, is it possible for the "new" ECU to have fixed the fuel pump power problem but is now causing the defogger issue?
Any advice or information would be most welcome.
Thanks.
Thanks.
Suspect not, the power for the defogger comes from the load reduction relay (and lots of stuff wouldn't be working if that were bad), to a fuse, then to the dash switch, then to the antenna amplifier, and finally to the defogger. I would check the fuse, and if it is good then if the light in the switch comes on when you turn the defogger on the problem is after it, otherwise the switch.
Check the fuse first, my manual says #26, but check your owners manual, things move around. Then if it is good check your switch. Use an ohm meter to check it if it looks good, sometimes they will just crack internally, but not look blown. Or substitute a different fuse and see if it works. Keep in mind that fuses usually blow for a reason, so if it is blown you might have a bigger problem, so if it blows again you need to dig deeper. Don't substitute a bigger fuse, that is just a way to burn wiring.
b5t
01-26-2005 09:47 AM
