1999 Audi A4 2.8 Quattro 5 speed p1545 17953 codes?!
I know there are a thousand posts about this code and this car, but please read before responding.
So long story short, i bought the car from an old buddy. It had been sitting for a year or two. When i bought it he had said something like it may need a coil or a MAF sensor. So i bought both and threw them in, still getting a rough idle and car seems like its hitting rev limiter around 1400-1500 RPMS. So i went and got a generic Scan tool, just to see what the codes were, and i only got a P1545, " Throttle Body Valve Malfunction" I read up on some forums were saying the Throttle body was bad, bought a tb. Still same result. Then i was like well maybe its because i have a cheap scanner.. I have my buddy come by with a "ROSS-TECH" Cable Vag-com set up. We get an 'ERROR' when trying to re-align the throttle body. So then i did a little more reading up, everyone was saying the ECU was probably on the way out. Ordered a ECU, with thee exact numbers, and letters. And still same exact result.
When i bought the car, i know it needed a few things, So this is what i have replaced so far.. Battery, ECU, Throttle body, Mass Air flow Assembly, Plugs, Wires, coil, and valve cover gaskets.
The car doesn't have an exhaust after the flex pipes, the 02's are gone from "bank 2" or after the cat, but from my understanding those aren't really for your air - fuel. They are more to see if the CAT is doing its job, if I am wrong please correct me.
Any Ideas, or tricks are greatly Appreciated.
Thanks,
Ryan.
Thanks,
Ryan.
wisconsin_quat
9
11-04-2008 11:38 AM
Ken400
06-14-2007 11:30 AM
