2001 Audi A4 B5 2.8 Quattro Misfire! Please Help!!
Hi, I have a 2001 A4 2.8 Quattro with 140,000 miles that I recently bought. When I hook up my Vag-Com, the scanner says intermittent misfire, cyl 1, 2 and 3 misfire, and o2 sensor codes. I am currently in the process of replacing the pre-cat o2 sensors, and I have already replaced the plug wires, plugs and I have put seafoam thru the intake, and the oil and changed the oil, and I put fuel system cleaner in the tank. I'm thinking it's a bad camshaft position sensor, but I don't know. Any help would be greatly appreciated.
Thanks, Daniel
Thanks, Daniel
Also: If i clear all codes, and only run the engine below 2,000 rpm, it won't misfire. Above that, the CEL comes on, and flashes, and when i drop the rpms down, continues to flash for about 30 seconds, then it's on solid until I clear it again. When taking off from a stop, the car has decent power until it gets above about 3,500 rpm, then it seems to fall on it's face. Also, it won't shift unless I let my foot off the pedal a little bit, then put it back on.
Thanks, Daniel
Thanks, Daniel
My guess is a timing problem. Check belt timing first, then chain. Could be a broken guide on the cam chain adjuster.
K9COP
11
08-30-2012 06:20 PM
