98.5 1.8t hesitation after warm up
My 98.5, 1.8t is starting to hesitate. I've noticed it more after driving for 15 minutes. It may get worse as I drive. I notice it mostly once it shifts into another gear and tries to accelerate. It feels like its bucking. It doesn't feel like the auto transmission. Is this a sign that the turbo is going out? Back spark plugs? Any other ideas.
Thanks. |
id say spark plugs/CPs for hesitation, and the bucking may be your mounts.
First what is your mileage, time since TB change, - for sure get the codes read
and if there are not codes try a can of BG 44K.
Coil packs could be going bad - same for needing plugs etc. Hard to say with so little info on car. |
Re: First what is your mileage, time since TB change, - for sure get the codes read
Mileage is around 117,000. TB was done around 80 I believe.
Is there a way to test coil packs? It only does it after the car is warm. Is that a symptom of coil packs? I have a Gross Evap leak but that has been going on and off for the last 3 years because I never turn the car off getting gas. I should check if there is a new code. |
Bucking is just another adjective to describe the hesitation/stutter. Mounts are ok.
never turn the car off when getting gas. Please explain this horrid practice
Re: never turn the car off when getting gas. Please explain this horrid practice
Years ago I'd trouble starting the car after getting gas. So, I avoided that problem by never turnning it off. Problem solved (temporarily). I do it out of habit now.
Whats so horrid about it? Are you one of those people that are afraid to use their cell phone around a gas pump? |
well that is probably tripping your evap code because the car is running and
the gas cap is open.....
Yup, I know that. Thats why I don't worry about it. I just make sure its off when the car needs its
...emissions done.
Here is one reason
<ul><li><a href="http://www.youtube.com/watch?v=b3x-8tj49ac">Link</a></li></ul>
