Old Nov 1, 2002 | 09:24 AM
nospek3's Avatar
Senior Member
Old Nov 1, 2002 | 09:28 AM
randy@5280's Avatar
Member
Default Probably too much involved...
If you want a non-dbw, just buy a non-dbw. Probably cost far less than trying to make the conversion.
Old Nov 1, 2002 | 09:29 AM
nospek3's Avatar
Senior Member
Old Nov 1, 2002 | 09:39 AM
Yippers®'s Avatar
Member
Someone (ECS ???) sells a conversion kit.
Old Nov 1, 2002 | 09:43 AM
randy@5280's Avatar
Member
Default I stand corrected...
Figured there was more to the conversion then just doing ECU, throttle cable, pedal, etc. How does the non-dbw ECU work with the dbw motors equipped with variable valve timing and the sort?
Old Nov 1, 2002 | 09:53 AM
nospek3's Avatar
Senior Member
Old Nov 1, 2002 | 09:54 AM
Yippers®'s Avatar
Member
Default I didn't do a lot of digging as I am already nDBW but...
This page shows the Golf/Jetta conversion 'kit'. I would imagine the Audi would be similar. If you swap over to a nDBW ECU and install the MAF sensor I would expect the MAP sensor would no longer 'pertain'.<ul><li><a href="http://www.eurospecsport.com/electrical.html">Eurospec .. not ECS</a></li></ul>
Old Nov 1, 2002 | 09:58 AM
Yippers®'s Avatar
Member
Default I know someone running a VVT head on a nDBW Stg 3. I don't know where in the V the VT lives but IIRC
it doesn't V
 Michael S. Palmer
Old Nov 1, 2002 | 10:00 AM
randy@5280's Avatar
Member
Are there many DBWers running this conversion?
Old Nov 1, 2002 | 10:08 AM
Yippers®'s Avatar
Member
No idea. The person I spoke of is just running a VVT head on a nDBW car. It isn't a conversion.
