A4 light issue/problem
Old Aug 7, 2010 | 08:29 PM
tahoe11111's Avatar
Default A4 light issue/problem
Hello everyone. I have an issue with my 1999 A4, 1.8T Q, sedan which somebody may already faced before: my light is going out every 3-4 months. All I have: parking light, turn light and high beam flashing light. Low beam lights and high light in "on" position do not work. I know what the the problem is: this lights/cruise control module is going bad. Inside there is a little lower plastic component with 2 cooper contact groups on the springs. As soon as one of the tracks is overheating plastic is melting and one contact group get stock and do not contact metal threads. It takes time to take off plastic covers, disconnect airbag, remove steering wheel completely before module can be replaced, tricky enough at least for my skills.
My question is: what could cause this overheating? Does anyone hear about recall? My bulbs are right according to manual 12V/55W and fuses are correct ones.
Any help would be appreciated!!
Old Aug 9, 2010 | 10:50 PM
12vB5's Avatar
The light switch contacts are on the small side and will eventually burn out. The solution is to add relays between the switch and the low and high beams and the fog lights. Check here for info on how to do this: http://www.danielsternlighting.com/t...ys/relays.html
audiquattroduo
9
Oct 1, 2010 01:36 PM
foxy_a6
2.7T V6 Discussion
Feb 7, 2010 10:14 AM
A4tek
Feb 7, 2007 04:56 PM
QuattroEngineering
Jul 17, 2005 03:20 PM
Avants
Audi 100 / A6 (C4 Platform)
Jun 30, 2004 08:58 AM
