ABS Problem.... Any Help??
Ok Here is my problem. My ABS (solid) and brake light(blinking) had come on. I used my Vag-com to retrieve the codes. There was 1 code listed. It was for the right rear (performance / range)
I took the wheel, rotor etc off. Inspected the abs sensor. Since I had replaced the other 3 I decided to replace the 4th. So I replaced the abs sensor.
Now I can drive around town, etc with no problems. When I get on the highway and get up to speed (65-75 mph) after about 5-10 min the abs lights come on again. The same code appears, Right Rear Speed sensor(performace / range)
I have since replaced the brake pads, rotors. What should I look at next? The calipers? Could they be hanging up and only noticable at highway speeds?
Any help would be appreciated.
Thanks
Should I use brake cleaner or electronics cleaner?
Thanks
