ABS Unit question
You can access the top wire harness without removing the entire unit, but to get to the bottom wire harness you'll need to remove the computer.
In my 99.5, the computer is attached to the top of the ABS pump, in the engine bay.
To remove the computer, I did the following:
- Removed driver's side front wheel
- Removed wheel liner
- Removed Washer fluid reservoir
- Unscrewed all 6 screws attaching the computer to the pump. (only one is inaccessible, and therefore necessitates the removal of the washer fluid reservoir)
- Unplugged top and bottom plugs on the computer
- Removed computer by sliding the computer away from the pump (careful not to bend the solenoids)<ul><li><a href="http://www.autoecu.com/Products/default.asp">http://www.autoecu.com/Products/default.asp</a</li></ul>
Remember, you won't have ABS, and if you have traction control it might not work.
