AC Clutch Plate Fell Off
As I pulled into work today, it sounded like someone was working with a jackhammer. It stopped when I turned the car off. I opened the hood to discover that the AC clutch plate fell off and it was rubbing on the crank pulley. Using a long stick and duct tape, I was able to retrieve it from the topside.
The clutch plate is a little chewed up but I can salvage it if I can find a bolt and shims. The dealer sells a clutch pack that includes everything from the compressor out for, get this, $850. All I need are a couple skinny washers and a bolt. Anyone have their dimensions?
Has this happened to anyone else? What did you do?
I am going to be swaping my clutch this weekend time permitting. I got a used compressor and removed the clutch, their were no shims in the one I removed. the end cover is held on by a 10mm bolt then the pulley is held on with a C-Clip, then the electromagnet which is the part I need to swap has another clip, mine is also a 98. I could probably send you the parts when I am finished next week.
Thanks, this is a big help
If you would check the length of your bolt (the threaded part), that would be all that I need at this time. If it loosens up I will replace it. Next time I do a timing belt, I will replace it the proper length bolt. With my giant meathooks, it is tight to work on from underneath or above the vehicle.
Thanks for offering to send the bolt. Truly a kind gesture.
Pscheoverdrive
02-04-2007 07:42 PM
skiddmark
07-21-2002 09:57 AM
SteveK-O (stock!)
02-18-2002 10:04 AM
