AC stopped working after climatronic change
Hi !
I have a A4 2.8q 95. And the climatronic was broken so i got a new used one but form an 98 A4. Now the AC dosen't work. Basiclly nothing works exept the display and it blows mor or less and i can change the temp. But nothing else. Any ideas ? TNX |
I Accessed the On-Board Diagnostic codes if my AC this is what i got:
05.3 Outside Air (Ambient) Temperature Sensor, front, sporadic open 06.1 (G110) Engine Coolant Temperature (ECT), A/C static open 07.1 (G109) Ambient Temperature Sensor at Fresh Air Blower, static open 11.7 Central Flap, sporadic block 15.5 Air Flow Flap, static block 22.1 (F118) A/C Refrigerant High Pressure Switch, static open 49.1 50.3 |
Originally Posted by fire_warrior_3
(Post 24339732)
Hi !
I have a A4 2.8q 95. And the climatronic was broken so i got a new used one but form an 98 A4. Now the AC dosen't work. Basiclly nothing works exept the display and it blows mor or less and i can change the temp. But nothing else. Any ideas ? TNX The AC was redesigned for model year 97 so it will never work. You can't recode it either. See if you can get the old unit repaired or find one from either an earlier Audi 90 or A4. |
Crap.
Tnx anyways :) |
So there is no way to make it work ?
(Post 24339846)
