anyone with the RS4 alcantara shift knob swap out the shift pattern from A4 knob to that?
AudiWorld Expert
anyone with the RS4 alcantara shift **** swap out the shift pattern from A4 **** to that?
I just got my RS4 shift **** today and it has a crack in the plastic covering the shift pattern? does the stock plastic cover fit the RS4 ****??? =)
AudiWorld Expert
pic of crack =o\
<img src="http://www.imagestation.com/picture/sraid26/p34807f8f3ba22319c44ce810f4907213/fe37380e.jpg.orig.jpg">
<img src="http://www.imagestation.com/picture/sraid26/pe6b02bc53c3df5ec42142ba06bf4ef0a/fe37380d.jpg.orig.jpg">
It's the right curvature. Do they look to be the same size?
I know how the stock one comes apart. I bet that silver ring takes the whole top off.<ul><li><a href="http://georgeryon.com/audi/images/****/">http://georgeryon.com/audi/images/****/</a></li></ul>
AudiWorld Expert
ball part? this is what I have?
<img src="http://www.imagestation.com/picture/sraid26/p3b0c62824a8e666544c76493ba8cb04d/fe373545.jpg.orig.jpg">
the two shift pattern pieces are NOT the same curvature on the underside =o\ guessing I can remove a part of the RS4 **** to fix that, but not sure how yet =o\
AudiWorld Expert
NM got clarification on it from a friend
<img src="http://www.imagestation.com/picture/sraid26/p35566f1597a404e8fb316da7e258e7bf/fe3733ff.jpg.orig.jpg">
I had to remove the inner piece that sat on the silver bezel. It just popped out relatively easily. THANKS DUAN! =) The acrylic shift pattern on the stock A4 **** has a tab that I had to grind down(GOoooooooooo Dremellllllllllll!) and then I used spray paint(black) to cover the exposed plastic. Put some CA(super glue) and glued the stock shift pattern onto the bezel, all done =)
AudiWorld Expert
The finished **** install!
<img src="http://www.imagestation.com/picture/sraid26/pbf56a4733fc46dace68ab73af28fa83e/fe37334e.jpg.orig.jpg">
<img src="http://www.imagestation.com/picture/sraid26/pec92653f72d3df5bc740f5b79cc0dc27/fe373350.jpg.orig.jpg">
AudiWorld Expert
forgot to add, before gluing the A4 shift pattern piece down onto
the bezel, you need to cut(with dremel or something else) the two tabs that come up from the ****.
