View Poll Results: Do you prefer the OLD FAQ?
I want the OLD FAQ back!
100.00%
I like the NEW FORMAT
0%
Voters: 4. You may not vote on this poll
AUDI A4 | B5 | 8D 1996 - 2001 FAQ Frequently Asked Questions and Common Problems Thread Collection
Old 04-02-2005, 05:35 AM
  #11
FAQ Author
BSK auf Arbeit's Avatar
Default Drivetrain, Transmission, AWD System, Quattro, differentials
<center><img src="http://star-motoring.com/archives/2005/11/6/motorreviews/mo_07audi2.jpg"></center><p>
BSK auf Arbeit is offline
  #12
FAQ Author
Default Common Problems and the repairs that go along with them
<center><img src="http://pictureposter.audiworld.com/76496/rod.jpg"></center><p>
  #13
FAQ Author
Default Climate Control Air Conditioning
<center><img src="http://www.summersmotors.co.uk/images/air_conditioning.jpg"></center><p>
Old 04-02-2005, 05:36 AM
  #14
FAQ Author
Default Brakes
<center><img src="http://www.mnaudi.com/mymnaudi/images/860/Smash%20004.jpg"></center><p>
  #15
FAQ Author
Default Alarm System
<center><img src="http://i7.photobucket.com/albums/y293/FastA4Turbo/audi/alarm_systems.jpg"></center><p>
  #16
FAQ Author
Default Exhaust, Downpipe, Catalytic converter, muffler
<center><img src="http://img110.imageshack.us/img110/7232/neuspeedexhaust0041oi.jpg"></center><p>
Old 04-02-2005, 05:37 AM
  #17
FAQ Author
Default Tires, Rubber, Slicks, Valves, Flat repair
<center><img src="http://image.motortrend.com/f/auto-review/audi-a4-32-s-line-quattro-in-galoshes/6218344+w700+cr1+re0+ar1/a4-wheel-with-blizzaks.jpg"></center><p>
Old 04-02-2005, 05:38 AM
  #18
FAQ Author
Default Body
<center><img src="http://www.caractere-uk.com/images/AUDI/A4_B5/A4_95_AV_1.jpg"></center><p>
Old 04-02-2005, 05:54 AM
  #19
FAQ Author
Default Modules on the B5 that Vag-com can connect to
Specific Modules:
01-Engine: -- KWP-1281
VAG-COM works well with all engines available in the U.S. and most engines that users have tested in overseas markets.
Idle Speed Adaptation:
With engine warmed up, at idle:
[Select]
[01 engine]
[Adaptation - 10]
Enter channel 01
Enter an adaptation value between 124 and 132
[Save]
(May require a Login of 01283 or 11463, depending on year or model)
Throttle Body Adaptation:
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Measuring Blocks - 08]
Enter Group 060 (may be Group 098 on some cable-throttle cars)
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB
adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in basic mode for about 30 seconds, then switch back to normal settings and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
02-Auto Trans : -- KWP-1281
VAG-COM works fine
Recoding Tiptronic:
In the newer cars, there are coding options for "Old" vs "New" "Tiptronic strategy". The "New" stategy (introduced in 2000 I think) is much more "automatic" than the old. To get the "Old Tiptronic strategy" where it won't downshift unless you come to a complete stop, I believe you have to change the coding in the following manner:
[Select]
[02 - Auto Trans]
[Recode - 07]
Enter the coding below
[Do It!]
Write down the original coding for future reference.
Look at the fourth digit in the coding (Cylinders):
0 or 1 - "New-style Tiptronic"
2 - "Old-style Tiptronic"
Look at the fifth digit in the coding (Market version):
1 - "Rest of world, quattro"
2 - "USA, quattro"
3 - "Rest of world, FronTrak"
4 - "USA, FronTrak"
So, for a USA model A4 quattro, if the original coding is 00002, and you want to change to the "Old-style Tiptronic" strategy, change the coding to 00022.
PS: As always, you play with stuff like this at your own risk. The "old" strategy is documented by VW only for "testing" and they explictly say that the car should be recoded the way it was before giving it back to the customer.
03-ABS Brakes: -- KWP-1281
VAG-COM works fine
08-HVAC: -- KWP-1281
VAG-COM works fine
15-Airbags: -- KWP-1281
VAG-COM works fine
17-Instruments: -- KWP-1281
VAG-COM Works fine.
Immobilizer II Instructions:
Immobilizer III Instructions:
Note: US/Canada model Audi A4/S4 do not have Immobilizers.
Recode for warning lamps:
[Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active (may only work with pre-2000 models)
+16 - Navigation System (non-USA models)
Look at the third digit in the coding (Market version):
0 - "Germany" 24 hour clock
1 - "Rest of World" 24 hour clock
2 - "USA" 12 hour clock
3 - "Canada" 12 hour clock
4 - 4-cylinder
6 - 6-cylinder
Look at the fifth digit in the coding (Distance impulse multiplier):
0 - TDI Engine (non-USA models)
2 - Non-turbo Gasoline engine
4 - Turbocharged engine
So, if you want to have Seatbelt warning and washer fluid warning only in a 1999 Canadian A4 2.8, (add 00+02+04 = 06),3,6,2 = 06362.
Change Language Displayed:
[Select]
[17 - Instruments]
[Adaptation - 10]
Enter channel 04
The available languages are :
00001 - German
00002 - English
00003 - French
00004 - Italian
00005 - Spanish
00006 - Portuguese
[Save]
Resetting Service Reminder Intervals:
http://www.ross-tech.com/vag-com/cars/audi_sri.html
22-AWD * Purely Mechanical!
The quattro system in these cars is purely mechanical, no electronics at all. This address is used by the Haldex system used in transverse-engine cars like the TT, the A3, and various Golf/Bora models.
35-Central Locks: -- KWP-1281
VAG-COM Works fine (note: pre-'97 A4's may not have this module).
Recode locking options
[Select]
[35 - Cent. Locks]
[Recode - 07]
[Do It!]
A4 pre-1998 with Delta radio and anti-theft system
Standard Coding: 03468
A4 pre-1998 with Delta radio, anti-theft system and keyless entry
Standard Coding: 12172
A4 1998+ with Concert/Symphony radio and anti-theft system
Standard Coding: 03340
S4, A4 1998+ with Concert/Symphony radio, anti-theft system and keyless entry
Standard Coding: 16140
Add the following options to your coding number:
+64 Windows up, sunroof close, and windows down with remote.
-04 One touch unlock of all 4 doors and trunk
-1024 Remove horn honk when arming
+32 Auto lock/unlock of doors (Doors lock at 15 mph and unlock when key is removed)
So, if you want to have a 1999 A4 with Concert radio and anti-theft system and keyless entry, and you want to add window control with the remote along with auto-lock, then:
add 03340+64+32= 03436
37-Navigation: -- KWP-1281
VAG-COM Works fine.
45-Int. Monitor: -- KWP-1281
VAG-COM Works fine (note: This is tied in with 35-Central Locking so it may not work with pre-'97).
Sensitivity Adjustment
[Select]
[45 - Int. Monitor]
[Adaptation - 10]
Enter channel 01
Enter a value between 50-100 (it should be 100 by default) for the sensitivity of the ultra-sound sensors
[Save]
55-Headlight Range: KWP-1281
VAG-COM Seems to work fine.
Note this controller is only present on cars with Xenon headlights.
56- Radio: * KWP-1281
Please read the following pages pertaining to Audi Concert and Symphony Radios
Old 04-02-2005, 05:59 AM
  #20
FAQ Author
Default Changing Temperature Display between Celcius and Fahrenheit
Press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius &amp; Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays.
Quick Reply: AUDI A4 | B5 | 8D 1996 - 2001 FAQ Frequently Asked Questions and Common Problems Thread Collection
