Audi TSB's & Recalls (1990-2010)
Old 01-06-2011, 09:35 PM
mksu19's Avatar
Default Audi TSBs & Recalls List (1990-2010)
Service Bulletins for 1990 Audi
No service bulletins exist.
Recalls for 1990 Audi
1990 AUDI 100
NHTSA Campaign ID: POWER TRAIN:AXLE ASSEMBLY
Manufacturer: VOLKSWAGEN OF AMERICA,INC
Manufacture Dates: 10/01/1984 - 01/01/1991
Potential Units Affected: 152000
Defect Description:
THE DIFFERENTIAL OIL OF THE TRANSAXLE IS LOST OVER TIME DUE TO EVAPORATION. LOW OIL LEVELS CAUSE PREMATURE BEARING AND GEAR WEAR AND EVENTUAL FAILURE OF THE DIFFERENTIAL.
Consequence:
IN THE EVENT OF FAILURE, THE VEHICLE'S DRIVE WHEELS COULDLOSE POWER. IN EXTREME CIRCUMSTANCES, THE FRONT WHEELS LOCK, CAUSING RAPID DECELERATION RESULTING IN POSSIBLE LOSS OF VEHICLE CONTROL AND AN ACCIDENT.
Action:
DRAIN AND REPLACE THE DIFFERENTIAL GEAR OIL WITH OIL HAVING HIGHER PERFORMANCE CHARACTERISTICS.
1990 AUDI 100
NHTSA Campaign ID: EQUIPMENT:OTHER:LABELS
Manufacture Dates: 07/01/1990 - 12/01/1990
Potential Units Affected: 5900
Defect Description:
THE VEHICLE CAPACITY WEIGHT WAS INADVERTANTLY OMITTED FROM PLACARD LOCATED INSIDE THE GAS FILLER DOOR, AS REQUIRED BY FMVSS 11O.
Consequence:
VEHICLES FAIL TO MEET THE REQUIREMENTS OF FMVSS 110.
Action:
NEW LABELS CONTAINING THE VEHICLE CAPACITY WEIGHT WILL BE AFFIXED TO THE VEHICLES.
1990 AUDI 100
NHTSA Campaign ID: AIR BAGS:FRONTAL:SENSOR/CONTROL MODULE
Manufacture Dates: 09/01/1988 - 07/31/1993
Potential Units Affected: 54800
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. SOME AIR BAG SENSORS DO NOT COMPLY WITH AUDI'S DURABILITY STANDARDS OVER THE LIFETIME OF THE VEHICLE.
Consequence:
IN THE EVENT THE SENSOR SHOULD MALFUNCTION, THE AIR BAG RESTRAINT SYSTEM CAN INADVERTENTLY DEPLOY. DEPLOYMENT OF THE AIR BAG RESTRAINT SYSTEM WITHOUT WARNING COULD CAUSE A DRIVER TO LOSE VEHICLE CONTROL.
Action:
DEALERS WILL REPLACE THE AIR BAG SENSOR CONTROL MODULE.
1990 AUDI 100
NHTSA Campaign ID: EQUIPMENT:MECHANICAL:JACKS
Manufacture Dates: 05/01/1989 - 02/01/1991
Potential Units Affected: 20800
Defect Description:
INSTRUCTION LABEL IN THE TRUNK OF VEHICLE IS INCORRECT FOR THE JACK SUPPLIED WITH THE VEHICLE.
Consequence:
INCORRECT USE CAN RESULT IN THE JACK COLLAPSING, WITHINJURY TO INDIVIDUALS UNDER OR NEAR VEHICLE DURING COLLAPSE.
Action:
SUPPLY INSERT TO OWNER'S MANUAL NOTING CORRECT USAGE, AS WELL AS A CORRECTED INSTRUCTION LABEL FOR THE TRUNK.
1990 AUDI 200
Defect Description:
Consequence:
IN THE EVENT OF FAILURE, THE VEHICLE'S DRIVE WHEELS COULDLOSE POWER. IN EXTREME CIRCUMSTANCES, THE FRONT WHEELS LOCK, CAUSING RAPIDDECELERATION RESULTING IN POSSIBLE LOSS OF VEHICLE CONTROL AND AN ACCIDENT.
Action:
1990 AUDI 200
Defect Description:
Consequence:
Action:
1990 AUDI 200
Defect Description:
Consequence:
Action:
1990 AUDI 200
Defect Description:
Consequence:
Action:
1990 AUDI 4000
Defect Description:
Consequence:
Action:
1990 AUDI 5000
Defect Description:
Consequence:
Action:
1990 AUDI 80
Defect Description:
Consequence:
Action:
1990 AUDI 80
Defect Description:
Consequence:
Action:
1990 AUDI 80
NHTSA Campaign ID: STEERING:COLUMN LOCKING:ANTI-THEFT DEVICE
Manufacture Dates: 09/01/1989 - 03/01/1990
Potential Units Affected: 6600
Defect Description:
IMPROPERLY MANUFACTURED STEERING LOCK BOLTS COULD BREAK IF DRIVER APPLIES EXCESSIVE FORCE TO A LOCKED STEERING WHEEL IN AN ATTEMPT TO DISENGAGE THE STEERING LOCK.
Consequence:
BOLT BREAKAGE WOULD CAUSE STEERING WHEEL TO REMAIN LOCKED EVEN AFTER THE DRIVER TURNS THE IGNITION KEY AND ATTEMPTS TO MOVE THE CAR; THIS TOTAL LOSS OF STEERING CONTROL COULD RESULT IN AN ACCIDENT.
Action:
REPLACE COMPLETE STEERING LOCK ASSEMBLY, INCLUDING A MODIFIED LOCK BOLT.
1990 AUDI 90
Defect Description:
Consequence:
Action:
1990 AUDI 90
Defect Description:
Consequence:
Action:
1990 AUDI 90
Defect Description:
Consequence:
Action:
1990 AUDI COUPE
Defect Description:
Consequence:
Action:
1990 AUDI QUATTRO
NHTSA Campaign ID: SEATS:FRONT ASSEMBLY:RECLINER
Manufacture Dates: 02/01/1989 - 09/01/1989
Potential Units Affected: 600
Defect Description:
A SECURING CLIP ON THE OUTSIDE OF HINGES OF THE LEFT AND RIGHT FRONT SEAT BACK MAY NOT BE PROPERLY SEATED DUE TO INTERFERENCE WITH SEAT COVERING MATERIAL.
Consequence:
AN IMPROPERLY SECURED CLIP COULD CAUSE THE SEAT BACKHINGE TO SEPARATE FROM ITS ANCHOR IN A REAR-END ACCIDENT AND COULD RESULT IN AN INJURY TO OCCUPANT(S).
Action:
REALIGN SEAT COVERING MATERIAL WHERE INTERFERENCE IS PRESENT.
1990 AUDI QUATTRO
Defect Description:
Consequence:
Action:
1990 AUDI S4
Defect Description:
Consequence:
Action:
1990 AUDI V8
Defect Description:
Consequence:
Action:
1990 AUDI V8
NHTSA Campaign ID: VEHICLE SPEED CONTROL
Manufacture Dates: 09/01/1989 - 09/01/1990
Potential Units Affected: 3100
Defect Description:
A BUSHING WHICH GUIDES THE CRUISE CONTROL ROD CAN, OVER TIME, DETERIORATE AND CAUSE THE CONTROL ROD TO BIND.
Consequence:
A BINDING CONTROL ROD CAN IMPEDE THE RETURN OF THE THROTTLE PLATE TO ITS FULL IDLE POSITION.
Action:
DEALERS WILL REPLACE THE CONTROL ROD BUSHING WITH AN IMPROVED VERSION.
1990 AUDI V8
Defect Description:
Consequence:
Action:
Old 01-06-2011, 09:36 PM
mksu19's Avatar
Service Bulletins for 1991 Audi
1991 AUDI 100
Bulletin Number: 20056243
HEADLIGHT AIMING, USING HELLA UNIVERSAL BEAMSETTER. *KB
1991 AUDI 100
1991 AUDI 200
1991 AUDI 4000
1991 AUDI 5000
1991 AUDI 80
1991 AUDI 90
1991 AUDI COUPE
1991 AUDI QUATTRO
Recalls for 1991 Audi
1991 AUDI 100
Defect Description:
Consequence:
Action:
1991 AUDI 100
Defect Description:
Consequence:
Action:
1991 AUDI 100
NHTSA Campaign ID: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC.
Manufacture Dates: 07/01/1990 - 03/31/1992
Potential Units Affected: 4300
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. AN ELECTROLYTIC CAPACITOR CONTAINED IN THE AMPLIFIER FOR EACH REAR SPEAKER COULD LEAK AN ELECTROLYTE, WHICH MAY IN TIME AND IN THE PRESENCE OF HUMIDITY, CAUSE AN UNWANTED CONDUCTIVE PATH.
Consequence:
THIS CONDITION COULD RESULT IN THE AMPLIFIER OVERHEATING AND A POTENTIAL FIRE RISK.
Action:
DEALERS WILL REPLACE THE AMPLIFIERS FOR THE REAR SPEAKER ASSEMBLIES. OWNER NOTIFICATION BEGAN JULY 10, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT AUDI AT 1-800-822-2834.
1991 AUDI 100
Defect Description:
Consequence:
Action:
1991 AUDI 200
Defect Description:
Consequence:
Action:
1991 AUDI 200
Defect Description:
Consequence:
Action:
1991 AUDI 200
Defect Description:
Consequence:
Action:
1991 AUDI 200
Defect Description:
Consequence:
Action:
1991 AUDI 4000
Defect Description:
Consequence:
Action:
1991 AUDI 5000
Defect Description:
Consequence:
Action:
1991 AUDI 80
Defect Description:
Consequence:
Action:
1991 AUDI 80
Defect Description:
Consequence:
Action:
1991 AUDI 90
Defect Description:
Consequence:
Action:
1991 AUDI 90
Defect Description:
Consequence:
Action:
1991 AUDI COUPE
Defect Description:
Consequence:
Action:
1991 AUDI S4
Defect Description:
Consequence:
Action:
1991 AUDI V8
Defect Description:
Consequence:
Action:
1991 AUDI V8
NHTSA Campaign ID:EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC.
Defect Description:
Consequence:
Action:
1991 AUDI V8
Defect Description:
Consequence:
Action:
1991 AUDI V8
Defect Description:
Consequence:
Action:
Old 01-06-2011, 09:38 PM
mksu19's Avatar
Service Bulletins for 1995 Audi
1995 AUDI 100
Bulletin Number: GRP46/9501
BRAKE PEDAL SQUEAK. *TW
Bulletin Number: TSB-44-08-14
AUDI: WHEEL BOLTS REQUIRE TORQUE ADJUSTMENT. TORQUE STICKS AND TORQUE EXTENSION BARS ARE NOT APPROVED BY AUDI OF AMERICA, INC. AND SHOULD NOT BE USED TO APPLY TORQUE TO WHEEL BOLTS. ALL AUDI MODELS INCLUDED. *PE
1995 AUDI 100
1995 AUDI 80
Bulletin Number: GRP24/9502
CODING THE ELECTRONIC CONTROL MODULE HAS CHANGED WITH THE INTRODUCTION OF LATEST MTOOR MANAGEMENT SYSTEM (MMS-311). *TW
Bulletin Number: GRP24/9504
CHANGE IN CODING OF ECM WITH THE INTRODUCTION OF THE LATEST MOTOR MANAGEMENT SYSTEM (MMS-311). *TW
1995 AUDI 90
Bulletin Number: 042804
SERVICE ACTION TO INSPECT LOWER CONTROL ARM SEALS. *TT
1995 AUDI A4
Bulletin Number: 9801C
VEHICLE EXHIBITS DELAYED 1-2 SHIFT UNDER PART LOAD AFTER A COLD START. *YC
Bulletin Number: GRP24/9501
CODING THE ELECTRONIC CONTROL MODULE HAS CHANGED WITH THE INTRODUCTION OF THE LATEST MOTOR MANAGEMNET SYSTEM (MMS-311). *TW
Bulletin Number: GRP37/9501
DELAYED 1-2 SHIFT ON COLD START WARM-UP. *TW
Bulletin Number: GRP57/9410
NEW SAFETY FEATURE FOR UNLOCKING VEHICLES FROM THE INTERIOR. *TW
Bulletin Number: GRP87/9501
CLIMATE CONTROL MALFUNCTIONS. *TW
Bulletin Number: GRP94/9501
FOG LIGHTS FUNCTION MODIFIED TO OPERATE ONLY WITH LOW BEAM HEADLIGHTS ON. *TW
1995 AUDI A6
1995 AUDI A8
1995 AUDI AUDI
Bulletin Number: 9711039701X
CONDITION WITH VEHICLES CONVERTIBLE TOP OPERATION IS SLOW OR INOPERATIVE. *YC
1995 AUDI CABRIOLET
1995 AUDI QUATTRO
1995 AUDI S4
Recalls for 1995 Audi
1995 AUDI 100
NHTSA Campaign ID: ELECTRICAL SYSTEM:IGNITION:SWITCH
Manufacture Dates: 01/01/1994 - 12/01/1995
Potential Units Affected: 24000
Defect Description:
DEFECTIVE IGNITION SWITCHES WERE IMPROPERLY MANUFACTURED AND CAN CAUSE SOME ELECTRICAL ACCESSORIES TO MALFUNCTION.
Consequence:
SOME ELECTRICAL ACCESSORIES, SUCH AS, TURN SIGNALS, WINDSHIELD WIPERS, LAMPS, POWER WIND0WS AND AIR CONDITIONERS CAN MALFUNCTION WHEN THE CAR IS STARTED.
Action:
DEALERS WILL REPLACE THE IGNITION SWITCH.
1995 AUDI 100
NHTSA Campaign ID: FUEL SYSTEM, GASOLINE:FUEL INJECTION SYSTEM
Manufacture Dates: 01/01/1992 - 07/31/1995
Potential Units Affected: 37200
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES EQUIPPED WITH V6 ENGINES. AN INTERNAL SEAL OF THE FUEL INJECTOR CAN MALFUNCTION, ALLOWING FUEL LEAKAGE IN THE ENGINE COMPARTMENT.
Consequence:
FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE CAN RESULT IN A FIRE.
Action:
DEALERS WILL REPLACE ALL FUEL INJECTORS.
1995 AUDI 90
Manufacture Dates: 07/01/1994 - 09/30/1996
Potential Units Affected: 39300
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. THE DISCHARGE OF STATIC ELECTRICITY UNDER LOW HUMIDITY CONDITIONS CAN ACTIVATE THE DRIVER SIDE AIR BAG WHEN THE DRIVER ENTERS OR EXITS THE VEHICLE AND FORMS AN ELECTRICAL CIRCUIT BY TOUCHING CERTAIN AREAS OF THE STEERING WHEEL.
Consequence:
ACTIVATION OF THE AIR BAG UNDER THESE CONDITIONS CAN CAUSE PERSONAL INJURY.
Action:
DEALERS WILL INSTALL A GROUND WIRE ON THE DRIVER SIDE AIR BAG.
1995 AUDI 90
Defect Description:
Consequence:
Action:
1995 AUDI 90
Defect Description:
Consequence:
Action:
1995 AUDI A4
Defect Description:
Consequence:
Action:
1995 AUDI A6
Defect Description:
Consequence:
Action:
1995 AUDI A6
Defect Description:
Consequence:
Action:
1995 AUDI A8
Defect Description:
Consequence:
Action:
1995 AUDI CABRIOLET
Defect Description:
Consequence:
Action:
1995 AUDI CABRIOLET
Defect Description:
Consequence:
Action:
1995 AUDI CABRIOLET
Defect Description:
Consequence:
Action:
1995 AUDI S4
Defect Description:
Consequence:
Action:
1995 AUDI S4
NHTSA Campaign ID: FUEL SYSTEM, GASOLINEELIVERY:HOSES, LINES/PIPING, AND FITTINGS
Manufacture Dates: 09/01/1991 - 08/31/1995
Potential Units Affected: 3000
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. A FUEL FEED LINE CONNECTING THE FUEL FILTER TO THE ENGINE CAN PREMATURELY AGE AND SHRINK THROUGH EXPOSURE TO HIGH UNDER HOOD TEMPERATURE CAUSED BY THE TURBOCHARGER.
Consequence:
THIS CAN RESULT IN FUEL SEEPAGE AT THE CONNECTION.
Action:
DEALERS WILL REPLACE THE ENTIRE FUEL FEED LINE FROM THE FUEL FILTER TO THE ENGINE WITH A FUEL LINE OF SHRINKAGE-PROOF MATERIAL.
1995 AUDI S6
Defect Description:
Consequence:
Action:
1995 AUDI S6
NHTSA Campaign ID:
Defect Description:
Consequence:
Action:
mksu19's Avatar
Service Bulletins for 1996 Audi
1996 AUDI 100
1996 AUDI 100
1996 AUDI 90
Bulletin Number: 092603
ZF VH RECALL OF THE ZF STEERING PUMP, SUPPLIED TO WD'S FOR REPLACEMENT OF THE AUDI A4 PASSAT P/N 8D0 145 156FX INSTEAD OF THE CORRECT ZF P/N 7691 955 276ZW. 2004 AUDI A4 ALSO INCLUDED. *TT
Bulletin Number: 11
THIS TECHNICAL REPAIR MANUAL CONTAINS THE ELECTRICAL WIRING DIAGRAMS, TROUBLESHOOTING AND COMPLENT LOCATIONS. *TT
Bulletin Number: 11242004
SERVICE ACTION JE CAMPAIGN-CHECK/REPLACE FRONT SUSPENSION LOWER CONTROL ARMS. AUDI HAS FOUND THAT IN RARE CASES, ONE OR BOTH FRONT SUSPENSION LOWER CONTROL ARMS ON AFFECTED VEHICLES CAN EXHIBIT WEAR, EVEN THOUGH THE DAMAGE TO THE RUBBER BO
Bulletin Number: 2012749-2
EXTERIOR LIGHTS, MOSITURE ACCUMULATION. *PE
Bulletin Number: 400101
SUBJECT REGARDING NOISY FRONT SUSPENSION. *JG
Bulletin Number: 8
SERVICE INFORMATION ON ELECTRICAL WIRING DIAGRAM. *TT
Bulletin Number: 970501975X
REPAIR MANUAL ON ELECTRICAL WIRING DIAGRAMS. *YC
Bulletin Number: 980174
REMOVING AND INSTALLING THE FRONT SEAT BACKREST PANEL. *YC
Bulletin Number: 9801I
INFORMATION ON SERVICING CLUTCH AND CLUTCH CONTROLS ON VEHICLES WITH FWD MANUAL TRANSMISSIONS. *TT
Bulletin Number: 9802
CLUNKING OR RATTLING NOISE FROM ONE OR BOTH SIDES OF FRONT SUSPENSION WHEN DRIVING OVER ROUGH ROADS. *YC
Bulletin Number: 980215
SUBJECT ON TORQUE SPECIFICATION CHANGE FOR VEHICLES WITH 1.8, 5 VALVE TURBO. *YC
Bulletin Number: 980264
INFORMATION ON AIRBAG LABEL FOR REPLACEMENT WINDSHIELD. *YC
Bulletin Number: 9804
VEHICLE EXHIBITING A WHINING / WHIRRING TYPE NOISE AT CERTAIN MPH RANGES. *TT
Bulletin Number: A9815
SUBJECT ON ELECTRICAL WIRING DIAGRAMS, TROUBLESHOOTING & COMPONENT LOCATIONS TECHNICAL BULLETIN NO. 8. *YC
Bulletin Number: JE
CHECK/REPLACE REPLACE FRONT SUSPENSION LOWER CONTROL ARMS. *TC
Bulletin Number: TSB-45-08-04
AUDI: ABS ACTIVATES DURING LIGHT BRAKE APPLICATION . CONTROL NOISES ARE HEARD FROM THE ABS UNIT AT LOW SPEED WITHOUT BRAKE APPLICATION. *PE
1996 AUDI A4
Bulletin Number: 01/9701
ABS LIGHT (K47) ON DUE TO BATTERY JUMPING/CHARGING. *TW
Bulletin Number: 0715
EXTERIOR LIGHTS, MOISTURE ACCUMULATION. *NJ
Bulletin Number: 980163
REPLACING DAMAGED CLIPS FOR FRONT BUMPER. *YC
Bulletin Number: GRP28/9502
THE MODEL LISTED ABOVE WILL BE EQUIPPED. WITH A NEW 'INTERIOR PROFILE' KEY AND LOCK SYSTEM.
Bulletin Number: TSB-94-07-15
AUDIO: EXTERIOR LIGHTS, MOISTURE ACCUMULATION. CONDENSATION IS VISIBLE ON THE INSIDE OF HEADLIGHTS, TAILLIGHTS, FOG LIGHTS, SIDE MARKER LIGHTS, FRONT TURN SIGNAL OR THIRD BRAKE LIGHT LENS. DAMP AIR SETTLES ON THE INSIDE OF A COLD LENS,
1996 AUDI A6
1996 AUDI A8
Bulletin Number: 9707299702D
EXPERIENCING FRICTION NOISE FROM FRONT/REAR DOOR SEALS. *YC
Bulletin Number: 9711259701T
CUSTOMER EXPRESSES CONCERNS ABOUT BRAKE SQUEAL. *YC
Bulletin Number: 9803
CONDITION WITH INSUFFICIENT VEHICLE GROUND AT GROUND LOCATION 43. *YC
Bulletin Number: A9802
SUGGESTED REPAIR TIMES REVISION REQUEST FORM. *TT
1996 AUDI AUDI
1996 AUDI CABRIOLET
1996 AUDI QUATTRO
1996 AUDI S4
Recalls for 1996 Audi
1996 AUDI 100
Defect Description:
Consequence:
Action:
1996 AUDI 90
Defect Description:
Consequence:
Action:
1996 AUDI 90
Defect Description:
Consequence:
Action:
1996 AUDI A4
Defect Description:
Consequence:
Action:
1996 AUDI A4
Manufacture Dates: 10/01/1995 - 08/31/1997
Potential Units Affected: 27900
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. THE PLASTIC IGNITION SWITCH HOUSING CAN FRACTURE AT THE RETURN SPRING ANCHOR POINT. FRACTURE OF THE HOUSING COULD CAUSE THE RETURN SPRING FORCE TO BE INSUFFICIENT FOR RETURNING THE IGNITION KEY TO THE RUNNING POSITION AFTER STARTING THE ENGINE.
Consequence:
THIS CONDITION CAUSES ELECTRICAL ACCESSORIES SUCH AS WINDSHIELD WIPERS AND HEADLIGHTS TO BECOME INOPERATIVE.
Action:
1996 AUDI A4
Manufacturer: VOLKSWAGEN OF AMERICA, INC
Potential Units Affected: 28594
Defect Description:
ON CERTAIN PASSENGER VEHICLES, AS A RESULT OF A PROBLEM IN THE PRODUCTION PROCESS OF THE IGNITION SWITCH, THE ANCHOR POINT OF THE SPRING MAY CRACK. THIS COULD POTENTIALLY CAUSE THE RETURN SPRING FORCE TO BE INSUFFICIENT FOR RETURNING THE IGNITION KEY TO THE RUNNING POSITION AFTER STARTING THE ENGINE.
Consequence:
THIS CONDITION CAUSES ELECTRICAL ACCESSORIES SUCH AS WINDSHIELD WIPERS AND HEADLIGHTS TO BECOME INOPERATIVE INCREASING THE RISK OF A CRASH.
Action:
DEALERS WILL INSTALL A NEW IGNITION SWITCH WITH AN OPTIMIZED ANCHOR POINT FREE OF CHARGE. THE RECALL BEGAN ON NOVEMBER 27, 2006. OWNERS MAY CONTACT AUDI AT 1-800-822-2834. NOTE: THIS RECALL SUPERSEDES THE REMEDY PROGRAM UNDER A PREVIOUS RECALL (PLEASE SEE 00V317).
1996 AUDI A4
NHTSA Campaign ID: COMMUNICATIONS:HORN ASSEMBLY
Manufacture Dates: 09/01/1995 - 01/01/1996
Potential Units Affected: 3700
Defect Description:
THE HORN CAN WORK ONLY INTERMITTENTLY DUE TO INSUFFICIENT ELECTRICAL GROUND CONTACT.
Consequence:
THIS CONDITION COULD PREVENT A DRIVER FROM SOUNDING A WARNING BY USING THE HORN INCREASING THE POTENTIAL FOR A VEHICLE ACCIDENT.
Action:
CORRECTIVE ACTION: DEALERS WILL INSTALL A GROUND CONTACT SPRING WHICH WILL ENHANCE THE ELECTRICAL GROUND CONNECTION.
1996 AUDI A6
Defect Description:
Consequence:
Action:
1996 AUDI A6
Defect Description:
Consequence:
Action:
1996 AUDI A8
Defect Description:
Consequence:
Action:
1996 AUDI A8
NHTSA Campaign ID: POWER TRAIN:AUTOMATIC TRANSMISSION
Manufacture Dates: 07/19/1995 - 08/14/2002
Potential Units Affected: 13900
Defect Description:
VOLKSWAGEN IS RECALLING 13,900 MY 1996-2003 AUDI A8 VEHICLES EQUIPPED WITH A 5-SPEED AUTOMATIC TRANSMISSION. THE LOCKING CABLE MAY MOVE OUT OF POSITION OVER TIME. WITH THE LOCKING CABLE OUT OF POSITION, THE SHIFTER CAN BE MOVED OUT OF THE "PARK" POSITION EVEN IF THE IGNITION KEY IS NOT IN THE IGNITION LOCK.
Consequence:
THIS COULD ALLOW THE VEHICLE TO ROLL, CAUSING A CRASH WITHOUT WARNING.
Action:
DEALERS WILL MODIFY THE AUTOMATIC TRANSMISSION LOCKING CABLE BY INSTALLING AN ADJUSTING PIECE THAT WILL SECURE THE LOCKING CABLE IN PLACE. THE RECALL BEGAN ON SEPTEMBER 12, 2008. OWNERS MAY CONTACT AUDI AT 1-800-822-2834.
1996 AUDI CABRIOLET
Defect Description:
Consequence:
Action:
1996 AUDI CABRIOLET
Defect Description:
Consequence:
Action:
1996 AUDI S4
Defect Description:
Consequence:
Action:
1996 AUDI S6
Defect Description:
Consequence:
Action:
Old 01-06-2011, 09:39 PM
mksu19's Avatar
Service Bulletins for 1997 Audi
1997 AUDI 100
1997 AUDI 100
1997 AUDI 90
1997 AUDI A3
Bulletin Number: 0401
ENGINE OIL SPECIFICATIONS, OIL CAPACITY, OIL FILTER. *TT THIS BULLETIN REPLACES BULLETIN 04-01 DATED JAN. 12, 2004. 2004 CABRIOLET, AUDI INCLUDED. *TT
THROTTLE VALVE CONTROL MODULE - J338-, WILL NOT ADAPT. *MJ
Bulletin Number: 0402
ENGINE OIL SPECIFICATIONS, OIL CAPACITY, OIL FILTER. TO INCLUDE AUDI 24 2006. *TT
Bulletin Number: 0403
VALVE COVER GASKET, INSTALLING SEALANT AT CRITICAL POINTS. *TT
LOW ENGINE OIL PRESSURE LIGHT IS ON. AUDI CABRIOLET 2004 INCLUDED. *TT
Bulletin Number: 0420
WARRANTY EXTENSION COVERING CERTAIN OIL SLUDGE RELATED REPAIRS. *TT
OIL SLUDGE - WARRANTY EXTENSION. SERVICE CIRCULAR - WARRANTY. *TT
Bulletin Number: 0431
REPAIRS OF OIL SLUDGE RELATED PROBLEMS. *TT
Bulletin Number: 0514
WARRANTY EXTENSION 1997-1999 MODEL YEAR. *TT
Bulletin Number: 0521
THE WARRANTY IS EXTENDED FOR SUBJECT VEHICLES TO 168,000 KM (105,000 MILES), REGARDLESS OF TIME IN SERVICE, FOR ENGINE DAMAGE RESULTING FROM A BROKEN TIMING BELT. *TT
Bulletin Number: 0604
OIL SLUDGE LIMITED WARRANTY EXTENSION. *KB
Bulletin Number: 11
Bulletin Number: 17 08 03
ENGINE OIL PRESSURE TOO LOW - ENGINE FLUSH. *NJ UPDATED 4/30/08. *NJ
Bulletin Number: 2012833
ENGINE OIL PRESSURE TOO LOW - ENGINE FLUSH. *KB
Bulletin Number: 9707299708D
VEHICLES WILL BE SHIPPED WITH A PAINT PROTECTION PRODUCT CALLED RAPGARD. *YC
TURBOCHARGER, FAILURE DUE TO LACK OF LUBRICATION. *YC
Bulletin Number: 9801B
TIGHTENING TORQUE FOR OIL DRAIN PLUG. *YC
Bulletin Number: 980298
EXPERIENCING KNOCKING/CREAKING NOISES FROM REAR AXLE. *YC
PROCEDURES ON INSTALLING TRANSMISSION SOUND DEADENING SHIELDS *TT
Bulletin Number: 9807
SUBJECT ON CENTRAL LOCKING SYSTEM, FUNCTION OPTIONS. *YC
Bulletin Number: JE
Bulletin Number: JK
CUSTOMER SATISFACTION CAMPAIGN JK TO INSPECT THE TIMING BELT ON VEHICLES WITH INTERNAL ENGINE DAMAGE RESULTING FROM A BROKEN TIMING BELT. *TT
1997 AUDI A4
1997 AUDI A6
Bulletin Number: 0001
INFORMATION ON REPLACING DAMAGE FASTENERS WHEN A CONDITION EXIST WHERE THE REAR LICENSE PLATE FASTENERS MAY BE BROKEN, LOOSE OR FALLEN BEHIND THE LICENSE PLATE HOLDER / LENS ASSEMBLY.
Bulletin Number: 9704159701D
CONDITIONS WITH REAR DOOR SUNSHADE PULL TAB. *YC
Bulletin Number: 9705159705X
SUBJECT ON PNEUMATIC RIVETING GUN 2002 FOR BODY REPAIR. *YC
Bulletin Number: 9705169707D
SUBJECT ON THREADED POP RIVETS. *YC
Bulletin Number: 9705299706B
INFORMATION ON VEHICLES BODY REPAIR MATERIAL. *YC
Bulletin Number: 9706189703F
CONDITIONS WITH REAR WINDOW SUNSHADE. *YC
Bulletin Number: 9707299703D
INSTALLATION AND REMOVAL OF FRONT FLOOR MATS. *YC
Bulletin Number: 9708199710A
THE GOODYEAR TIRE & RUBBER COMPANY HAS ESTABLISHED A TOLL-FREE OE SERVICE LINE TO ASSIST THE DEALER NETWORK REGARDING ANY GOODYEAR TIRE CONCERNS. *YC
Bulletin Number: 9708209701A
CONCERNS WITH CASSETTE TAPE PLAYER, SOUND OUTPUT LOW OR DISTORTED, TAPES MAY BE DESTROYED. *YC
Bulletin Number: 9711219708T
INFORMATION ON REPLACING THE REAR WINDOW SUNSHADE/MOTOR. *YC
Bulletin Number: 980169
INFORMATION ON REPLACING AIRBAG COMPONENTS AFTER AN ACCIDENT. *YC
Bulletin Number: 9801A
SUBJECT REGARDING CRANKSHAFT CENTER BOLT AND CAMSHAFT SPROCKER BOLT, CORRECTIONS. *YC
Bulletin Number: 9801D
INFORMATION ON FRONT AXLE COMPONENTS. *YC
Bulletin Number: 9801E
INFORMATION ON REAR AXLE COMPONENTS. *YC
Bulletin Number: 9801F
SUBJECT ON WHEELS AND TIRES. *YC
Bulletin Number: 9801G
SUBJECT ON ABS FRONT AXLE COMPONENTS. *YC
Bulletin Number: 9801H
SUBJECT ON POWER STEERING. *YC
SUBJECT ON DIAGNOSTIC TROUBLE CODES 00591 & 00592L. *YC
CONDITIONS WITH AUTOMATIC TRANSMISSION, DELAYED DOWNSHIFT ON VEHICLES WITH 4.2L AND 01L TRANSMISSION ON VEHICLES WITH 4.2L AND 01L TRANSMISSION ON VEHICLES WITH 4.2L AND 01L TRANSMISSION. *YC
Bulletin Number: 9803K
CUSTOMER REQUESTS DEACTIVATION OR REACTIVATION OF REAR SIDE AIRBAGS. *YC
Bulletin Number: 9809
Bulletin Number: 9903
INFORMATION ON DEACTIVATING / ACTIVATING THE REAR SIDE AIRBAGS. *TT
Bulletin Number: JE
1997 AUDI A8
Bulletin Number: 010101
SUBJECT REGARDING VAG 1687 DIAGNOSTIC TOOL, CHECKING INTAKE SYSTEM FOR LEAKS. *JG
1997 AUDI AUDI
1997 AUDI CABRIOLET
1997 AUDI QUATTRO
Recalls for 1997 Audi
1997 AUDI 90
Defect Description:
Consequence:
Action:
1997 AUDI A4
NHTSA Campaign ID: SERVICE BRAKES, HYDRAULIC:POWER ASSIST:VACUUM:HOSES, LINES/PIPING, AND FITTINGS
Manufacture Dates: 10/01/1997 - 02/28/1999
Potential Units Affected: 88121
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES EQUIPPED WITH AUTOMATIC TRANSMISSIONS. A CONTROL VALVE IN THE VACUUM HOSE CONNECTING THE BRAKE BOOSTER TO THE INTAKE MANIFOLD MAY NOT OPEN OR CLOSE FULLY AT TEMPERATURES BELOW -4 F UNDER CERTAIN DRIVING CONDITIONS.
Consequence:
THIS CONDITION COULD CAUSE INSUFFICIENT VACUUM TO BE PROVIDED TO THE BRAKE BOOSTER.
Action:
DEALERS WILL INSTALL A VACUUM BY-PASS SYSTEM INTO VEHICLES OPERATED IN THESE STATES WHICH IS DESIGNED TO PROVIDE SUFFICIENT VACUUM FOR FULL BRAKE ASSIST UNDER ALL WEATHER CONDITIONS.
1997 AUDI A4
Defect Description:
Consequence:
Action:
1997 AUDI A4
Defect Description:
Consequence:
Action:
1997 AUDI A4
NHTSA Campaign ID: SEAT BELTS:REAR
Manufacture Dates: 02/26/1997 - 02/28/1997
Potential Units Affected: 12
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. THE REAR SEAT BELT RETRACTORS MAY NOT LOCK PROPERLY WHEN ENGAGED, OR NOT REMAIN LOCKED AFTER BEING ENGAGED.
Consequence:
IN THE EVENT OF A CRASH, AN IMPROPERLY LOCKING SEAT BELT COULD CAUSE INJURY TO AN OCCUPANT.
Action:
DEALERS WILL REPLACE THE REAR SEAT BELT ASSEMBLY.
1997 AUDI A4
Defect Description:
Consequence:
Action:
1997 AUDI A6
Defect Description:
Consequence:
Action:
1997 AUDI A6
Defect Description:
Consequence:
Action:
1997 AUDI A8
Defect Description:
Consequence:
Action:
1997 AUDI A8
Defect Description:
Consequence:
Action:
1997 AUDI CABRIOLET
Defect Description:
Consequence:
Action:
Old 01-06-2011, 09:40 PM
mksu19's Avatar
Service Bulletins for 1998 Audi
1998 AUDI 100
1998 AUDI 100
1998 AUDI 90
1998 AUDI A3
VALVE COVER, DIAGNOSING OIL LEAKAGE FROM GASKETS. *TT
Bulletin Number: 0406
COOLANT LEAK AT OIL COOLER HOSES. *TT
Bulletin Number: 0408
LONG TERM FUEL TRIM - SYSTEM TOO RICH. DIAGNOSTIC TROUBLE CODE P1123, P1125, P1137 AND P1139. *TT
Bulletin Number: 11
Bulletin Number: 150101
A CONDITION MAY EXIST WHERE THE ENGINE MAY CRANK BUT WILL NOT START. *TT
Bulletin Number: 150102
A CONDITION MAY EXIST WHERE THE ENGINE CRANKS BUT WILL NOT START. *TT
Bulletin Number: 900102
SUBJECT REGARDING INSTRUMENT CLUSTER, DRIVER'S INFORMATION DISPLAY FADES. *JG
Bulletin Number: 900104
Bulletin Number: 9706249701F
SUBJECT ON CYLINDER HEAD REMOVAL AND INSTALLATION. *YC
SUBJECT ON LUGGAGE COVER HANDLE, REPLACING. *YC
SUBJECT ON FLOOR MAT FASTENER VARIATIONS. *YC
Bulletin Number: 980291
VEHICLES WITH CONCERT RADIO WITHOUT BOSE SOUND SYSTEM MAY EXHIBIT AN INOPERATIVE AND / OR DISTORTED REAR SPEAKER. *YC
EXPERIENCING CREAKING / POPPING NOISES FROM REAR WINDOW. *YC
Bulletin Number: 980591
INSTALLATION INSTRUCTIONS FOR CELLULAR TELEPHONE. *YC
Bulletin Number: 980698
SUBJECT ON AIRBAG SYSTEM ON BOARD DIAGNOSTIC (OBD) FOR VEHICLES WITH REAR SEAT BELT TENSIONERS. *YC
Bulletin Number: 9902
CONDITIONS WITH CREAKING NOISE FROM CENTER ARMREST ON VEHICLES VIN 8D_WA240851. *TT
Bulletin Number: A9810
SUBJECT ON THE AUDI A4 REPAIR MANUAL. *YC
Bulletin Number: JE
Bulletin Number: JK
1998 AUDI A4
Bulletin Number: 970398
INSTALLATION INSTRUCTIONS ON CELLULAR TELEPHONE. *YC
Bulletin Number: 980198
INCREASING DISTANCE RANGE FOR FOLDING KEY ( KEYLESS REMOTE TRANSMITTER ). *YC
Bulletin Number: 9801T
INFORMATION ON SERVICING SUNROOF. *YC
Bulletin Number: JE
1998 AUDI A4 AVANT
SUBJECT REGARDING AN INCORRECT FUEL READING ON FUEL GAUGE (ERRATIC, STUCK ON FULL OR EMPTY). *TT
Bulletin Number: 0002
REVISED INFORMATION FOR VEHICLES EXHIBITING AN INCORRECT FUEL GAUGE READING. *TT
THROTTLE BODY REPLACEMENT KIT INSTALLATION. *TC
Bulletin Number: 0404
Bulletin Number: 480501
POWER STEERING, NOISY. TO INCLUDE 2006 MODELS. *TT
Bulletin Number: 640001
A CONDITION MAY EXIST WHERE THE FRONT DOOR WINDOW(S) BIND OR DO NOT OPERATE WHEN OPENING OR CLOSING. *TT
Bulletin Number: 970298
CONDITION WITH WINDSHIELD WATER LEAK. *YC
SUBJECT ON OPEN CONDTION AT FUSE S14. *YC
Bulletin Number: 980269
DEACTIVATING AND ACTIVATING REAR SIDE AIRBAGS. *YC
Bulletin Number: 9802J
REPAIR MANUAL UPDATES / REVISIONS ON THE CAMSHAFT POSITION (CMP) SENSOR. *YC
Bulletin Number: 9803T
REVISIONS ON REPAIR MANUAL UPDATES. *YC
Bulletin Number: 980491
INSTALLATION INSTRUCTIONS ON CELLULAR TELEPHONE FOR VEHICLES WITHOUT INSULATED GLASS. *YC
Bulletin Number: 980598
SUBJECT PERTAINING TO AIRBAG SYSTEM WITH SIDE AIRBAGS. *YC
Bulletin Number: 9808
SUBJECT REGARDING CELLULAR TELEPHONE INSTALLATION INSTRUCTIONS FOR VEHICLES WITHOUT INSULATED GLASS AND / OR WITHOUT FENDER MOUNTED ANTENNA. *TT
A CONDITION MAY EXIST WHERE THE FRONT DOOR WINDOW(S) BINDS OR DOES NOT OPERATE WHEN OPENING OR CLOSING. *TT
Bulletin Number: A9806
SUBJECT ON ELECTRICAL WIRING DIAGRAMS, TROUBLESHOOTING & COMPONENT LOCATIONS TECHNICAL BULLETING NO. 3. *YC
Bulletin Number: A9813
SUBJECT REGARDING REPAIR MANUAL BOOKLET. *AK
Bulletin Number: JE
Bulletin Number: JE
BOTH FRONT SUSPENSION LOWER CONTROL ARMS CAN EXHIBIT WEAR, EVEN THOUGH THE DAMAGE TO THE RUBBER BOOTS IS NOT OBVIOUS. SERVICE ACTION CIRCULAR TO CHECK/REPLACE FRONT SUSPENSION LOWER CONTROL ARMS. *TT
Bulletin Number: LQ
SERVICE ACTION CAMPAIGN - INSTALLATION OF FRONT BUMPER GUIDES. *TT
1998 AUDI A6
1998 AUDI A6 AVANT
SUBJECT ON FOLDING KEY (KEYLESS REMOTE TRANSMITTER ), INCREASING DISTANCE RANGE. *YC
Bulletin Number: 9810
Bulletin Number: JE
1998 AUDI A8
1998 AUDI ALLROAD QUATTRO
SUBJECT REGARDING ENGINE, FLUCTUATING IDLE OR IDLE SPEED TOO LOW. *TT
Bulletin Number: 570101
A CONDITION MAY EXIST WHERE THE REMOTE TRANSMITTER(S) ARE PERMANENTLY OR INTERMITTENTLY INOPERATIVE. *TT
Bulletin Number: 910106
SUBJECT REGARDING RADIO CONNECTORS. *TT
INFORMATION CONTAINING POSSIBLE ERROR CODES FOR MODELS WITH PANASONIC CD CHANGERS. *TT
THIS BULLETIN PROVIDES A FLUID CAPACITY CHART FOR 1998 AND 1999 VEHICLES. *TT
1998 AUDI AUDI
1998 AUDI CABRIOLET
1998 AUDI QUATTRO
1998 AUDI S6
Recalls for 1998 Audi
1998 AUDI A4
Defect Description:
Consequence:
Action:
1998 AUDI A4
NHTSA Campaign ID: ENGINE AND ENGINE COOLING:COOLING SYSTEM
Manufacture Dates: 02/01/1997 - 02/28/1998
Potential Units Affected: 19800
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. IF THE ENGINE BACKFIRES DURING A COLD-START, AN AIR SCREEN WHICH IS LOOSELY SEATED IN THE AIR FLOW METER CAN BECOME DAMAGED.
Consequence:
SCREEN PIECES COULD ENTER THE INTAKE AIR FLOW SYSTEM AND PREVENT THE THROTTLE PLATE FROM RETURNING TO ITS FULL IDLE POSITION.
Action:
DEALERS WILL INSTALL A RETAINING RING TO HOLD THE AIR SCREEN IN PLACE.
1998 AUDI A4
NHTSA Campaign ID: STEERING:LINKAGES:ROD:RELAY:CONNECTING
Manufacture Dates: 01/02/1998 - 07/31/1998
Potential Units Affected: 51900
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. THE TIE RODS OF THE STEERING ASSEMBLY ARE PROTECTED ON EACH SIDE BY A SEAL TO PREVENT MOISTURE AND DUST PARTICLES FROM ENTERING THE SWIVEL BEARING MECHANISM. IT IS POSSIBLE THAT SOME TIE ROD SEALS MAY NOT SEAL PROPERLY.
Consequence:
IF MOISTURE AND/OR DUST PARTICLES ENTER THE SWIVEL BEARING MECHANISM, THE SWIVEL BEARING COULD WEAR OVER TIME DIMINISHING THE STEERING CONTROL OF THE VEHICLE.
Action:
DEALERS WILL REPLACE THE TIE RODS.
1998 AUDI A6
Defect Description:
Consequence:
Action:
1998 AUDI A6
NHTSA Campaign ID: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY
Manufacture Dates: 08/14/1997 - 11/15/2000
Potential Units Affected: 70000
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. SULFUR IN FUEL INTERACTS WITH CERTAIN ADDITIVES FOUND IN WIDELY AVAILABLE GASOLINE CAUSING SULFUR TO BECOME DEPOSITED ON THE CONTACT POINTS OF THREE FUEL SENDING UNITS MOUNTED INSIDE THE FUEL TANK. THIS COULD CAUSE THE FUEL GAUGE TO READ FULL WHILE THE FUEL TANK MAY NOT IN FACT BE FULL OR COULD BE EMPTY.
Consequence:
RUNNING OUT OF FUEL WITHOUT WARNING WHILE THE FUEL GAUGE INDICATES THAT THERE IS SUFFICIENT FUEL IN THE TANK LEAD TO SAFETY PROBLEMS.
Action:
DEALERS WILL REMOVE THE EXISTING FUEL LEVEL SENDING UNITS AND REPLACE THEM WITH FUEL LEVEL SENDING UNITS USING A NEW ALLOY COMPOSED OF GOLD, SILVER, AND A SMALL AMOUNT OF NICKEL, WHICH WILL NOT CHEMICALLY REACT WITH SULFUR. VW/AUDI WILL ALSO CALL BACK VEHICLES THAT WERE REPAIRED UNDER A PREVIOUS RECALL LAST JUNE IN ORDER TO INSTALL THE UPDATED FUEL SENDING UNITS NHTSA 00V137/AUDI LB). OWNER NOTIFICATION BEGAN MAY 1, 2001. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT AUDI AT 1-866-892-2834.
1998 AUDI A6
NHTSA Campaign ID: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
Manufacture Dates: 07/01/1997 - 07/31/1997
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. DURING PRE-ASSEMBLY OF THE FUEL TANKS, AN INCORRECT FILLER NECK WAS INSTALLED CAUSING THE FILLER NECK TO NOT "MATCH" THE FUEL CAP.
Consequence:
THIS CONDITION COULD ALLOW FUEL TO ESCAPE AND IF AN IGNITION SOURCE WAS PRESENT, A FIRE COULD OCCUR.
Action:
DEALERS WILL REPLACE THESE FILLER NECKS.
1998 AUDI A6
Manufacture Dates: 08/14/1997 - 02/12/2004
Potential Units Affected: 172866
Defect Description:
ON CERTAIN PASSENGER VEHICLES, IF A DRIVER'S KNEES PUSH AGAINST THE KNEE BOLSTER (CRASH ELEMENT) LOCATED UNDER THE DASHBOARD, IT CAN CONTACT THE HEADLIGHT SWITCH WIRING HARNESS, AND AN ELECTRICAL SHORT COULD OCCUR.
Consequence:
A FIRE COULD ORIGINATE IN THE LEFT DASHBOARD AREA.
Action:
DEALERS WILL INSTALL A PROTECTIVE COVERING ON THE KNEE BOLSTER (CRASH ELEMENT). IN ADDITION, THE WIRING HARNESS AS WELL AS THE FELT PROTECTOR ON THE LEFT SIDE OF THE DASHBOARD CARRIER WILL BE CHECKED, AND REPLACED IF NECESSARY. THE RECALL BEGAN ON JULY 26, 2004. OWNERS SHOULD CONTACT AUDI AT 1-800-822-2834.
1998 AUDI A6
Defect Description:
Consequence:
Action:
1998 AUDI A6
Manufacture Dates: 11/01/1997 - 03/22/1999
Potential Units Affected: 27964
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES EQUIPPED WITH QUATTRO DRIVE SYSTEM WHICH EMPLOYS A FUEL AND FUEL VAPOR LEAK DETECTION SYSTEM. IF THE VEHICLE IS REFUELED SHORTLY AFTER THE ENGINE IS STARTED, AND IS KEPT RUNNING WHILE BEING REFUELED, THE FUEL VAPOR RECOVERY SYSTEM COULD PRODUCE SUFFICIENT BACK PRESSURE TO CAUSE FUEL TO BE EJECTED AFTER A COMPLETE FILL-UP WHEN THE FUEL PUMP NOZZLE IS REMOVED FROM THE FILLER NECK.
Consequence:
IN THE PRESENCE OF AN IGNITION SOURCE, FUEL SPRAY COULD RESULT IN FIRE OR POSSIBLE PERSONAL INJURY.
Action:
VW IS PROVIDING A NEW PAGE FOR THE OWNER'S MANUAL AND ALSO REQUESTING OWNERS TO MAKE AN APPOINTMENT WITH THEIR DEALERS TO HAVE A LABEL CONTAINING IMPORTANT REFUELING INSTRUCTIONS INSTALLED INSIDE OF THE FUEL FILLER DOOR. DEALERS WILL ALSO REMOVE THE TIRE PRESSURE LABEL AND REPLACE IT WITH A NEW LABEL AFFIXED TO THE FENDER WELL AT THE RIGHT REAR DOOR.
1998 AUDI A6
Manufacture Dates: 08/01/1997 - 07/31/1999
Potential Units Affected: 28300
Defect Description:
ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH 2.8L, V6 5-VALVE ENGINES, AND AUTOMATIC TRANSMISSIONS, WHILE DRIVING DURING EXTREMELY LOW AMBIENT TEMPERATURES THE THROTTLE MAY FREEZE IN AN OPEN POSITION DUE TO ICE ACCUMULATING IN THE THROTTLE BODY.
Consequence:
IF THIS OCCURS, THE VEHICLE MAY FAIL TO REDUCE SPEED WHEN THE DRIVER LIFTS HIS/HER FOOT FROM THE GAS PEDAL. THIS LOSS OF VEHICLE CONTROL COULD RESULT IN A CRASH WITHOUT WARNING.
Action:
AUDI WILL INSTALL A REPLACEMENT THROTTLE BODY KIT FREE OF CHARGE. THE RECALL BEGAN ON OCTOBER 29, 2004. OWNERS MAY CONTACT AUDI AT 1-800-822-2834. OWNERS OF VEHICLES WHICH ARE NOT REGISTERED IN THE COLD-WEATHER STATES OF ALASKA, COLORADO, CONNECTICUT, DELAWARE, IDAHO, ILLINOIS, INDIANA, IOWA, MAINE, MARYLAND, MASSACHUSETTS, MICHIGAN, MINNESOTA, MONTANA, NEBRASKA, NEVADA, NEW HAMPSHIRE, NEW JERSEY, NEW YORK, NORTH DAKOTA, OHIO, OREGON, PENNSYLVANIA, RHODE ISLAND, SOUTH DAKOTA, VERMONT, WASHINGTON, WISCONSIN, AND WYOMING, WILL BE NOTIFIED OF A SERVICE ACTION, UNDER WHICH THEY WILL BE PROVIDED THE FREE REMEDY UPON REQUEST.
1998 AUDI A6
Defect Description:
Consequence:
Action:
1998 AUDI A6
Manufacture Dates: 08/01/1997 - 05/31/2000
Potential Units Affected: 70512
Defect Description:
ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH HALOGEN LOW BEAM HEADLIGHTS, CERTAIN CONNECTOR PINS IN THE HEADLIGHT SWITCH CONNECTOR COME INTO CONTACT WITH EACH OTHER CAUSING A SHORT CIRCUIT. NOTE: VEHICLES WITH XENON LOW BEAM HEADLIGHTS ARE NOT AFFECTED BECAUSE THE CIRCUIT IN THESE VEHICLES CONTAINS A FUSE, WHICH PRECLUDES EXCESSIVE CURRENT FLOW IN THE CASE OF A SHORT CIRCUIT. AUDI S6 AND S6 AVANT VEHICLES ARE ALL EQUIPPED WITH XENON LOW BEAM HEADLIGHTS AND, THEREFORE, ARE NOT LONGER AFFECTED BY THIS RECALL.
Consequence:
THIS CONDITION COULD LEAD TO OVERHEATING OR FIRE.
Action:
DEALERS WILL REROUTE THE WIRING HARNESS BY INSTALLING A JUMPER WIRING HARNESS. THE RECALL BEGAN ON DECEMBER 16, 2006. OWNERS MAY CONTACT AUDI AT 1-800-822-2834.
1998 AUDI A6 AVANT
Defect Description:
Consequence:
Action:
1998 AUDI A8
Defect Description:
Consequence:
Action:
1998 AUDI A8
Defect Description:
Consequence:
Action:
1998 AUDI S6
Defect Description:
Consequence:
Action:
Old 01-06-2011, 09:41 PM
mksu19's Avatar
Service Bulletins for 1999 Audi
1999 AUDI 90
1999 AUDI 90
1999 AUDI A3
Bulletin Number: 11
Bulletin Number: 9904
VEHICLES MAY EXPERIENCE WIND NOISE HEARD FROM THE EXTERIOR REARVIEW MIRROR. *TT
Bulletin Number: JE
Bulletin Number: JK
1999 AUDI A4
Bulletin Number: JE
1999 AUDI A4 AVANT
Bulletin Number: 980898
INSTALLATION INSTRUCTIONS ON CELLULAR TELEPHONES. *YC
Bulletin Number: JE
Bulletin Number: JE
Bulletin Number: LQ
1999 AUDI A6
Bulletin Number: JE
1999 AUDI A6 AVANT
Bulletin Number: JE
Bulletin Number: LT
EMISSION RECALL LT. THE FUEL SENDING UNIT HOUSING COULD BECOME DISTORTED UNDER CERTAIN CLIMATIC CONDITIONS. SHOULD THIS HAPPEN, FUEL VAPORS COULD ESCAPE INTO THE ATMOSPHERE. A VAPOR LEAK ALSO ILLUMINATES THE VEHICLE'S DASHBOARD MALFUNCTI
1999 AUDI A8
1999 AUDI ALLROAD QUATTRO
Bulletin Number: 0004
ON ALL MODELS EXCEPT CABRIOLET AND TT, THE HEATED EXTERIOR REAR-VIEW MIRROR ELEMENT APPEARS TO BE INOPERATIVE. *TT
1999 AUDI AUDI
1999 AUDI CABRIOLET
1999 AUDI QUATTRO
1999 AUDI S6
1999 AUDI S6 AVANT
Recalls for 1999 Audi
1999 AUDI A4
Defect Description:
Consequence:
Action:
1999 AUDI A4
Defect Description:
Consequence:
Action:
1999 AUDI A4
Manufacture Dates: 08/01/1998 - 04/30/1999
Potential Units Affected: 83000
Defect Description:
Consequence:
Action:
1999 AUDI A6
Defect Description:
Consequence:
Action:
1999 AUDI A6
Defect Description:
Consequence:
Action:
1999 AUDI A6
Defect Description:
Consequence:
Action:
1999 AUDI A6
Defect Description:
Consequence:
Action:
1999 AUDI A6
Defect Description:
Consequence:
Action:
1999 AUDI A6
Defect Description:
Consequence:
Action:
1999 AUDI A6
Defect Description:
Consequence:
Action:
1999 AUDI A6
Defect Description:
Consequence:
Action:
1999 AUDI A6 AVANT
Defect Description:
Consequence:
Action:
1999 AUDI A8
Defect Description:
Consequence:
Action:
1999 AUDI A8
Defect Description:
Consequence:
Action:
1999 AUDI A8
Defect Description:
Consequence:
Action:
1999 AUDI S6
Defect Description:
Consequence:
Action:
mksu19's Avatar
Service Bulletins for 2000 Audi
2000 AUDI 90
Bulletin Number: 20036582
LOSES POWER OR WILL NOT MOVE AFTER STOP. *KB
2000 AUDI 90
2000 AUDI A3
2000 AUDI A3 QUATTRO
Bulletin Number: 0502
UPDATE PROGRAMMING FOR CATALYTIC CONVERTER SYSTEM (IC). *TT UPDATE. *TT
Bulletin Number: 0504
THREE WAY CATALYST, CATALYTIC EFFICIENCY DIAGNOSTIC TROUBLE CODES (DTCS) STORED IN DTC MEMORY. *TT
Bulletin Number: 101508
AUDI: CSC LETTER WAS RECEIVED FOR AUDI MODEL YEARS 2000-2003 A4 AND TT. REVISED MAINTENANCE INSTRUCTIONS AND A WARRANTY EXTENSION COVERING CERTAIN TIMING BELT TENSIONER SYSTEM RELATED REPAIRS. *PE
Bulletin Number: 11
Bulletin Number: 15-D-4-JZ
AUDI: THE INTERNAL ENGINE DAMAGE RESULTING FROM A BROKEN TIMING BELT. IF THE TIMING BELT OF VEHICLE WERE TO BREAK, THE ENGINE WILL NOT RUN AND MAY SUSTAIN SERIOUS INTERNAL DAMAGE. *PE
Bulletin Number: 15D4/JZ
AUDI: INTERNAL ENGINE DAMAGE RESULTING FROM A BROKEN TIMING BELT. IF TIMING BELT OF VEHICLE WERE TO BREAK, THE ENGINE WILL NOT RUN AND MAY SUSTAIN SERIOUS INTERNAL DAMAGE. CSC LETTER WAS RECEIVED. *PE
Bulletin Number: JE
2000 AUDI A4
Bulletin Number: JE
2000 AUDI A4 AVANT
Bulletin Number: 010002
CONCERNS WITH THE VEHICLE IN A LIMP MODE, TRANSMISSION WILL NOT SHIFT GEARS, DIAGNOSTIC TROUBLE CODE 17114 STORED IN DIAGNOSTIC TROUBLE CODE MEMORY ON VEHICLES FROM VIN 4B_YN019790 TO VIN 4B_YN078064. *TT
OIL LEAK IN AREA OF TURBOCHARGER. *MJ
MALFUNCTION INDICATOR LIGHT ON WITH DTC (DIAGNOSTIC TROUBLE CODE) P0422 AND/ OR P0432 STORED IN DTC MEMORY . *TC
OIL LEAKS FROM UPPER ENGINE AREAS, DIAGNOSTIC GUIDELINES. *TT
Bulletin Number: 0501
SECONDARY AIR INJECTION (AIR) PUMP MOTOR -V101- IS NOISY. *TT
UNNECESSARY ECM AND/OR ACCELERATOR PEDAL REPLACEMENT. *TT
Bulletin Number: 550101
SUBJECT REGARDING REAR LID, LUBRICATING HINGES TO ALLEVIATE STIFFNESS. *JG
INFORMATION USED IF A CUSTOMER REQUESTS DEACTIVATION OF THE REAR SIDE AIRBAGS. *TT
Bulletin Number: JE
Bulletin Number: JE
Bulletin Number: LQ
2000 AUDI A6
2000 AUDI A6 AVANT
Bulletin Number: 260702
MIL ON (DTC'S P0300, P0411, P1128, P1130, P1411, P1423). THIS COULD BE CAUSED BY A CRACKED OR BROKEN VACUUM HOSE. *KB
A CONDITION MAY EXIST WHEN LOCKING VEHICLE WITH KEY OR BY REMOTE TRANSMITTER, THE TURN SIGNAL LIGHTS FLASH BUT ALARM HORN DOES NOT SOUND. *TT
Bulletin Number: JE
Bulletin Number: LT
2000 AUDI A8
2000 AUDI ALLROAD QUATTRO
Bulletin Number: 000001
SUBJECT REGARDING AIRBAG WARNING LABELS, COMPLIANCE WITH FEDERAL MOTOR VEHICLE SAFETY STANDARD 208. *TT
THIS BULLETIN CONTAINS REPAIR PROCEDURES FOR THE AIRBAG WIRING HARNESS. *TT
SUBJECT REGARDING THE AIRBAG WARNING LABEL, COMPLIANCE WITH CANADIAN MOTOR VEHICLE SAFETY STANDARD 208. *TT
Bulletin Number: 640002
SUBJECT REGARDING STRESS CRACK / DISTORTION SURVEY OF THE WINDSHIELD ON 2000 AND 2001 MODEL YEAR VEHICLES. *TT
Bulletin Number: 910104
A CONDITION MAY EXIST WHERE THE NAVIGATION SYSTEM DISPLAYS INCORRECT DISTANCE READINGS. *TT
Bulletin Number: 9901
RUST BUILD-UP ON ROTOR SURFACES CAUSING STEERING WHEEL SHIMMY DURING BRAKING ON VEHICLES WITH HP-2 BRAKES. *TT
2000 AUDI AUDI
FUEL INJECTORS, UNNECESSARY REPLACEMENT. UPDATE. *TT
2000 AUDI CABRIOLET
Bulletin Number: 0308
MALFUNCTION INDICATOR LIGHT ON, DIAGNOSTIC TROUBLE CODES (DTC) P0300, P0411, P1128, P1411, P1423 STORED IN DTC MEMORY. A8, S8, A6 QUATTROS. *TT
2000 AUDI QUATTRO
2000 AUDI S3 QUATTRO
INFORMATION ON INSTALLING FRONT LICENSE PLATE HOLDER PRIOR TO DELIVERY (FOR STATES, PROVINCES AND TERRITORIES REQUIRING A FRONT LICENSE PLATE). *TT
Bulletin Number: 0006
SUBJECT REGARDING INSTALLATION OF FRONT LICENSE PLATE HOLDER. *TT
Bulletin Number: 131000
OWNER NOTIFICATION LETTERS REGARDING AUDI TT AND S4 LOW PROFILE TIRES. *TT
Bulletin Number: 151100
THIS LETTER ADDRESSES DEFECT ALLEGATIONS MADE IN THE SEPTEMBER 25TH ISSUE OF BUSINESS WEEK WITH RESPECT TO THE BRIDGESTONE RE040 LOW ASPECT RATIO, ULTRA HIGH PERFORMANCE TIRES. *TT
Bulletin Number: 171100
THIS SAMPLE LETTER PROVIDES INFORMATION ON THE SPECIALLY DESIGNED LOW ASPECT RATIO, ULTRA HIGH PERFORMANCE TIRES. *TT
Bulletin Number: AWA0011
SUBJECT REGARDING AUDI OF AMERICA, INC. CUSTOMER SATISFACTION PROGRAM FOR CERTAIN VEHICLES EQUIPPED WITH 225 / 45R17 / 91Y LOW ASPECT RATIO, ULTRA HIGH PERFORMANCE TIRES. *TT
Bulletin Number: JE
2000 AUDI S4
2000 AUDI S6
2000 AUDI S6 AVANT
EXPERIENCING GROANING OR HOWLING NOISE FROM ENGINE COMPARTMENT WHEN ACCELERATING DURING PARTIAL LOAD BETWEEN 2500 - 3000 RPM AND / OR NOISY CHARGE PRESSURE BYPASS VALVE WHEN DECELERATING BETWEEN 2000 - 3000 RPM. *TT
SUBJECT REGARDING WHEEL ALIGNMENT SPECIFICATION CHANGES, HUNTER WHEEL ALIGNMENT PROGRAM. *TT
Bulletin Number: 0005
INFORMATION REGARDING INSTALLATION OF FRONT LICENSE PLATE HOLDER. *TT
Bulletin Number: 0007
SUBJECT REGARDING CD CHANGER INSTALLATION INSTRUCTIONS. *TT
Bulletin Number: 480101
SUBJECT REGARDING REPLACEMENT OF COIL CONNECTOR WITH SLIP RING (SPRIAL SPRING), REMOVING ADDITONAL WIRING. *TT
Bulletin Number: 500001
VEHICLES WITHIN VIN 8N_Y1015425 MAY EXHIBIT SILL PANEL UNDERCOATING OR BODY DAMAGE DUE TO CONTACT WITH HOIST LIFT ARMS OR FLOOR JACKS. *TT
INFORMATION ON LOCATING THE TELEPHONE ANTENNA MAST ON COUPE MODEL VEHICLES AT PRE-DELIVERY INSPECTION. *TT
INFORMATION ON THE PASSENGER-SIDE FRONT AIRBAG, ACTIVATING / DEACTIVATING ON COUPE MODEL VEHICLES. *TT
Bulletin Number: A9907
SUBJECT CONTAINS NEW AND REVISED WIRING DIAGRAM INFORMATION. *TT
Bulletin Number: ALS0015
THIS SERVICE CIRCULAR MENTIONS THAT THE TECHNICAL BULLETIN FOR YOUR AUDI TT 2000 - ELECTRICAL WIRING DIAGRAMS, TROUBLESHOOTING AND COMPONENT LOCATIONS MANUAL WILL BE COMING SOON. *TT
Bulletin Number: ALS0116
THIS SERVICE CIRCULAR STATES THAT THE TECHNICAL BULLETIN NO. 8 FOR THE AUDI TT 2000 ELECTRICAL WIRING DIAGRAMS, TROUBLESHOOTING AND COMPONENT LOCATIONS MANUAL WILL BE COMING SOON. *TT
SUBJECT REGARDING AFTERMARKET INSTALLATION OF ESP (ELECTRONIC STABILIZATION PROGRAM). *TT
2000 AUDI TT
Bulletin Number: 0003
INFORMATION ON REMOVING THE REAR LID SPOILER. *TT
Bulletin Number: 0009
A CONDITION MAY EXIST WHERE THE NAVIGATION SYSTEM INSTRUCTS THE DRIVER TO TURN APPOX. TWO HUNDRED FEET BEFORE OR AFTER THE DESIGNATED INTERSECTION. *TT
Bulletin Number: AWA-08-05
LIMITED WARRANTY EXTENSION ON ORIGINAL INSTRUMENT CLUSTERS FOR 2000-2005 AUDI TT VEHICLES. *PE
AUDI: LIMITED NEW VEHICLE WARRANTY FOR ORIGINAL EQUIPMENT MANUFACTURER INSTRUMENT CLUSTERS FOR 2000-2005 MODEL YEAR TT VEHICLES UP TO AND INCLUDING VIN TRU_8N_51017389 IS EXTENDED TO SIX (6) YEARS FROM THE VEHICLE'S ORIGINAL IN SERVICE DA
2000 AUDI TT COUPE
2000 AUDI TT QUATTRO
Recalls for 2000 Audi
2000 AUDI A6
Defect Description:
Consequence:
Action:
2000 AUDI A6
Defect Description:
Consequence:
Action:
2000 AUDI A6
Defect Description:
Consequence:
Action:
2000 AUDI A6 AVANT
Defect Description:
Consequence:
Action:
2000 AUDI A8
Defect Description:
Consequence:
Action:
2000 AUDI A8
Manufacture Dates: 02/01/2000 - 07/31/2000
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES EQUIPPED WITH A FUEL AND VAPOR LEAK DETECTION SYSTEM. A "BLIND COVER" AT THE FILLER NECK OF THE FUEL TANK MAY NOT SEAL PROPERLY ALLOWING FUEL VAPOR TO ESCAPE.
Consequence:
SHOULD THIS HAPPEN, THE FUEL TANK PRESSURE WILL BE REDUCED, WHICH WILL ACTIVATE THE LEAK DETECTION SYSTEM AND ALERT THE DRIVER OF A SYSTEM'S FAULT INDICATED BY AN INSTRUMENT PANEL LIGHT.
Action:
DEALERS WILL REPLACE THE FUEL FILLER NECK/EXPANSION TANK ASSEMBLY. OWNER NOTIFICATION BEGAN MARCH 21, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT AUDI AT 1-866-892-2834.
2000 AUDI S6
Defect Description:
Consequence:
Action:
2000 AUDI TT
NHTSA Campaign ID: SUSPENSION:FRONT:CONTROL ARM:LOWER ARM
Manufacture Dates: 04/30/1999 - 12/14/1999
Potential Units Affected: 6200
Defect Description:
PASSENGER VEHICLES. IN SHARP HIGH SPEED TURNS OR ABRUPT LANE CHANGE MANEUVERS AT SPEEDS SUBSTANTIALLY ABOVE POSTED SPEED LIMITS, AND DEPENDING UPON ROAD CONDITIONS, PRECISE STEERING RESPONSE MAY BE DEMANDED TO RETAIN DIRECTIONAL STABILITY.
Consequence:
IN THE EVENT CONTROL IS LOST, A CRASH MAY OCCUR RESULTING IN INJURY.
Action:
DEALERS WILL REPLACE THE FRONT STABILIZERS IN FRONT DRIVE AUDI TT'S AND THE FRONT AND REAR STABILIZERS IN AUDI TT'S EQUIPPED WITH QUATTRO DRIVE. A MODIFIED CONTROL ARM WILL BE INSTALLED IN FRONT TOGETHER WITH FIRMER SHOCK ABSORBERS IN FRONT AND REAR. IN ADDITION AUDI WILL INSTALL A REAR SPOILER.
2000 AUDI TT
Manufacture Dates: 03/01/1999 - 05/31/1999
Potential Units Affected: 52
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. A SMALL SECTION OF THE VEHICLE FUEL LINE ASSEMBLY MAY HAVE BEEN DAMAGED DURING PRODUCTION. IF DAMAGED, FUEL COULD LEAK TO THE OUTSIDE.
Consequence:
IN THE PRESENCE OF AN IGNITION SOURCE, CAUSE A FIRE.
Action:
DEALERS WILL REPLACE THE FUEL LINE ASSEMBLY.
NHTSA Campaign ID: SUSPENSION:REAR
Manufacture Dates: 09/01/1998 - 03/31/2000
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. MOISTURE COULD ENTER THE REAR TRACK CONTROL ARM'S MOUNTING BUSHING AND BOLT COMBINATION AND CAUSE CORROSION.
Consequence:
CORROSION COULD IMPEDE THE FREE MOVEMENT OF THE CONTROL ARM.
Action:
DEALERS WILL REPLACE THE TRACK CONTROL ARMS. OWNER NOTIFICATION BEGAN APRIL 12, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT AUDI AT 1-800-822-2834.
Old 01-06-2011, 09:42 PM
mksu19's Avatar
Service Bulletins for 2001 Audi
2001 AUDI 100
Bulletin Number: SA-28F2 J1
AUDI: (REVISED) VEHICLES AFFECTED BY THIS ACTION MAY HAVE IGNITION COILS THAT COULD MALFUNCTION UNDER CERTAIN CONDITIONS. IF THIS HAPPENS, THE MALFUNCTION INDICATOR LAMP (MIL) WILL ILLUMINATE TO LET YOU KNOW THAT THE VEHICLE MAY EXPERIENCE
2001 AUDI 100
2001 AUDI A3
2001 AUDI A3 QUATTRO
Bulletin Number: 09012006
IGNITION COILS MAY FAIL CAUSING A ROUGH IDLE OR REDUCED DRIVING POWER COULD OCCUR. *KB
Bulletin Number: 190504
THE COOLANT RESERVOIR IS DIAGNOSED TO BE LEAKING AND INTENDED TO BE REPLACED. *TT
Bulletin Number: AWA-08-03
ENGINE COOLANT TEMPERATURE SENSOR WARRANTY EXTENSION FOR CERTAIN 2001-2004 AUDI MODEL YEAR VEHICLES. CSC WAS RECEIVED *PE
Bulletin Number: AWA-08-04
ENGINE COOLANT TEMPERATURE SENSOR WARRANTY EXTENSION FOR CERTAIN 2001-2004 MODEL YEAR AUDI VEHICLES. *PE
2001 AUDI A4
2001 AUDI A4 AVANT
Bulletin Number: 0102
CUSTOMER STATES TIRES ARE NOISY, EXHIBITING A SAW-TOOTH PATTERN. *JG
SUBJECT REGARDING TIRES, ELIMINATING NOISE. *JG
UDPATE PROGRAMMING (FLASHING) ENGINE CONTROL MODULE (ECM) TO CORRECT COLD START ENGINE STUMBLE. *TT
Bulletin Number: 0421
EMISSION WARRANTY EXTENSION FOR OXYGEN SENSOR. *TT
Bulletin Number: 0526
AUTHORIZATION REQUIREMENTS FOR AUTOMATIC TRANSMISSIONS. *TT
Bulletin Number: 320501
MIL ILLUMINATED, DTC 17125 STORED IN TRANSMISSION FAULT MEMORY-NO DRIVEABILITY CONCERN. TORQUE CONVERTER CLUTCH CIRCUIT PERFORMANCE OR STUCK OFF STORED IN TRANSMISSION FAULT MEMORY. *SC
Bulletin Number: 5
REPAIR MANUAL TECHNICAL BULLETIN BINDER CONTAINING ELECTRICAL WIRING DIAGRAMS, TROUBLESHOOTING AND COMPONENT LOCATIONS (EDITION 06.00). *TT
Bulletin Number: ALS0101
INFORMATION REGARDING THE ELECTRICAL WIRING DIAGRAMS, TROUBLESHOOTING AND COMPONENT LOCATIONS MANUAL. *TT
Bulletin Number: LQ
2001 AUDI A6
2001 AUDI A6 AVANT
Bulletin Number: 2
THIS TECHNICAL BULLETIN SUPPLEMENTS AND UPDATES PREVIOUSLY PUBLISHED WIRING DIAGRAM, TROUBLESHOOTING AND COMPONENT LOCATION INFORMATION. *TT
Bulletin Number: 3
INFORMATION IN THIS TECHNICAL BULLETIN SUPPLEMENTS AND UPDATES PREVIOUSLY PUBLISHED WIRING DIAGRAM, TROUBLESHOOTING AND COMPONENT LOCATION INFORMATION. *TT
Bulletin Number: ALS0010
THIS SERVICE CIRCULAR CONTAINS ELECTRICAL WIRING DIAGRAMS, TROUBLESHOOTING AND COMPONENT LOCATIONS TECHNICAL BULLETIN NO. 2. *TT
Bulletin Number: ALS0103
THIS BULLETIN CONTAINS REVISED WIRING DIAGRAMS. *TT
Bulletin Number: ALS0123
SUBJECT REGARDING ELECTRICAL WIRING DIAGRAMS, TROUBLESHOOTING AND COMPONENT LOCATIONS BINDER. *JG
Bulletin Number: LT
2001 AUDI A8
ELECTRIC STABILITY PROGRAM PREMATURE INTERVENTION. *TC
2001 AUDI ALLROAD QUATTRO
Bulletin Number: 0301
IGNITION COIL, MISFIRE DIAGNOSIS. MALFUNCTION INDICATOR LIGHT ON/FLASHING; ENGINE RUNNING ROUGH; LOSS OF POWER; DIAGNOSTIC TROUBLE CODES P0300, P0301, P0302, P0303, P0304, P0305 OR P0306 STORED. *TT
Bulletin Number: 430101
A CONDITION MAY EXIST WHERE THE INDICATOR LAMP FOR THE SUSPENSION LEVEL CONTROL SYSTEM IS ON AND / OR THE SELF-LEVELING SUSPENSION IS INOPERATIVE. *TT
2001 AUDI AUDI
2001 AUDI CABRIOLET
2001 AUDI MPV
INFORMATION ON VEHICLES PAINTED WITH A MATTE, SCRATCH-RESISTANT FINISH. *TT
Bulletin Number: 010203
SUBJECT REGARDING MALFUNCTION INDICATOR LIGHT (MIL) ON, DIAGNOSTIC TROUBLE CODES P0421 OR P0431 STORED IN MEMORY. *TT
2001 AUDI QUATTRO
2001 AUDI S3 QUATTRO
2001 AUDI S4
2001 AUDI S6
2001 AUDI S8
A CONDITION MAY EXIST WITH THE MALFUNCTION INDICATOR LIGHT ON WITH DIAGNOSTIC TROUBLE CODE P0411 SECONDARY AIR SYSTEM INCORRECT FLOW DETECTED STORED IN MEMORY. *TT
A CONDITION MAY EXIST WHERE THE MALFUNCTION INDICATOR LAMP (MIL) IS ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P04`` SECONDARY AIR SYSTEM INCORRECT FLOW DETECTED STORED IN DTC MEMORY. *TT
Bulletin Number: TSB-28-10-04
AUDI: FOR INTERIM CLAIMS FOR 28F2/J1 VEHICLES CAMPAIGN ONLY. APPLICABLE VEHICLES MUST FALL WITHIN VIN RANGES NOTED. ENGINES 2.8L ARE NOT AFFECTED IN THIS SCOPE. COILS OF SCREW DOWN DESIGN (NON PENCIL TYPE) ARE ALSO NOT AFFECTED. THE MI
2001 AUDI TT
Bulletin Number: 900101
SUBJECT REGARDING INSTRUMENT CLUSTER, WHISTLING/BUZZING NOISE. *JG
2001 AUDI TT COUPE
2001 AUDI TT QUATTRO
INFORMATION CONTAINING CELLULAR TELEPHONE INSTALLATION INSTRUCTIONS FOR MODEL YEAR VEHICLES. *TT
Bulletin Number: 0008
SUBJECT REGARDING COMPACT DISC CHANGER INSTALLATION INSTRUCTIONS. *TT
mksu19's Avatar
Recalls for 2001 Audi
2001 AUDI A6
Defect Description:
Consequence:
Action:
2001 AUDI A6
Defect Description:
Consequence:
Action:
2001 AUDI A6
NHTSA Campaign ID: VISIBILITY:WINDSHIELD WIPER/WASHER
Manufacture Dates: 08/01/2000 - 01/31/2001
Potential Units Affected: 2837
Defect Description:
VEHICLE DESCRIPTION: PASSENGER VEHICLES (ALLROAD). WHEN ACTIVATING THE WINDSHIELD WIPER UNDER HEAVY LOAD CONDITIONS SUCH AS FREEZING, SNOW OR HEAVY RAIN, ONE WIPER COULD BE DELAYED BEHIND THE OTHER WIPER.
Consequence:
IF THAT HAPPENS, THE WIPER BLADES, BECAUSE THEY OVERLAP WIPING AREAS, COULD BECOME ENTANGLED WITH EACH OTHER AND CEASE FUNCTIONING. THIS COULD IMPAIR THE DRIVER'S VISIBILITY.
Action:
DEALERS WILL REPLACE THE ENTIRE DRIVER SIDE WIPER ARM. OWNER NOTIFICATION BEGAN JUNE 22, 2001. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT AUDI AT 1-866-892-2834.
2001 AUDI A6
Manufacture Dates: 08/01/1997 - 06/30/2005
Defect Description:
Consequence:
Action:
2001 AUDI A6
NHTSA Campaign ID: TIRES
Manufacture Dates: 11/01/2000 - 07/31/2001
Potential Units Affected: 1360
Defect Description:
CERTAIN PASSENGER VEHICLES EQUIPPED WITH 2.7L ENGINES FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 110, "TIRE SELECTION AND RIMS." THE CALCULATED "VEHICLE NORMAL LOAD" EXCEEDS THE ALLOWABLE WEIGHT OF THE AXLE LOAD WITH TIRE DIMENSION 225/45R 17 91Y BY 19KG.
Consequence:
Action:
DEALERS WILL REPLACE ALL FIVE TIRES. OWNER NOTIFICATION BEGAN ON SEPTEMBER 19, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT AUDI AT 1-800-822-2834.
2001 AUDI A6
Manufacture Dates: 06/02/2001 - 06/01/2005
Potential Units Affected: 68240
Defect Description:
VOLKSWAGEN IS RECALLING 68,240 MY 2001-2004 AUDI A6 QUATTRO VEHICLES EQUIPPED WITH 2.7L, 2.8L, OR 3.0L ENGINES AND MY 2001-2005 ALLROAD QUATTRO VEHICLES EQUIPPED WITH 2.7L OR 4.2L ENGINES. THE AGING OF THE PLASTIC MATERIAL IN THE FUEL TANK ROLLOVER VALVE COMBINED WITH BENDING STRESS FROM THE ALUMINUM VENTILATION LINE TO THE ROLLOVER VALVE NIPPLE MAY LEAD TO CRACKING OF THE NIPPLE. IF THIS HAPPENS, A FUEL LEAK MAY RESULT.
Consequence:
A FUEL LEAK IN THE PRESENCE OF AN IGNITION SOURCE COULD LEAD TO A VEHICLE FIRE.
Action:
DEALERS WILL REINFORCE THE NIPPLE ON THE ROLLOVER VALVE TO PREVENT LEAKAGE OR REPAIR THE CRACKING AT THE NIPPLE. THE RECALL BEGAN ON JUNE 27, 2008. OWNERS MAY CONTACT AUDI AT 1-800-822-2834.
2001 AUDI A6 AVANT
Defect Description:
Consequence:
Action:
2001 AUDI A8
Defect Description:
Consequence:
Action:
2001 AUDI A8
Defect Description:
Consequence:
Action:
Defect Description:
Consequence:
Action:
Defect Description:
Consequence:
Action:
Defect Description:
Consequence:
Action:
2001 AUDI S6
Defect Description:
Consequence:
Action:
Defect Description:
Consequence:
Action:
Quick Reply: Audi TSB's & Recalls (1990-2010)
