Audi TSB's & Recalls (1990-2010)
#21
Recalls for 2005 Audi
2005 AUDI A8
NHTSA Campaign ID: AIR BAGS:FRONTAL
Manufacturer: VOLKSWAGEN OF AMERICA, INC
Manufacture Dates: 02/01/2003 - 06/30/2005
Potential Units Affected: 7674
Defect Description:
ON CERTAIN PASSENGER VEHICLES, DURING PRODUCTION OF THE DRIVER'S FRONTAL AIR BAG, THE AIR BAG MAY NOT UNFOLD PROPERLY IN THE EVENT OF A CRASH AND THEREFORE MAY NOT INFLATE AS DESIGNED.
Consequence:
LOSS OF FRONTAL AIR BAG DEPLOYMENT COULD OCCUR WHICH CAN INCREASE THE RISK OF INJURY IN A FRONTAL CRASH.
Action:
DEALERS WILL INSTALL A NEW DRIVER'S FRONTAL AIR BAG FREE OF CHARGE. THE RECALL BEGAN ON OCTOBER 6, 2006. OWNERS MAY CONTACT AUDI AT 1-800-822-2834.
2005 AUDI ALLROAD QUATTRO
NHTSA Campaign ID: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY
Manufacture Dates: 06/02/2001 - 06/01/2005
Potential Units Affected: 68240
Defect Description:
VOLKSWAGEN IS RECALLING 68,240 MY 2001-2004 AUDI A6 QUATTRO VEHICLES EQUIPPED WITH 2.7L, 2.8L, OR 3.0L ENGINES AND MY 2001-2005 ALLROAD QUATTRO VEHICLES EQUIPPED WITH 2.7L OR 4.2L ENGINES. THE AGING OF THE PLASTIC MATERIAL IN THE FUEL TANK ROLLOVER VALVE COMBINED WITH BENDING STRESS FROM THE ALUMINUM VENTILATION LINE TO THE ROLLOVER VALVE NIPPLE MAY LEAD TO CRACKING OF THE NIPPLE. IF THIS HAPPENS, A FUEL LEAK MAY RESULT.
Consequence:
A FUEL LEAK IN THE PRESENCE OF AN IGNITION SOURCE COULD LEAD TO A VEHICLE FIRE.
Action:
DEALERS WILL REINFORCE THE NIPPLE ON THE ROLLOVER VALVE TO PREVENT LEAKAGE OR REPAIR THE CRACKING AT THE NIPPLE. THE RECALL BEGAN ON JUNE 27, 2008. OWNERS MAY CONTACT AUDI AT 1-800-822-2834.
NHTSA Campaign ID: ELECTRICAL SYSTEM
Manufacture Dates: 08/01/1997 - 06/30/2005
Potential Units Affected: 70512
Defect Description:
ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH HALOGEN LOW BEAM HEADLIGHTS, CERTAIN CONNECTOR PINS IN THE HEADLIGHT SWITCH CONNECTOR COME INTO CONTACT WITH EACH OTHER CAUSING A SHORT CIRCUIT. NOTE: VEHICLES WITH XENON LOW BEAM HEADLIGHTS ARE NOT AFFECTED BECAUSE THE CIRCUIT IN THESE VEHICLES CONTAINS A FUSE, WHICH PRECLUDES EXCESSIVE CURRENT FLOW IN THE CASE OF A SHORT CIRCUIT. AUDI S6 AND S6 AVANT VEHICLES ARE ALL EQUIPPED WITH XENON LOW BEAM HEADLIGHTS AND, THEREFORE, ARE NOT LONGER AFFECTED BY THIS RECALL.
Consequence:
THIS CONDITION COULD LEAD TO OVERHEATING OR FIRE.
Action:
DEALERS WILL REROUTE THE WIRING HARNESS BY INSTALLING A JUMPER WIRING HARNESS. THE RECALL BEGAN ON DECEMBER 16, 2006. OWNERS MAY CONTACT AUDI AT 1-800-822-2834.
2005 AUDI A8
Defect Description:
Consequence:
Action:
Defect Description:
Consequence:
Action:
Defect Description:
Consequence:
Action:
#22
Service Bulletins for 2006 Audi
2006 AUDI A3
Bulletin Number: 0501
DIRECT SHIFT GEARBOX (DSG) EXPERIENCES MOMENTARY DELAY WHEN ACCELERATING. *TT
Bulletin Number: 0509
ENGINE DOES NOT CRANK INTERMITTENTLY. *TT
Bulletin Number: 0523
GUIDED FAULT FINDING (GIFF) MISSING ON VAS 5051 / VAS 5052 FOR A3 MODELS WITH 3.2L V6 4V (ENGINE CODE BUB). *TT
Bulletin Number: 0601
WIND NOISE AND/OR BUZZING NOISE IN SLIDING ROOF. *TT
Bulletin Number: 0602
SUNROOF SUNSHADE BINDS OR DOES NOT RETRACT. *TT
Bulletin Number: 0718
AUTOMATIC HEADLIGHT SWITCHES ON AND OFF WITHOUT REASON. *NJ
Bulletin Number: 15 08 01
MIL ON (DTC P2293, P0087 IN ECM). *NJ
Bulletin Number: 15-08-05
AUDI: MIL ON (DTC P2293, P0087 IN ECM). THE FOLLOWING DTC IS STORED IN THE ECM DATA MEMORY: P2293 (FUEL PRESSURE REGULATOR 2 PERFORMANCE); P0087 (RAIL FUEL PRESSURE TOO LOW); P1093 (FUEL TRIM 2, BANK 1 MALFUNCTION). *PE
Bulletin Number: 20036582
LOSES POWER OR WILL NOT MOVE AFTER STOP. *KB
Bulletin Number: 20056243
HEADLIGHT AIMING, USING HELLA UNIVERSAL BEAMSETTER. *KB
Bulletin Number: 2012749-2
EXTERIOR LIGHTS, MOSITURE ACCUMULATION. *PE
Bulletin Number: 2013535
ENGINE CONTROL MODULE UPDATE. *KB
Bulletin Number: 20138292
HEADLIGHT LOW BEAM MAY NOT WORK. *KB
Bulletin Number: 20145191
DOWNSHIFTING INTO 5TH GEAR IS DIFFICULT, OR GEAR CANNOT BE SELECTED. *KB
Bulletin Number: 240708
MIL ON (DTC P310B AND/OR P129F). *KB UPDATED 5/13/08. *NJ
Bulletin Number: 24 08 10
MIL ON (DTC P0642, P2004, P2008, P3137, P3138 IN ECM). *NJ
Bulletin Number: 24 08 11
MIL ON (DTC P310B, P129F, P2293, P0087). *NJ
Bulletin Number: 24-08-11
AUDI: DUE TO FUEL INTRUSION INTO THE LOW-PRESSURE SYSTEM FUEL PRESSURE SENSOR (G410), A FALSE SIGNAL MAY BE SENT TO THE CONTROLLER RESULTING IN A READING THAT IS OUT OF TOLERANCE. *PE
Bulletin Number: 24 08 13
RVU - ENGINE CONTROL MODULE UPDATE (CH). *NJ
Bulletin Number: 24-08-13
AUDI: RVU-ENGINE CONTROL MODULE UPDATE. *PE
Bulletin Number: 340702
AFTER SELECTING D, R, OR S FROM PARK THE GEAR INDICATOR FLASHES AND VEHICLE WILL NOT ACCELERATE. *KB
Bulletin Number: 350701
DIRECT SHIFT GEARBOX (DSG) EXPERIENCES MOMENTARY DELAY WHEN ACCELERATING. *KB
Bulletin Number: 660703
FRONT WINDSHIELD WIPERS ARE INOPERATIVE. *KB
Bulletin Number: 910608
TIRE PRESSURE MONITORING SYSTEM WARNING LIGHT IS ON. NO SATELLITE RADIO FUNCTION WITH AUDI NAVIGATION PLUS. *NJ
Bulletin Number: 94-07-08
THE BULB WARNING FOR THE DAYTIME RUNNING LIGHTS IN THE INSTRUMENT CLUSTER. *PE
Bulletin Number: 940710
DYNAMIC HEADLIGHT RANGE CONTROL, WARNING LIGHT IS ON IN THE INSTRUMENT PANEL CENTER DISPLAY. *KB
Bulletin Number: KM-1379
AUDI: MIL LIGHT ON AND DTC P2294 (FUEL PRESSURE REGULATOR 2 CONTROL CIRCUIT), P2295 (FUEL PRESSURE REGULATOR 2 CONTROL CIRCUIT LOW), P2296 (FUEL PRESSURE REGULATOR 2 CONTROL CIRCUIT HIGH) IN FAULT MEMORY DRIVABILITY IS NOT AFFECTED. WIRING
Bulletin Number: KM-1384
AUDI: WHEN REPLACING ABS CONTROL UNITS WITH HILL HOLD CONTROL (PR UG1) BE AWARE. ALWAYS USE THE VIN WHEN CHECKING PARTS IN ETKA. THIS IS THE ONLY WAY TO ASSURE THAT PROPER PARTS ARE ORDERED. *PE
Bulletin Number: SA-28F2 J1
AUDI: (REVISED) VEHICLES AFFECTED BY THIS ACTION MAY HAVE IGNITION COILS THAT COULD MALFUNCTION UNDER CERTAIN CONDITIONS. IF THIS HAPPENS, THE MALFUNCTION INDICATOR LAMP (MIL) WILL ILLUMINATE TO LET YOU KNOW THAT THE VEHICLE MAY EXPERIENCE
Bulletin Number: SB-94-09-20
AUDI: THERE ARE TWO SEPARATE CONDITIONS THAT BOTH OCCUR IN VEHICLES WITH BI-XENON, WITH OR WITHOUT ADAPTIVE LIGHTING (AFS). ONE XENON LIGHT ON EITHER SIDE SPORADICALLY FLICKERS OR FLASHES AND GOES OUT. ONE XENON LIGHT ON ONE SIDE FAILS P
Bulletin Number: TB-24-09-07
AUDI: FUEL PRESSURE SENSOR REPLACEMENT. VEHICLE MUST MEET ALL OF THE FOLLOWING CRITERIA: VEHICLES THAT SHOW THE CL/24M4 CODE IN THE ELSAWEB CAMPAIGN/ACTION INFORMATION SCREEN; WITHIN THE LIMITED NEW VEHICLE WARRANTY;PROCEDURE MUST BE PERFOR
Bulletin Number: TSB-01-08-33
AUDI: SOFTWARE VERSION MANAGEMENT(SVM) OPERATING INSTRUCTIONS. ITS A PROCESS TO UPDATE THE PROGRAMMING IN FLASHABLE (REPROGRAMMABLE) CONTROL MODULES AND/OR TO DOCUMENT CHANGES IN SOFTWARE LEVELS IN ALL AUDI VEHICLES. *PE
Bulletin Number: TSB-01-09-06
AUDI: SOFTWARE VERSION MANAGEMENT (SVM), OPERATING INSTRUCTIONS. SVM IS A PROCESS TO UPDATE THE PROGRAMMING IN FLASHABLE (RE-PROGRAMMABLE) CONTROL MODULES AND/OR TO DOCUMENT CHANGES IN SOFTWARE LEVELS IN AUDI VEHICLES. THIS SYSTEM USES T
Bulletin Number: TSB-10-07-02
AUDI: AVOIDING DAMAGE TO HALDEX CLUTCH AND FINAL DRIVE. THE HALDEX CLUTCH'S OIL FILLER PLUG AND DRAIN PLUG MUST NOT BE CONFUSED WITH THE FINAL DRIVE'S OIL FILLER PLUG AND DRAIN PLUG. THE INTEGRATED HOUSINGS OF THE HALDEX CLUTCH AND FINAL
Bulletin Number: TSB-17-07-13
AUDI: OIL LEAKS. ONE OR MORE OF THE FOLLOWING CONDITIONS MAY BE PRESENT-MIL ON, AND ONE OR MORE OF FOLLOWING DTCS ARE STORED IN ECM DATA MEMORY-P1297 (CONNECTION CHARGER THROTTLE VALVE, PRESSURE LOSS), P2187 (FUEL TRIM BANK 1, SYSTEM TOO
Bulletin Number: TSB-17-09-16
AUDI: ENGINE STALLS OR IDLES ERRATICALLY IMMEDIATELY AFTER COLD START IN EXTREMELY COLD WEATHER (BELOW 20%F). *PE
Bulletin Number: TSB-24-10-01
AUDI: DUE TO FUEL INTRUSION INTO THE LOW PRESSURE SYSTEM FUEL PRESSURE SENSOR (G410), A FALSE SIGNAL MAY BE SENT TO THE CONTROLLER, RESULTING IN A READING THAT IS OUT OF TOLERANCE. COMPARING MEASURE VALUE BLOCK 103 WITH 106 IS NOT AN ACCU
Bulletin Number: TSB-24-10-02
AUDI: MIL ON AND ONE OR MORE OF THE FOLLOWING DTCS ARE STORED IN THE ECM DATA MEMORY-P310B (LOW PRESSURE FUEL SYSTEM REGULATION, FUEL PRESSURE OUTSIDE TOLERANCE); P129F OR P008B (LOW PRESSURE FUEL SYSTEM, PRESSURE TOO HIGH); P129E OR P008A
Bulletin Number: TSB-28-10-04
AUDI: FOR INTERIM CLAIMS FOR 28F2/J1 VEHICLES CAMPAIGN ONLY. APPLICABLE VEHICLES MUST FALL WITHIN VIN RANGES NOTED. ENGINES 2.8L ARE NOT AFFECTED IN THIS SCOPE. COILS OF SCREW DOWN DESIGN (NON PENCIL TYPE) ARE ALSO NOT AFFECTED. THE MI
Bulletin Number: TSB-44-08-14
AUDI: WHEEL BOLTS REQUIRE TORQUE ADJUSTMENT. TORQUE STICKS AND TORQUE EXTENSION BARS ARE NOT APPROVED BY AUDI OF AMERICA, INC. AND SHOULD NOT BE USED TO APPLY TORQUE TO WHEEL BOLTS. ALL AUDI MODELS INCLUDED. *PE
Bulletin Number: TSB-92-10-01
AUDI: FRONT WINDSHIELD WIPERS INOPERATIVE. THIS IS DUE TO A FAILURE IN THE WINDSHIELD WIPER MOTOR CONTROL MODULE. *PE
Bulletin Number: TSB-94-07-13
AUDI: ADAPTIVE LIGHTING, HEADLIGHT RANGE CONTROL WARNING. HEADLIGHT RANGE CONTROL WARNING IS ON IN THE DRIVER INFORMATION DISPLAY. AFTER CYCLING THE IGNITION WARNING SYMBOL IS OFF AGAIN. *PE
Bulletin Number: TSB-94-07-18
AUDI: AUTOMATIC HEADLIGHT SWITCHES ON AND OFF WITHOUT REASON. AUTOMATIC HEADLIGHT SWITCHES ON TOO EARLY OR TOO LATE, SWITCHES OFF TOO LATE OR COMES ON TOO LATE WHEN THE SUN SHINES BRIGHTLY. AFTER REPLACING THE RAIN LIGHT SENSOR OR AFTER
Bulletin Number: TSB-94-09-12
AUDI: HEADLIGHT, LOW BEAM MAY NOT WORK. THERE ARE TWO SEPARATE CONDITIONS THAT BOTH OCCUR IN VEHICLES WITH BI XENON, WITH OR WITHOUT ADAPTIVE LIGHTING(AFS). ONE XENON LIGHT ON EITHER SIDE SPORADICALLY FLICKERS OR FLASHES AND GOES OUT. ON
Bulletin Number: TSB-94-09-14
AUDI: THERE ARE TWO SEPARATE CONDITIONS THAT BOTH OCCUR IN VEHICLES WITH BI-XENON, WITH OR WITHOUT ADAPTIVE LIGHTING (AFS): ONE XENON LIGHT ON EITHER SIDE SPORADICALLY FLICKERS OR FLASHES AND GOES OUT. WHEN HEADLAMPS ARE TURNED OFF AND ON
2006 AUDI A3
Bulletin Number: 0506
ECM UPDATE FOR MALFUNCTION INDICATION LIGHT ON CONDITION, POSSIBLE DIAGNOSTIC CODE P2106(18538). *TS
Bulletin Number: 0507
ADAPTIVE LIGHTING, HEADLIGHT RANGE CONTROL WARNING IS ON IN DRIVER INFORMATION DISPLAY. *TT
MIL ILLUMINATION DUE TO SETTING OF DTC P2404 (RATIONALITY CHECK: REED SENSOR UNABLE TO OPEN). *TT
MIL ON AND ONE OR MORE OF THE FOLLOWING DTCS ARE STORED. *KB
Bulletin Number: 0717
COLD ENGINE RUNS ROUGH OR STUMBLES; WARM ENGINE MAY STALL WHEN ENGAGING GEAR AND VEHICLE IS STATIONARY. *NJ UPDATED 4/15/07. *NJ
Bulletin Number: 20174522
MIL ON - DTC P1388 STORED IN ECM (INTERNAL CONTROL MODULE DRIVE BY WIRE ERROR). *KB
Bulletin Number: 240701
COLD ENGINE RUNS ROUGH OR STUMBLES; WARM ENGINE MAY STALL WHEN ENGAGING GEAR AND VEHICLE IS STATIONARY. *KB
Bulletin Number: 240812
MIL ON (DTC P310B AND/OR P129F) AND ONE OR MORE OF THE FOLLOWING DTCS ARE STORED IN THE ECM DATA MEMORY. *PE
Bulletin Number: 28 08 04
MIL ON, ENGINE SPEED SENSOR SPACER NOT REQUIRED (DTC P0300, P0335, P0336, P0321, P0322). *NJ
Bulletin Number: 370710
MIL ON, AND/OR MULTITRONIC TRANSMISSION IN EMERGENCY RUNNING MODE (DTC P0706 OR P1793 IN TCM). *KB
Bulletin Number: 940707
AT AN IDLE, VIBRATIONS OR RESONANCE IN THE FRONT OF THE VEHICLE CAN CAUSE THE HEADLIGHTS TO VIBRATE. *KB
Bulletin Number: 94-08-11
AUDI: HEADLIGHT VIBRATION, A4 AND A4 CABRIOLET. UNDER CERTAIN OPERATING CONDITIONS, SUCH AS AT IDLE, VIBRATIONS OR RESONANCES IN THE FRONT OF THE VEHICLE CAN CAUSE THE HEADLIGHTS TO VIBRARTE. *PE
Bulletin Number: TSB-24-07-20
AUDI: COLD ENGINE RUNS ROUGH OR STUMBLES; WARM ENGINE MAY STALL WHEN ENGAGING GEAR AND VEHICLE IS STATIONARY. ENGINE MAY IDLE ROUGH AFTER A COLD START; ENGINE MAY STUMBLE OR HESITATE AT SLOW INITIAL ACCELERATION AFTER A COLD START AND UND
Bulletin Number: TSB-24-08-76
AUDI: MIL ON. MAY BE SLIGHT POWER REDUCTION AT HIGH RPMS. THIS CONDITION DOES NOT CAUSE STALLING. VACUUM LINE CRACKS. *PE
Bulletin Number: TSB-28-09-05
AUDI: MIL ON, ENGINE SPEED SENSOR SPACER NOT REQUIRED (DTC P0300, P0335, P0336, P0321, P0322). MULTIPLE MISFIRES DETECTED ON ONE OR MORE CYLINDERS; MALFUNCTION INDICATOR LIGHT (MIL) MAY BE ON OR FLASHING. *PE
2006 AUDI A4
Bulletin Number: TSB-17-07-12
AUDI: ENGINE OIL PRESSURE IS BELOW SPECIFIED VALUE. OIL PRESSURE WARNING LIGHT MIGHT BE ILLUMINATED OR ILLUMINATED INTERMITTENTLY. REPAIRS INCLUDE REPLACING THE OIL PUMP MODULE. *PE
2006 AUDI A4 CABRIOLET
Bulletin Number: 0401
AIRBAG SYSTEM, SERVICING. *TT
Bulletin Number: 0402
OIL LEAKS FROM UPPER ENGINE AREAS, DIAGNOSTIC GUIDELINES. *TT
ENGINE DOES NOT START/INTERMITTENT NO START USING ADVANCE KEY START BUTTON, STARTS W/KEY & IGNITION SWITCH. *AK
Bulletin Number: 0504
SUNROOF HEADLINER/GLASS ROOF JAMMED/NOT MOVING, SUNROOF NOT OPENING/CLOSING CORRECTLY. *TT
Bulletin Number: 0505
COOLANT LEAKAGE AROUND AUXILIARY COOLANT PUMP. COOLANT LIGHT MAY BE ILLUMINATED. *TT
CONTROL HOUSING FOR CAMSHAFT ADJUSTER, ENSURING SHIM WASHER INSTALLATION WHEN REPAIRING. *TT
UPDATE PROGRAMMING FOR AIRBAG WARNING LIGHT ON (II). *TT
Bulletin Number: 0707
AIRBAG WARNING LIGHT ON, UPDATE FOR AIRBAG MODULE SOFTWARE. *NJ
Bulletin Number: 0715
EXTERIOR LIGHTS, MOISTURE ACCUMULATION. *NJ
Bulletin Number: 200704
THUMPING, KNOCKING OR POPPING NOISE IN FUEL TANK AREA. *KB
Bulletin Number: 20142931
Bulletin Number: 20143571
FUEL FILLING PROBLEMS. *KB
Bulletin Number: 370716
IGNITION KEY CAN'T BE REMOVED WHEN TRANSMISSION IS IN PARK OR CAN NOT LOCK VEHICLE. *NJ
Bulletin Number: 460704
ELECTRONIC PARKING BRAKE WARNING LIGHT ON; PARKING BRAKE DOESN'T ALWAYS RELEASE. *NJ UPDATED 5/2/08. *NJ
Bulletin Number: 48 08 02
ELECTRIC STEERING COLUMN ADJUSTMENT IS INOPERATIVE. *NJ
Bulletin Number: 940706
WHILE VEHICLE IS AT IDLE SPEED, ENGINE RESONANCE MAY LEAD TO VIBRATIONS WITHIN THE HEADLIGHTS. THIS CAUSES THE LIGHT BEAMS TO SHAKE. *KB
Bulletin Number: KM-1374
AUDI: STEERING TOO STIFF AT LOW SPEEDS OR NO POWER ASSIST. THE SERVOTRONIC SYSTEM ON THE C6 IS DIFFERENT FROM PREVIOUS MODELS. THE SERVOTRONIC FUNCTION IS CONTROLLED BY J520 VEHICLE ELECTRICAL SYSTEM CONTROL MODULE. *PE
Bulletin Number: TB-97-09-01
AUDI: AFTER ENGINE START, THE STEERING IS STIFFER THAN IT USED TO BE AND/OR THAT THE GLOVE COMPARTMENT CANNOT BE OPENED. THIS CONDITION IS ALSO PRESENT IN THE NEXT DRIVING CYCLE. *PE
Bulletin Number: TSB-20-09-08
AUDI: FUEL GAUGE READS EMPTY AFTER REFUELING (DTCS 00438, 00771). DUE TO THE UNATTACHED SECTION OF CABLE IN THE AREA OF THE 2 PIN PLUG IN CONNECTIONS (INSIDE THE FUEL TANK) BETWEEN THE FLANGE OF THE ELECTRIC FUEL PUMP AND THE FUEL GAUGE S
Bulletin Number: TSB-37-07-16
AUDI: THE IGNITION KEY CAN'T BE REMOVED WHEN TRANSMISSION IS IN PARK OR CAN'T LOCK VEHICLE. IF EQUIPPED WITH ADVANCED KEY SYSTEM THE VEHICLE CAN'T BE LOCKED BY REMOTE CONTROL AFTER EXITING. *PE
Bulletin Number: TSB-43-08-07
AUDI: SELF LEVELING COMPRESSOR INOPERATIVE. THE SELF LEVELING SYSTEM CANNOT BE ADJUSTED ANY MORE WITH THE MMI. THE COMPRESSOR FOR THE SELF LEVELING SYSTEM CONTINUES TO RUN AFTER SWITCHING OFF THE ENGINE AND LOCKING THE VEHICLE.
Bulletin Number: TSB-43-08-15
AUDI: AIR SUSPENSION OPERATIVE (DTC 1577). COMPRESSOR SWITCH OFF DUE TO EXCESSIVE TEMPERATURE, SPORADIC) IS STORED IN THE AIR SUSPENSION CONTROL MODULE. THIS DTC DOES NOT INDICATE A COMPRESSOR MALFUNCTION. *PE
Bulletin Number: TSB-43-08-16
AUDI: THE SELF LEVELING SYSTEM CAN NOT BE ADJUSTED ANY MORE WITH THE MMI. THE COMPRESSOR FOR THE SELF LEVELING SYSTEM CONTINUES TO RUN AFTER SWITCHING OFF THE ENGINE AND LOCKING THE VEHICLE. *PE
Bulletin Number: TSB-43-09-10
AUDI: SELF LEVELING COMPRESSOR INOPERATIVE. SELF LEVELING SYSTEM CANNOT BE ADJUSTED ANY MORE WITH THE MMI; COMPRESSOR FOR SELF LEVELING SYSTEM CONTINUES TO RUN AFTER SWITCHING OFF THE ENGINE AND LOCKING THE VEHICLE. BECAUSE OF POOR PERFO
Bulletin Number: TSB-69-07-07
AUDI: AIRBAG WARNING LIGHT ON, UPDATE FOR AIRBAG MODULE SOFTWARE. AIRBAG WARNING LIGHT ILLUMINATES DUE TO SPORADIC FAULT ENTRY. THE REAR SEAT BELT PRETENSIONER IGNITERS WILL CONTINUE TO FUNCTION AS DESIGNED IF DTCS ARE SET AS SPORADIC F
Bulletin Number: TSB-94-07-15
AUDIO: EXTERIOR LIGHTS, MOISTURE ACCUMULATION. CONDENSATION IS VISIBLE ON THE INSIDE OF HEADLIGHTS, TAILLIGHTS, FOG LIGHTS, SIDE MARKER LIGHTS, FRONT TURN SIGNAL OR THIRD BRAKE LIGHT LENS. DAMP AIR SETTLES ON THE INSIDE OF A COLD LENS,
2006 AUDI A6
PART1
2006 AUDI A3
2006 AUDI A3
2006 AUDI A4
2006 AUDI A6
PART1
#23
2006 AUDI A6 AVANT
Bulletin Number: 0502
SUN ROOF CANNOT BE OPENED IN LIFT POSITION. *TT
AUTOMATIC TRUNK LID OPENING SYSTEM NOT OPERATING NORMALLY, INTERRUPTS DURING OPENING / CLOSING PROCESS. *TT
Bulletin Number: 190707
POOR OR NO HEATING IN ANY OR ALL HEATING ZONES OF THE VEHICLE. *NJ
Bulletin Number: 20116673
AIRBAG WARNING LIGHT ON, UPPER LIMIT FOR FRONT OR REAR SIDE AIRBAG EXCEEDED. *KB
Bulletin Number: TSB-19-07-07
AUDI: POOR OR NO HEATING IN ANY OR ALL HEATING ZONES. ECM SOFTWARE UPDATED WITH MODIFIED MAP CONTROLLED COOLANT THERMOSTAT SPECIFICATIONS. THE TCM SOFTWARE MUST ALSO BE UPDATED TO BE COMPATIBLE WITH THE NEW ECM SOFTWARE LEVEL. POSSIBLE
Bulletin Number: TSB-24-08-04
AUDI: MIL ON (MASS AIRFLOW SENSOR DTCS P0101, P0102, P0103, P0112, P0113 IN ECM). ENGINE HAS LOW PERFORMANCE WITHOUT SIGNIFICANT LOSS OF POWER OR STALLING. MODELS S4, S4 CABRIOLET, ALLROAD, RS6, & R8. *PE
Bulletin Number: TSB-24-09-16
AUDI: MIL ON (MASS AIRFLOW SENSOR DTCS P0101, P0102, P0103, P0112, P0113 IN ECM). ENGINE HAS LOW PERFORMANCE WITHOUT SIGNIFICANT LOSS OF POWER OR STALLING. DTCS RELATED TO THE MASS AIR FLOW SENSOR AND FUEL TRIM FAULTS CAN BE RELATED TO (
Bulletin Number: TSB-69-08-01
AUDI: AIRBAG WARNING LIGHT ON; UPPER LIMIT FOR FRONT/REAR SIDE AIRBAG EXCEEDED. OVER TIME RESISTANCE VARIANCE WITHIN SIDE IMPACT AIRBAG CONNECTOR CAN CAUSE THE AIRBAG WARNING LIGHT ON INSTRUMENT PANEL TO COME ON AND STAY ON, EVEN THOUGH SID
2006 AUDI A8
2006 AUDI A8 L
2006 AUDI A8 L W12
Bulletin Number: TSB-94-10-09
AUDI: FRONT PARKING LIGHT INDICATOR STEAMED UP. UNDER SPECIAL OPERATING CONDITIONS, SUCH AS DRIVING THROUGH DEEP WATER, WATER CAN GET INTO THE TURN SIGNAL PARKING LIGHT. THE TURN SIGNAL PARKING LIGHT HAS OPENINGS FOR AIR CIRCULATION. THE
2006 AUDI Q7
2006 AUDI RS6
REVERSE GEAR WILL NOT ENGAGE OR IS HARD TO ENGAGE. *TT
2006 AUDI S4
2006 AUDI S4 CABRIOLET
PART2
2006 AUDI A8
2006 AUDI A8 L
2006 AUDI A8 L W12
2006 AUDI Q7
2006 AUDI RS6
2006 AUDI S4
PART2
#24
Recalls for 2006 Audi
2006 AUDI A3
Manufacture Dates: 09/29/2005 - 07/30/2009
Potential Units Affected: 10200
Defect Description:
VOLKSWAGEN IS RECALLING CERTAIN MODEL YEAR 2006 THROUGH 2010 AUDI A3, TT, AND TT ROADSTER PASSENGER VEHICLES MANUFACTURED BETWEEN SEPTEMBER 29, 2005 AND AUGUST 26, 2009. THE CLOSING FORCE OF AN INTERNAL SPRING OF THE FUEL TANK VENTILATION VALVE IS NOT ADEQUATE ENOUGH TO HOLD THE VALVE CLOSED UNDER EXTREME DRIVING CONDITIONS POSSIBLY ALLOWING FUEL TO LEAK.
Consequence:
IN THE PRESENCE OF AN IGNITION SOURCE, A VEHICLE FIRE COULD OCCUR.
Action:
VOLKSWAGEN WILL NOTIFY OWNERS AND AUDI DEALERS WILL REPLACE THE FUEL TANK VENTILATION VALVE WITH AN IMPROVED VALVE FREE OF CHARGE. THE SAFETY RECALL BEGAN ON NOVEMBER 16, 2009. OWNERS MAY CONTACT AUDI AT 1-800-253-2834.
2006 AUDI A3
NHTSA Campaign ID: AIR BAGS:SIDE/WINDOW
Manufacture Dates: 07/01/2005 - 08/31/2005
Potential Units Affected: 48
Defect Description:
ON CERTAIN PASSENGER VEHICLES, DURING PRODUCTION OF THE AIR BAG, EITHER THE LEFT OR THE RIGHT SIDE CURTAIN AIR BAG INFLATION MODULE MAY LEAK.
Consequence:
IN THE EVENT OF A CRASH, THE AIR BAG MAY NOT INFLATE AS DESIGNED INCREASING THE RISK OF INJURY TO A SEAT OCCUPANT.
Action:
DEALERS WILL REPLACE THE SIDE CURTAIN AIR BAG FREE OF CHARGE. THE RECALL BEGAN ON AUGUST 31, 2006. OWNERS MAY CONTACT AUDI AT 1-800-822-2834.
2006 AUDI A6 AVANT
NHTSA Campaign ID: STRUCTURE:BODY:TRUNK LID
Manufacture Dates: 05/01/2005 - 07/31/2007
Potential Units Affected: 23898
Defect Description:
ON CERTAIN PASSENGER AND SPORT UTILITY VEHICLES, THE AUTOMATIC REAR LID INCLUDES AN ELECTRIC MOTOR AND CLUTCH THAT WORK IN CONJUNCTION WITH TWO GAS STRUTS TO OPEN AND CLOSE THE REAR LID, INCLUDING A MANUAL CLOSE FUNCTION. IF ONE OF THE STRUTS HAS A TOTAL LOSS OF PRESSURE, THE RESULTANT SLOW MOVEMENT OF THE REAR LID IS INTERPRETED BY THE SOFTWARE AS AN INTENDED MANUAL CLOSE AND THE MOTOR CLUTCH RELEASES TO CLOSE THE REAR LID IMMEDIATELY.
Consequence:
THIS CAN RESULT IN AN UNINTENDED RAPID CLOSING OF THE REAR LID WITH A RISK OF PERSONAL INJURY.
Action:
DEALERS WILL INSTALL NEW SOFTWARE FREE OF CHARGE. THE RECALL BEGAN ON SEPTEMBER 14, 2007. OWNERS MAY CONTACT AUDI AT 1-800-822-2834.
2006 AUDI A8
Manufacture Dates: 06/01/2005 - 10/31/2005
Potential Units Affected: 1530
Defect Description:
ON CERTAIN PASSENGER VEHICLES, A WIRING HARNESS CONDITION EXISTS THAT MAY DEACTIVATE THE PASSENGER SIDE FRONTAL AIR BAG EVEN UNDER CIRCUMSTANCES WHEN IT SHOULD REMAIN ACTIVATED.
Consequence:
IF THIS CONDITION OCCURS, BOTH THE AIR BAG WARNING LIGHT IN THE INSTRUMENT CLUSTER AND THE "PASSENGER AIR BAG OFF" TELLTALE IN THE CENTER OF THE INSTRUMENT PANEL WILL PROPERLY ILLUMINATE. CONSEQUENTLY, THE PASSENGER SIDE FRONTAL AIR BAG WOULD NOT DEPLOY IN THE CASE OF A FRONTAL CRASH.
Action:
DEALERS WILL MODIFY THE WIRING HARNESS FREE OF CHARGE. THE RECALL BEGAN ON NOVEMBER 30, 2005. OWNERS MAY CONTACT AUDI AT 1-800-822-2834.
2006 AUDI A8
Manufacture Dates: 06/01/2005 - 06/30/2006
Potential Units Affected: 5902
Defect Description:
ON CERTAIN VEHICLES WHERE A WEAK BATTERY EXISTS, IT IS POSSIBLE THAT A LOW VOLTAGE CONDITION COULD CAUSE THE AIR BAG CONTROL UNIT TO IMPROPERLY SET A FAULT CODE. IF THIS OCCURS, THE PASSENGER SIDE FRONTAL AIR BAG WILL BECOME DEACTIVATED. HOWEVER, BOTH THE AIR BAG WARNING LIGHT IN THE INSTRUMENT CLUSTER AS WELL AS THE 'PASSENGER AIR BAG OFF' TELLTALE IN THE CENTER OF THE INSTRUMENT PANEL WILL ILLUMINATE AND PROVIDE VISUAL WARNING TO THE DRIVER.
Consequence:
IF THE CASE OF A FRONTAL CRASH, THE PASSENGER SIDE FRONT AIR BAG WOULD NOT DEPLOY WHICH COULD CAUSE INJURY TO THE SEAT OCCUPANT.
Action:
DEALERS WILL UPDATE THE AIR BAG CONTROL MODULE SOFTWARE. THE RECALL BEGAN ON DECEMBER 5, 2006. OWNERS MAY CONTACT AUDI AT 1-800-822-2834.
2006 AUDI A8 L
Defect Description:
Consequence:
Action:
2006 AUDI A8 L W12
Defect Description:
Consequence:
Action:
2006 AUDI A3
Defect Description:
Consequence:
Action:
2006 AUDI A3
Defect Description:
Consequence:
Action:
2006 AUDI A6 AVANT
Defect Description:
Consequence:
Action:
2006 AUDI A8
Defect Description:
Consequence:
Action:
2006 AUDI A8
Defect Description:
Consequence:
Action:
2006 AUDI A8 L
Defect Description:
Consequence:
Action:
2006 AUDI A8 L W12
Defect Description:
Consequence:
Action:
#25
Service Bulletins for 2007 Audi
2007 AUDI A3
Bulletin Number: TSB-01-08-04
AUDI: 01 MIL ON, ENGINE SPORADICALLY RUNS ROUGH. THIS CONDITION WILL NOT CAUSE STALLING. *PE
2007 AUDI A3
Bulletin Number: 28 08 02
BRIEF ENGINE STUMBLE WHILE DRIVING AT MODERATE VEHICLE SPEED. *NJ
Bulletin Number: TSB-28-08-08
AUDI: BRIEF ENGINE STUMBLE WHILE DRIVING. WHILE CRUISING AT MODERATE VEHICLE SPEED, ENGINE STUMBLE, SUDDENLY, FOR APPROXIMATELY 1 SECOND. ENGINE FUNCTIONALITY IS OTHERWISE NORMAL AND NO OTHER SYSTEMS PRESENT. *PE
2007 AUDI A4
2007 AUDI A4 CABRIOLET
Bulletin Number: TSB-19-09-04
AUDI: SERVICE RADIATOR FANS. THIS RVU HAS BEEN PROACTIVELY RELEASED TO PREVENT THE FOLLOWING CONDITION FROM OCCURRING IN THE VEHICLE: AFTER SWITCHING OFF THE ENGINE, THE RADIATOR FAN MAY CONTINUE TO RUN UNTIL THE BATTERY IS COMPLETELY DIS
Bulletin Number: TSB-24-09-08
AUDI: ENGINE WILL NOT START WITH POSSIBLE MIL/EPC ON (P0087, P0088, P310B). ENGINE DOESN'T START. THE FOLLOWING DTC ENTRIES MAY BE LOGGED IN THE FAULT MEMORY INDIVIDUALLY OR IN COMBINATION: FUEL RAIL/SYSTEM PRESSURE TOO LOW-P0087; FUEL RA
2007 AUDI A6
PART1
2007 AUDI A3
2007 AUDI A3
2007 AUDI A4
2007 AUDI A6
PART1
#26
2007 AUDI A6 AVANT
Bulletin Number: 970704
RADIATOR COOLING FAN HARNESS REROUTE. *KB
2007 AUDI A8
Bulletin Number: 01012007
REPLACEMENT OF OWNER'S MANUAL. *KB
RVU - SOFTWARE UPDATE OF INSTRUMENT CLUSTER FOR INTERMITTENT OIL PRESSURE WARNING LIGHT (CC). *NJ UPDATED 2/14/08. *NJ
Bulletin Number: 0709
OUTSIDE DOOR HANDLE IS STICKING. *NJ
Bulletin Number: 240706
MIL ON, ENGINE MAY RUN ROUGH AFTER COLD START (DTC'S FOR MISFIRE, P0300 - P0306, IN ECM). *KB
Bulletin Number: 280708
MIL ON (DTC'S FOR CMP SENSORS IN ECM). *NJ
Bulletin Number: 28 08 03
MIL ON (DTC'S FOR CAM POSITION SENSOR). *NJ
Bulletin Number: 390702
RVU - 2007 AUDI Q7 CHECKING REAR AXLE DIFFERENTIAL (CE). *NJ UPDATED 4/15/08. *NJ
Bulletin Number: 39 08 01
TRANSFER CASE LEAKS. *NJ
Bulletin Number: 8
REFLASH FOR INSTRUMENT CLUSTER. *KB
Bulletin Number: 940606
LIGHT FAILS COMPLETELY ON LEFT OR RIGHT SIDE. FAULT CODES FOUND IN THE CENTRAL ELECTRONICS CONTROL UNIT. *KB
Bulletin Number: 970707
TRAILER TOWING, WIRING AND TIPS. *KB
Bulletin Number: TSB-28-07-08
AUDI: MIL ON (DTCS FOR CMP SENSORS IN ECM). DURING ENGINE STARTING PHASE, ELECTRICAL CURRENT NEAR THE ENGINE WIRING HARNESS CAN CREATE ELECTRICAL INTERFERENCE TO THE BANK 2 CMP SENSORS G163 AND G301. ELECTRICAL INTERFERENCE ONLY AFFECTS
Bulletin Number: TSB-39-07-02
AUDI: RVU-CHECKING REAR AXLE DIFFERENTIAL (CE). THIS RVU HAS BEEN PROACTIVELY RELEASED TO PREVENT THE FOLLOWING CONDITION FROM OCCURRING IN THE VEHICLE: THE REAR AXLE DIFFERENTIAL MAY EXHIBIT A HIGH DEGREE OF WEAR AFTER A SHORT PERIOD OF S
Bulletin Number: TSB-39-07-03
AUDI: CHECKING REAR AXLE DIFFERENTIAL (CE). SOME VEHICLES MANUFACTURED WITHIN A SPECIFIC PERIOD, THE REAR AXLE DIFFERENTIAL MAY HAVE BEEN FITTED WITH NON TEMPERED BEVEL GEARS, WHICH CAN EXHIBIT A HIGH DEGREE OF WEAR AFTER A SHORT PERIOD O
Bulletin Number: TSB-43-08-17
AUDI: IMMEDIATELY AFTER THE VEHICLE IS STARTED, THE AIR SUSPENSION LOWERS THE VEHICLE TO ITS LOWEST POSSIBLE POSITION. THE AIR SUSPENSION WARNING LIGHT BLINKS. *PE
Bulletin Number: TSB-57-07-09
AUDI: OUTSIDE DOOR HANDLE IS STICKING EXTERIOR DOOR HANDLE STICKS IN THE OPEN POSITION AFTER DOOR IS OPENED. FRICTION BETWEEN THE LOCK CYLINDER TRIM AND THE DOOR HANDLE. *PE
Bulletin Number: TSB-90-07-07
AUDI: RVU-SOFTWARE UPDATE OF INSTRUMENT CLUSTER FOR INTERMITTENT OIL PRESSURE WARNING LIGHT (CC). ENGINE OIL PRESSURE WARNING LIGHT COMES ON IN THE INSTRUMENT CLUSTER WHEN THE ENGINE IS INITIALLY STARTED. THE DOES NOT COME ON AGAIN IF TH
Bulletin Number: TSB-90-07-08
AUDI: RVU-SOFTWARE UPDATE OF INSTRUMENT CLUSTER FOR INTERMITTENT OIL PRESSURE WARNING LIGHT (CC). *PE
2007 AUDI Q7
Bulletin Number: 24-08-26
AUDI: POOR PERFORMANCE BECAUSE OF LEAK IN VACUUM SYSTEM. POOR ENGINE PERFORMANCE BECAUSE OF INOPERATIVE INTAKE MANIFOLD TUMBLE FLAPS OR AIR FILTER BOX POWER FLAP. *PE
2007 AUDI RS4
2007 AUDI RS4 CABRIOLET
2007 AUDI RS6
2007 AUDI S4
2007 AUDI S4 CABRIOLET
2007 AUDI S6
2007 AUDI S8
Bulletin Number: 690708
SEAT BELTS RETRACT SLOWLY AFTER UNBUCKLING. *NJ
2007 AUDI TT
Bulletin Number: TSB-69-07-08
AUDI: SEAT BELTS RETRACT SLOWLY. DRIVER/PASSENGER SEATBELT RETRACTS SLOWLY AFTER UNBUCKLING. THIS CONDITION DOES NOT AFFECT SEATBELT OPERATION. THE SEATBELT IS ROUTED BACK TO THE REEL IN SUCH A WAY THAT THE SPEED OF RETRACTION IS SLOWED
PART2
2007 AUDI A8
Bulletin Number: 8
2007 AUDI Q7
2007 AUDI RS4
2007 AUDI RS6
2007 AUDI S4
2007 AUDI S6
2007 AUDI S8
2007 AUDI TT
PART2
#27
Recalls for 2007 Audi
2007 AUDI A3
Defect Description:
Consequence:
Action:
2007 AUDI A6 AVANT
Manufacture Dates: 01/01/2006 - 07/31/2007
Defect Description:
Consequence:
Action:
2007 AUDI A8
Defect Description:
Consequence:
Action:
2007 AUDI Q7
Manufacture Dates: 12/01/2005 - 07/31/2007
Defect Description:
Consequence:
Action:
2007 AUDI A3
Defect Description:
Consequence:
Action:
2007 AUDI A6 AVANT
Defect Description:
Consequence:
Action:
2007 AUDI A8
Defect Description:
Consequence:
Action:
2007 AUDI Q7
Defect Description:
Consequence:
Action:
#28
Service Bulletins for 2008 Audi
2008 AUDI A3
Bulletin Number: 100702
AVOIDING DAMAGE TO HALDEX CLUTCH AND FINAL DRIVE. *NJ
Bulletin Number: TSB-24-09-24
AUDI: ENGINE CONTROL MODULE UPDATE (CM/24M6). THIS RVU HAS BEEN RELEASED TO ASSURE THAT ALL VEHICLES HAVE LATEST ECM SELF DIAGNOSIS UPDATE INSTALLED. NO COMPLAINTS ASSOCIATED WITH SOFTWARE UPDATE. *PE
2008 AUDI A3
Bulletin Number: B-23D6-C2
AUDI: SOFTWARE UPDATE TO SUSPENSION CONTROL AND ADD SUNROOF TORX TOOL. *PE
Bulletin Number: TSB-94-09-31
AUDI: XENON HEADLIGHT FLICKERS OR IS INOPERATIVE ON ONE SIDE (DTC 00978 OR 00979). XENON ON ONE SIDE FLICKERS OR IS INOPERATIVE INTERMITTENTLY OR PERMANENTLY); XENON BULBS WERE MANUFACTURED BY PHILIPS; DTC 00979 (RIGHT LOW BEAM HEADLIGHT
2008 AUDI A4
2008 AUDI A4 CABRIOLET
Bulletin Number: 92 08 01
RAIN-SENSING WINDSHIELD WIPERS, ERRATIC OPERATION. *NJ
Bulletin Number: 94-08-10
AUDI: XENON HEADLIGHTS HIGH BEAM CAN NOT BE ACTIVATED. LIGHT BULB SYMBOL AND MESSAGE LEFT (OR RIGHT) MAIN BEAM HEADLIGHT IS SEEN IN THE INSTRUMENT CLUSTER. *PE
Bulletin Number: 97 08 01
RVU - 2008 S5 GROUND WIRE (CG) - IF THE GROUND WIRE IS PINCHED OR DAMAGED, WATER INTRUSION OR CORROSION COULD OCCUR. *NJ
Bulletin Number: SB-57-09-07
AUDI: ONE OR MORE DOOR HANDLE TOUCH SENSORS CANNOT BE USED TO UNLOCK THE VEHICLE DOORS; THROUGH DIAGNOSIS IT HAS BEEN DETERMINED THAT A DOOR HANDLE TOUCH SENSOR MUST BE REPLACED; OTHER WISE, THE VEHICLE LOCKS FUNCTION NORMALLY, SUCH AS WHE
Bulletin Number: TSB-90-09-13
AUDI: FUEL GAUGE DOES NOT REFLECT FUEL TANK IS FULL. THE FUEL GAUGE DOES NOT SHOW FULL EVEN THOUGH THE TANK IS COMPLETELY FILLED. THIS MAY OCCUR AFTER THE VEHICLE HAS BEEN TRANSPORTED BY A VEHICLE TRANSPORT TRUCK. *PE
Bulletin Number: TSB-94-10-10
AUDI: XENON HEADLIGHT FLICKERS OR IS INOPERATIVE ON ONE SIDE (DTC 00978 OR 00979). ONLY PHILIPS BRAND XENON BULBS ARE AFFECTED. *PE
Bulletin Number: TSB-97-08-01
AUDI: GROUND WIRE. THIS RVU HAS BEEN PROACTIVELY RELEASED TO PREVENT THE FOLLOWING CONDITION FROM OCCURRING IN THE VEHICLE: IF THE GROUND WIRE IS PINCHED OR DAMAGED, WATER INTRUSION OR CORROSION COULD OCCUR. *PE
2008 AUDI A5
Bulletin Number: TSB-01-09-07
AUDI: DURING THE COLD START PHASE OF THE ENGINE, THE ENGINE MAY RUN ROUGH. MISFIRE DTCS (P0300, P0301, P0302, P0303, P0304, P0305 OR P0306) MAY BE STORED IN THE ECM. SOFTWARE UPDATE MAY BE NECESSARY. UPDATE SOFTWARE IN DEVELOPMENT.
PART1
2008 AUDI A3
2008 AUDI A3
2008 AUDI A4
2008 AUDI A5
PART1
#29
2008 AUDI A6
2008 AUDI A6 AVANT
2008 AUDI A8
2008 AUDI Q7
Bulletin Number: JW /17C5
CUSTOMER SATISFACTION CAMPAIGN CIRCULAR - 2008 MY AUDI R8 ENGINE AND TRANSMISSION CONTROL MODULE SOFTWARE UPDATE. CSC WAS RECEIVED. *NJ
Bulletin Number: TSB-20-09-10
AUDI: FUEL GAUGE READS EMPTY AFTER REFUELING (DTCS 00438, 00771, 00439, OR 00251). DUE TO THE OF SECTIONS OF CABLE IN THE AREA OF THE 2 PIN PLUG IN CONNECTIONS (INSIDE THE FUEL TANK) BETWEEN THE FUEL TANK LOCKING FLANGES AND THE FUEL GAUG
2008 AUDI R8
2008 AUDI RS4
2008 AUDI RS4 CABRIOLET
2008 AUDI RS6
2008 AUDI S4
2008 AUDI S4 CABRIOLET
Bulletin Number: 24 08 07
MIL/EPC WARNING LIGHTS ON (P0101, P0113, P2177, P2179). *NJ
Bulletin Number: 24-08-30
AUDI: MIL ON (DTC P2146-P2157 FOR FUEL INJECTOR SUPPLY VOLTAGE). ENGINE RUNS ROUGH BUT DOES NOT STALL. *PE
2008 AUDI S5
2008 AUDI S6
2008 AUDI S8
Bulletin Number: 0703
3.2L REROUTE ENGINE WIRING HARNESS(I7). *NJ
Bulletin Number: 0713
RVU - 3.2L REROUTE ENGINE WIRING HARNESS (I7). *NJ
Bulletin Number: 0714
REAR TURN SIGNAL OR BACKUP LIGHT DOES NOT WORK ON ONE SIDE. *NJ
Bulletin Number: 970703
RVU - 3.2L REROUTE ENGINE WIRING HARNESS. *KB
Bulletin Number: TSB-94-07-14
AUDI: REAR TURN SIGNAL OR BACKUP LIGHT DOES NOT WORK ON ONE SIDE. MESSAGE CONCERNING A LIGHT BULB IS DISPLAYED IN THE DRIVER INFORMATION DISPLAY. THE MESSAGE MAY BE STATIC OR SPORADIC. THE BACKUP LIGHT AND/OR THE TURN SIGNAL ON ONE SIDE
Bulletin Number: TSB-97-07-13
AUDI: RVU-3.2L REROUTING ENGINE WIRING HARNESS (17). REQUIRED VEHICLE UPDATE IS IN EFFECT FOR 15 MONTHS FROM DATE OF PUBLICATION. AFTER THAT DATE, THIS RVU WILL EXPIRE AND NO LONGER BE IN EFFECT. WIRING TO THE SECONDARY AIR SOLENOID MUS
2008 AUDI TT
PART2
2008 AUDI A6 AVANT
2008 AUDI A8
2008 AUDI Q7
2008 AUDI R8
2008 AUDI RS4
2008 AUDI RS6
2008 AUDI S4
2008 AUDI S5
2008 AUDI S6
2008 AUDI S8
2008 AUDI TT
PART2
#30
Recalls for 2008 Audi
2008 AUDI A3
Defect Description:
Consequence:
Action:
2008 AUDI A6 AVANT
Defect Description:
Consequence:
Action:
2008 AUDI Q7
Defect Description:
Consequence:
Action:
2008 AUDI TT
Manufacture Dates: 01/10/2007 - 08/26/2009
Defect Description:
Consequence:
Action:
2008 AUDI TT
NHTSA Campaign ID: STRUCTURE:BODY:ROOF AND PILLARS
Manufacture Dates: 01/05/2007 - 02/20/2007
Potential Units Affected: 720
Defect Description:
VOLKSWAGEN IS RECALLING 720 MY 2008 AUDI TT COUPE VEHICLES. THESE VEHICLES WERE PRODUCED WITH C-PILLAR TRIM COVER CLIPS THAT DO NOT PROVIDE ADEQUATE RETENTION. IN THE EVENT OF A DEPLOYMENT OF THE REAR PYROTECHNIC SAFETY BELT, THE C-PILLAR TRIM COVER MAY BECOME DETACHED FROM THE SHEET METAL DUE TO LOW RETENTION FORCE OF THE TRIM CLIP.
Consequence:
THE DETACHED TRIM COVER COULD POSE A RISK OF PERSONAL INJURY FOR VEHICLE FRONT SEAT OCCUPANTS.
Action:
DEALERS WILL INSTALL AN IMPROVED CLIP ON THE AFFECTED VEHICLES. THE RECALL BEGAN ON MARCH 7, 2008. OWNERS MAY CONTACT VW/AUDI AT 1-800-822-2834.
2008 AUDI TT ROADSTER
Defect Description:
Consequence:
Action:
2008 AUDI A3
Defect Description:
Consequence:
Action:
2008 AUDI A6 AVANT
Defect Description:
Consequence:
Action:
2008 AUDI Q7
Defect Description:
Consequence:
Action:
2008 AUDI TT
Defect Description:
Consequence:
Action:
2008 AUDI TT
Defect Description:
Consequence:
Action:
Defect Description:
Consequence:
Action:
