Autothority Chipped ECU Swap - any downside? (repost)
Guest
Posts: n/a
)Reposting from below into it's own thread)<p>I just spoke with Autothority (Pat I think) and they advised that they will have chipped ECUs for demo and sale purposes (through VW Sport, one of their distributors) at an upcoming N.E. A4 event. I asked if there was any dowside to purchasing a chip via an ECU swap versus having them add the chip to your stock ECU. Hestated that unlike Porsche, where the ECU is coded with your specific car's VIN, paint color, etc., Audi's ECUs are interchangeable and not vehicle specific.<br>He also said that the type of ECU (e.g., 'M' vs. 'P') did not really matter since a VAG tool used to install their chip would reprogram everything anyway.<p>Is this true? I may have misunderstood the details but I definitely know that they plan on selling their chip via an ECU swap - any downside?<p>Thanks,<br>Chris L.
Guest
Posts: n/a
I believe that is DOES matter wheather its an "M", "N", or a "P".
At least that is my understanding from every other Chip tuner on the market. The part number must match! The rev number is the one that does not matter if you revise the code. I would not trust a company that is giving out bad information.<p>
Guest
Posts: n/a
copied this from the archives....
When a new ECU is installed it must be programmed with shop code information,tip or manual,q or fwd.<br>A VAG 1551/1552 service tool can read the codes on an existing ecu and write codes on a "virgin" ecu and rewrite code on an existing ECU as well.<br>SO, if you want to swap out an unmodified ECU for one that has been chipped, you must first read the codes on the old ECU, swap the puppies then recode<br>the new one. This is explained in Audi's technician service manuals.
übertek
01-23-2006 05:30 AM
choward
10-26-2001 11:40 AM
Skydive69
11
06-26-2001 12:31 PM
mike
06-03-1999 11:02 PM
