Basic Maintenance to be done at 80K??
oil
oil filter
spark plugs
air filter
cabin pollen filter
lube sunroof guide rails/door hinges
checking engine/trans mounts condition
things not to do with 80k but doing:
re-center snub (vibration when in gear and stopped)
oil dipstick tube replace (cracked and broken to ****)
And hopefully to top it off, all of this with a beautiful new windshield and lower cowling! ;-)
-pcv and vacuum hoses(3mm)
-oil and filter(MANN)
-spark plugs
-air & cabin filter
-driveline mounts(if original):trans, motor, diff
-flush brake and clutch fluid
-change diff and trans oil
-clean out throttle body
-check wheel bearings
-check suspension and replace as necessary(control arms, shocks, mounts).
-set tire pressures
-lubricate sunroof tracks with appropriate grease
-update the coolant temp sensor if done yet.
-check coolant tank for cracks
-check battery and charging levels to see if they are within factory spec.
Here are a few common things I go through with our 30v.
