Brake issue (long)
Brake issue (long)
I got new pads/rotor's recently for my front brakes, after a few weeks now when I apply a small amount of presure on the pedal(Slow breaking) I can feel a bit of chatter. Under heavy/firm braking cant feel any chatter.
But the main issue is when I drive in slow traffic or slow at an intersection,I apply the brake, I get to nearly the stop position and just before the car stops I get a vibration in the pedal, I can also hear a noise from the front left wheel when it hapens (similar to the feeling you get in the pedal when ABS kicks in).
If I stop firmly/moderatly to a halt at an intersection it dosnt hapen, only under light breaking?
Anyone else had this, mabe early stages of a sticking caliper or something???
Thanks in advance..
Thanks in advance..
that use to happen to my a4 turned out to have a error code..
saying it was the abs modual malfunction so i pulled the fuses 3 years ago and just been with out since then .. even had 4 days on track and works great.. only you have the abs and brake light always on.. i dont even notice it anymore..
Re: Brake issue (long)
Yup, rattling knocking & chattering up to every stop sign.
Sunday morning job this weekend to clean the sensors, all advice seems to point in that direction. Will be most disapointed if it's a little more serious.
All good now...
It was the front left sensor I VAG'ed it and there was a stlight variation in latency between that one and the rest of them , so I pulled out the sensor, cleaned it and its all working fine now.
Thanks for the help
Thanks for the help
audiDTM
11-11-2005 06:20 AM
Chuck-S4
10-08-2004 01:00 PM
Scot J
06-20-2002 05:16 AM
Greg "S" (not Slater)
08-19-1999 08:20 AM
