Brake pads warning light
Good Day
I recently changed brake pads both front and rear on an Audi A4 2000. Now after changing the pads, the warning light has not switched off as an indication that new pads have been installed.
What could be the reason for this and how can i resolve it.
Thanks
Thanks
Can we assume the light was on before you changed the brake pads?
If so, then you need to replace the sensor that wore through and turned on the light.
If not, then I assume you damaged one, or more, of the sensors changing the pads.
vellnueve
01-17-2010 03:00 PM
Sacer
01-09-2003 01:02 PM
