Bubbling expansion tank
2001 B5 1.8. Noticed that there is some sort of bubbling occurring at the top hose in the coolant expansion tank. Just had the coolant flange replaced (thinking of going aluminum next time if it fails again). Thought that might fixed it but it didn't. Any idea as to what the reason is?
If the coolant is constantly bubbling then something is pushing gas under pressure into the coolant. You are not going to like it, but the most likely is the head gasket. I would go get a leak down tester and pressurize the cylinders and look for the bubbling when each cylinder is under pressure. If it does you have verified the problem and can go from there.
Originally Posted by David.Norton
(Post 24960572)
