burning coolant and engine temp light
So I got a 99 a4 2.8 gifted to me in really bad shape. It sat for three years because it was leaking oil from just about everywhere it could be and wouldn't pass smog because of a bad abs unit. i just went ahead and did a full timing belt job along with all seals, water pump, thermostat ect as well as valve cover seals and everything else.
I got it back together and it fires up/ runs good but it smells like burning coolant and the red engine temp light comes on after about 30 seconds.
Also I screwed up a little bit. After reasembly I added coolant but I did not burp the coolant system. i then started the car and let it run for about a minute before shutting it off when the light came on. i then burped the system but the light still comes on and it still smells like burning coolant
My only thought is a bad thermostat? or that I messed something up with the initial start.....
Thoughts?
Thoughts?
If the light comes on before it could possibly be hot then I would verify the sensor. I would likely just replace the coolant temp sensor that is located below the MAF plenum. This one is cheap, easy to swap and causes many issues related to feeding incorrect engine temp. Search this forum for CTS issues.
Yea that's the one. I also just put in another new thermostat/ did a really good flush of the whole coolant system and still no luck... The smoke has gone away for the most part and the car seems to run fine but the CTS light still comes on after about 30 seconds...
Canon
04-04-2009 05:42 PM
gregpurnell
Audi 100 / A6 (C4 Platform)
08-09-2007 08:51 AM
Redaudifor
08-01-2006 05:15 PM
logan15xx
12-26-2005 08:49 PM
Avant Sport
12-09-2003 08:51 PM
