Car seeming to run slightly hotter. Any suggestions.....
my 2000 1.8T Avant recently began running just slightly hotter on the water temp and oil temp guages. The temperature has not risen significantly, and I just had a full timing belt/water pump replacement done at ECS. Any ideas what could be causing this?
Thermostat?
if you did thermostat..
there are 2 avalible. 183° and 193°.
you might want to look into a coolant system flush
