Car won't start. No codes. Ran output test and seems to be fuel pump...
Is there any tricks to getting this thing started with a faulty fuel pump? Just thought I would take a shot in the dark to see.
Check the fuel pump relay - it's probably not the fuel pump itself.
I'm not sure where the relay is. I did check the fuses however. Are those the relays?
#6 in the relay panel
OK. I pulled up my ebahn software and it said to remove the kick panel for the relay. I removed a ..
panel and I see a bunch of wires and plugs but it doesn't look anything like the picture in ebahn. Am I looking in the right place? All I see is 3,3,3,3. There aren't 6 plugs in a row.
you're probably looking at the fuse panel, there's also a relay panel under there.
You have to look at the relay diagram to see which one is #6.
Well, it was the relay. Got the car running. Now I need to go buy a new relay. Thanks for the help.
Glad to hear - you're welcome!
