car won't start wtf !
Old 06-12-2012, 07:24 AM
97beautifulaudi's Avatar
Default car won't start wtf !
1997 audi a4 2.8..........so i had the car parked for 4 days waiting on a coolant temperature sensor to come in. it came in i replaced the sensor and the car would not start unless i kept pumping gas in and after a good thirty seconds. then once started it would blow a quick cloud of white smoke then idle at 1100 rpm and sputter and die when i go to take off. i then thought it was the sensor so i unplugged it and nothing has changed. its been two days now. the coolant and oil look fine and i hear the fuel pump turn on...also i double checked all my hoses and everything is connected.....
Old 06-12-2012, 09:24 AM
jseklund's Avatar
Scan with a vag-com
Old 06-12-2012, 09:43 AM
i scanned it with the autozone scanner and nothing came up
Old 06-12-2012, 12:42 PM
Prospeeder's Avatar
Sounds like you may have broken, or dislodged a crank vent pipe, or the boot that goes to the throttle body, or something back there. It sounds like a big intake leak.
Old 06-12-2012, 05:11 PM
it was the crank vent pipe. thanks prospeeder
Old 06-15-2012, 07:13 PM
Prospeeder's Avatar
Originally Posted by Carter12
Could be several things, starter, ignition, dirty or loose battery connections.
覧覧覧覧覧覧覧覧覧覧覧覧覧覧
Audi airbag light
Yes because when the engine is cranking over fine its a starter or battery connections......jeese read the thing man, not only that it was solved already.
Alaskan4kq
12-26-2018 12:47 PM
Jason Michals
09-23-2012 09:20 AM
azfun38
04-17-2009 12:16 PM
MM120
12v V6 Discussion
21
03-19-2005 01:32 PM
cashguzzler
10-19-2004 08:15 AM
Quick Reply: car won't start wtf !
