CEL...what could be the problem?
Old Oct 5, 2007 | 05:20 AM
AudiRacerA4's Avatar
Default CEL...what could be the problem?
I don't have a CEL but i decided to vag my car yesterday and i pulled the code P0121 Throttle/Pedal Pos.Sensor A Circ Range/Performance (G69) implausible signal. What does this mean?
Old Oct 5, 2007 | 07:34 AM
Shard7's Avatar
Default TPS is probably worn
The sensor is a bit like a volume control that senses the throttle position. After many years of use, the track can wear (especially if the throttle spends a lot of time in a smaller range), resulting in erratic readings (hence this code shows up).
Other possibility is a loose connection between the ECU and the sensor.
Old Oct 5, 2007 | 12:47 PM
Default Re: TPS is probably worn
where is the TPS located?
Old Oct 6, 2007 | 05:52 AM
Shard7's Avatar
What year and engine?
ricekikr
Oct 29, 2010 05:23 AM
alexwonggjy
Dec 14, 2009 04:16 PM
ccomengee86
Audi allroad
Feb 11, 2009 03:09 PM
coloradobax
VAG-COM Discussion
Jan 18, 2005 03:30 PM
Black Sunshine
Mar 31, 2003 05:55 PM
