Center console removal! Can't get climate control off / out
Almost got the center console removed, but it seems that something near the ashtray or the climate control is restricting me from removing it. Any ideas would be greatly appreciate it. Btw: its a an 2000 model, with the symphony head unit.
I removed tha radio aready, just can't get the climate conrol out and I don't see
Any screws holding it!! Anyone someone, need help.. I see two screw under it, but that looks like it holding the ash tray down..
not screws, clips
There's some old threads from Greyhound guy regarding this.
Basically, you need to stick a flat screwdriver in at the top of the CC and bottom of the CC (Centered under the heated seat switches, if you have them) and pop one side of the CC out, then the other.
You can see the top clips if you look carefully, there's an identical set below the CC, put a screwdriver in between the ashtray and the CC...
HTH.
Steveo
HTH.
Steveo
Removed mine last night... on my 98.5
1st off, did you remove the rear console yet? And are you trying to get the actual climate control unit out of the dash? I only removed the consoles, so I don't know if any of this will help, but there was a "hidden" nut on the driver side of the front console near the gas pedal kinda. You have to remove a small plastic cover to get to it, then work the console over the bolt.
Let me know where you are at in the removal..
Jack88
13
05-10-2021 04:32 PM
timsias
04-04-2006 07:14 PM
Kirath ¾-B0§t0n
11-05-2002 10:36 AM
CharlieGSanD
11-03-2001 03:48 PM
