Central Locking System
Old Jun 1, 2004 | 02:20 PM
jm3's Avatar
jm3
New Member
Default Central Locking System
1998.5 A4 1.8
I cannot lock all of my doors by using either the remote or the key. The driver door will lock with the key,the horn will beep, and the alarm is activated but no other door will lock. I can then only use the key to unlock the door. Is their a central unit and if there is where is it located and can I replace it without going to the dealer? Did any of you ever have this problem? Thanks.
Old Jun 1, 2004 | 04:23 PM
David.Norton's Avatar
Default Sounds like a bad pump...
which is also the central unit, you will find it behind the passinger arear wheel well in the trunk, just pull the cover back. It is very easy to replace.
dlove
May 13, 2014 01:35 AM
EricBss7_CT
Oct 25, 2006 03:19 PM
nickp201
May 25, 2005 08:11 AM
jrul
May 18, 2005 05:44 PM
frank34
Feb 18, 2004 03:55 AM
