Check engine light?????
Guest
Posts: n/a
Had that a few months ago (more)
Was home in Burlington, VT for the holidays and some nights the temp. hit -10 degrees F. One morning after a particularly cold night my car behaved exactly as you describe. Very rough idling(obvious cylinder misfiring) with the flashing check engine light. I quickly recycled the engine again and still noticed the rough idle and check engine light. Finally, after letting the car sit for about 10 minutes with engine off, I restarted and the rough idle was gone. The check engine light remained on, however.
A quick call to my dealer's service dept. revealed that this is relatively common with the A4. As long as the rough idle doesn't come back, the check engine light will go off in a day or two and all is good. Haven't seen the rough idle since.
My theory is that a small amount of water may have gotten into my gas tank through condensation in the summer months. On such a cold night, the water froze and blocked my gas line resulting in cylinder misfires.
99.5 TQMS w/ 1.0 bar APR (ver 3 in the mail now!)
Guest
Posts: n/a
Missfire, carbon, get it fixed.
Sounds to me like a 2.8 that's carboned up. If so the dealer should: Install a hotter 92°c thermostat, special, hotter spark plugs (retail $28 each), decarbon the valves and change the oil. Covered uner 3/50 warranty. Don't let anyone tell you tha light will go out in a few days (that's not a fix). Get it fixed. If not, the next step is no start. Call a tow truck. Your choice.
Jake
MDAudi
A4 (B9 Platform) Discussion
03-29-2019 04:44 PM
