check engine light
Old Feb 23, 2006 | 05:19 PM
poorsche199's Avatar
New Member
Default check engine light
check light came on yesterday code was:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35 - 00 --
Anybody have any ideas? thanks in advance
Old Feb 23, 2006 | 05:26 PM
ChooChooNongNongHead's Avatar
is your sap working? could be a bad vacuum line or combi valve.
Old Feb 23, 2006 | 05:37 PM
New Member
Default Re: is your sap working? could be a bad vacuum line or combi valve.
there's a real high pitched noise sometimes, but it's been there for a couple years now at idle that might be the sap. any way to test the sap?
Old Feb 23, 2006 | 05:47 PM
Default on a 2.8 it's located on pass side lower front of engine..it operates for about 20-30 seconds
on cold starts. The hoses tend to break. There is a way to activate it with the VAG but I forget how. I have to step out right now but I will have to search anyway because I have a problem with my air pump too. One of the rivets broke on mine and it is leaking from the seam of the pump...I think this is an unusual problem though.
Old Feb 23, 2006 | 06:03 PM
New Member
Default just got the car back from timing belt service...
it's a 1.8, during that is it neccessary to mess with any of the secondary air system?
Old Feb 23, 2006 | 06:25 PM
not really but definitely possible that they may have removed or pinched one of the hoses
Old May 15, 2007 | 12:26 PM
1999Audi's Avatar
Default is there a way to activate it with the VAG ?
Im going to replace all rivets with nuts&bolts
because there is only two left ;-)
apquest
May 19, 2008 05:28 PM
Bariukas
Dec 15, 2004 10:06 PM
gcheddar
Sep 10, 2004 01:10 PM
bwead
Sep 15, 2003 11:59 AM
