Coilover Question...
Old Oct 12, 2001 | 07:05 AM
Joe (twitch, twitch)'s Avatar
Junior Member
Default Coilover Question...
Im thinking about H&R coilovers, but I have a few issues that I think should be addressed first...
I have factory sport suspension, which is not quite as sporty as I would like. The Intrax anti-sway kit has helped with body roll, but I think lowering is still necessary. My problem is that I live in German Village in Columbus and all the streets in my neighborhood are decrepid cobblestone. Is adding H&R coilovers going to make cobblestone driving even more unbearable???
Old Oct 12, 2001 | 07:57 AM
no_motorrad's Avatar
New Member
Default Just got Koni coilovers installed (more)
To answer your question, I just drove mine back the other night over lot's o' cobblestones, back roads and highways. The height was two fingers in back and not quited three in front, lower than stock sport suspension.
IMO, the smaller bumps like c-stones and rough pavement get soaked up better than stock suspension because the shocks are so much better. However, having much stiffer settings and less travel, the car "followed" any larger dips in the pavement rather than just soaking it up as before (I had non-sport stock setup).
I just moved the back up by about 3/8" and the difference is noticeable.
BTW, Tirerack.com sells the complete adjustable Koni suspension at $973.
My advice would be that just replacing the shocks with Bilsteins or Konis will get you 95% of what you want. If you've got the budget, go for the coilovers, but ask yourself seriously if you'll really like having the car much lower than it is now over the long term. But, if you like to tinker with stuff like this, then go for it.
Good Luck!
Old Oct 12, 2001 | 08:05 AM
Junior Member
thanks man
Old Oct 12, 2001 | 08:55 AM
mj42jackson's Avatar
Default that's an even better reason to get coilovers...
fully adjustable. especially konis. set it where it feels best.
2R8Sand1RS4
Sep 16, 2001 09:58 PM
TraitorS4
14
Aug 27, 2001 07:42 AM
18TQM Ken
Jul 6, 2001 11:27 AM
CzarS4
Apr 19, 2001 08:12 PM
pcw
Nov 9, 2000 02:55 PM
