Dual Mass Flywheel - slipping?
Old 10-20-2007, 08:41 AM
New Member
A4 drivin daughter's Avatar
Default Dual Mass Flywheel - slipping?
My daughter has a '97 A4 quattro w/1.8 tubo. We had the front axles changed. It drove fine for about one week. One morning she started the car put it into reverse and it would not move. We thought the clutch went out, so it was changed. (The old disk and pressure plate looked ok and not worn out.) The car worked fine for about one day, then it happened again. The clutch pedal seems fine, it sounds like it engages as you release the pedal, but the car will not move and a wurr is heard under the floor. This happens in all gears. After talking with a friend he thought that the dual mass flywheel may be able to slip and should be changed. Is this possible? or Is it likely something else? Thanks for any help.
Old 10-20-2007, 09:01 AM
fastbreak88's Avatar
Default Re: Dual Mass Flywheel - slipping?
you are supposed to change the flywheel each time you do a clutch as you can't really properly resurface a dual mass cost effectively.
Old 10-20-2007, 09:04 AM
n0yxl's Avatar
Default The DMFW develops "play" as it ages, I would think it'd be unlikely that it would slip though.
It incorporates stops so that the floating center *should* only move so far, but; I have seen interesting things happen to supposedly "failsafe" designs before.
Tech Guru
4Driver4's Avatar
Default Not to the degree you are saying.
If that was the case it would have fallen apart when they pulled it out.
Old 10-20-2007, 10:08 AM
Im@wesome~ out!'s Avatar
Default i doubt your clutch/dual mass are causing this problem
usually a clutch gives you a bit of warning...
master/slave don't make sense because you say you still get pedal feel... hmmm
through out bearing? no that had to be replaced when you did the clutch...
trans? yikes that would suck. but it makes more sense then flywheel.
What about the shifter mechanism? Is the car going into gear smoothly? Are you getting an actual grip onto the gear? Usually if your clutch goes you can't get into gear at all.... so.. i would guess your trans is shot or else WAIT
axles changed? that could be your problem right there... they may not be tight enough/spindles are slipping... the bolts fell out. That explains the whole problem...
Old 10-20-2007, 10:37 AM
Junior Member
tkarwin's Avatar
You have been had. Time to find a new mechanic.
Old 10-20-2007, 11:36 AM
Joey T
Guest
Posts: n/a
Default No.
You need to find the noise. Something is broken. did the same shop do the axles as did the clutch?
My bet is bolts backed out of the axle flange.
Old 10-20-2007, 01:37 PM
r3post... :P i had that at the end of my rant
Old 10-23-2007, 06:36 PM
New Member
Update and thanks for the help....It was my front axle comming out. It was not seated well. Car is working now and hopefully will for many more miles. So it wasn't a dual mass issue, it was just a dumb *** issue. thx
Standard Issue
03-05-2015 01:05 AM
xr4tic
Performance and Tuning
10
04-21-2004 08:59 AM
98.5_2.8
03-07-2002 09:30 AM
moke80q
03-02-2002 03:15 PM
Quick Reply: Dual Mass Flywheel - slipping?
