Coolent sensor issues, codes for sensor and gauge not working, changed sensor but didnt fix issue.
Old 12-11-2008, 07:23 PM
kkii9's Avatar
Default Coolent sensor issues, codes for sensor and gauge not working, changed sensor but didnt fix issue.
My temp gauge stopped working a while ago, it just reads "C" all the time, so I got a new sensor and replaced it. Afterwards, still no change as the gauge doesn't work and now I also have codes 17704 P1296 & 18062 P1659 Im assuming still from the sensor.
Is there another one that needs to be replaced or could it be possible the replacement was also faulty.
I noted once that there is another sensor that plugs into the lower radiator hose where it connects to the radiator. Should I change that sensor as well?
Thanks.
2001 A4 1.8t
Old 12-11-2008, 08:25 PM
Skribbs2000's Avatar
Default You replaced the ECT, correct?
ECT=Engine coolant sensor. The one on the lower drivers side radiator might be causing your CEL's but I dont want to say is it for sure. Is yous Auxiliary fan coming on? Heat work?
Old 12-11-2008, 09:08 PM
kkii9's Avatar
Yes replaced ECT, aux fan / heat works, do you know the pn for that other sensor?
Old 12-12-2008, 03:15 AM
Tech Guru
4Driver4's Avatar
VAG-COM is your friend.
Old 12-12-2008, 10:12 AM
kkii9's Avatar
Re: I got the codes...how else can it fix it as my friend?
Old 12-13-2008, 12:21 PM
Default here you go..
PN#-3219594816
$16
Old 12-15-2008, 12:37 AM
kkii9's Avatar
where did you find that ? cant find it on any of the online parts stores...
Old 12-15-2008, 02:54 PM
Sorry it was late I left out a few #'s.. but I was close!<ul><li><a href="http://www.autohausaz.com/search/product.aspx?sid=4rsygdvem4pyt4450x55e1fj&amp;make id=800002@Audi&amp;modelid=1008739@A4%20QUATTRO%20 &amp;year=1996&amp;cid=16@Cooling%20System&amp;gid =4768@Radiator/Auxiliary%20Fan%20Switch">Autohausa
grocery getter S3+
VAG-COM Discussion
11-19-2009 02:04 PM
Neo1130
07-14-2008 12:21 PM
red90q
01-30-2005 03:36 PM
illkid
06-24-2004 09:55 AM
egp320i
02-04-2004 09:04 AM
Quick Reply: Coolent sensor issues, codes for sensor and gauge not working, changed sensor but didnt fix issue.
