Custom Intake
Old Jul 15, 2002 | 06:37 PM
ungenant's Avatar
New Member
Default Custom Intake
i have a 98.5 1.8T, i am working on making my own custom cold air intake. i see alot of ppl that have a4's, put the filter in the lower ritght passenger grill. but i was thinking about putting it in the lower left grill rite in front of the intercooler. this will allow for a shorter amount of tubing to be used. also can i go directly to the engine intake since its a cold air?...or do i still have to go through the intercooler. i am also puzzled on what size tubing to use, 2.5 inch or 3.0 inch. 2.5 is better for smaller engines, but the 1.8 is turbo...any help or comments would be appreciated
Old Jul 15, 2002 | 08:27 PM
LaR H 88's Avatar
Elder Member
Default it would actualy be more tubing
the reason the intake's on the passenger side is because the turbo's right there. if you try to mount ur intake on the driver side...ur probably gonna run into some issues with fitting the actual filter in there along with making sure the piping doesn't run into anything. in my personal opinion...the filter placement is just fine as is...u just gotta shield it from the engine compartment.
Old Jul 15, 2002 | 08:46 PM
a4turbo18t's Avatar
Default You do not want to put it in front of the intercooler...
The intercooler needs that shot of cool air to lower the intake temps. Plus if you drive by a low line flood, it will suck up the water and guess where it goes: the motor! You do not want to replace your motor at that point. As for tubing size, it has to be at or larger than the diameter of the MAF sensor which is ~65mm.
Old Jul 18, 2002 | 12:05 PM
ungenant's Avatar
New Member
Default Re: it would actualy be more tubing
ok, so should i use the 3.0 inch piping?
McTTR
9
Jan 31, 2006 06:42 PM
lowflyingdolphin
Feb 23, 2005 07:13 PM
PitViper
12v V6 Discussion
12
Aug 12, 2003 09:06 AM
ByeByeA4 (AdamA418T)
Sep 25, 2002 07:14 PM
Obli
Sep 7, 2002 10:35 PM
