Door lock problems - Need help
I have remote central locking issue on my 98 B5 Audi A4.
I can lock and unlock using remote but only front Driver side is working properly. What should I do for other three doors?
I could hear pump working sound when I using remote. Should I change door actuators?
Thank you for your help.
No, other doors except Driver door are not locked and unlocked even I double click remote, push lock and unlock button inside and turned key twice.
The driver side door could lock and unlock as well with remote and inside lock and unlock button.
Thank you.
Thank you.
Troubleshooting info in the Bentley manual says that if the car has been parked for a lengthy time and/or after replacing the central locking system pump, the central locking system will not function properly until prompted repeatedly. Also, if you hear the pump run for more than 5 seconds there is a leak in the system.
Maybe someone here on the forum with experience with this issue will be able to give you some input. Let us know how it goes.
