Newb here charging issues question
Hi there
Im new here. i have recently acquired a 2001 A4 quattro 2.8lt
after i started driving it i noticed the on board voltmeter fluctuating between 10 and 12 volts. tested the voltage at the positive cable with car running got around 11.5 volts ( to me this indicates bad alt). so I went through the hell that is changing the alternator. immediately upon testing the new alt in the car the on board would go between about 10 and buried below 8 (uh oh) so today did some wheel bearings went to start the car and the battery was dead (this is the first dead battery so far) multimeter on the dead battery reads 4.5ish v jump start car meter reads 13.5ish for about a min then it begins to climb anywhere between 16.5 and 19v now this is where it stays (new alt is a bosch unit from a reputable parts store) once the voltage passes 16v i start to lose electronics in the car (gauges stop working tranny goes into limp mode)
So the questuion is any idea what cn cause this i suspect a bad cell in the battery a ground or bad alt
anyone ever run into this before?
Jay-S8
18
05-07-2021 12:50 PM
stormchaser1967
09-02-2015 09:02 AM
