Electrical Problems
Old Jul 26, 2004 | 11:08 AM
GeorgiaAudi's Avatar
New Member
Default Electrical Problems
I'm having electrical problems with my A4. My windshield wipers stopped working (I checked the fuses) Does anybody know what could be wrong?
Old Jul 26, 2004 | 11:21 AM
Digit@lex's Avatar
AudiWorld Expert
It might actually be the wiper motor.
Old Jul 26, 2004 | 11:28 AM
silver rain's Avatar
Default do your turn signals work?
if they do not its probably a relay
Old Jul 26, 2004 | 11:31 AM
New Member
Default Re: do your turn signals work?
Yes they do. So does the wiper fluid.
Old Jul 26, 2004 | 11:32 AM
New Member
Default Re: It might actually be the wiper motor.
Does that just stop working from one day to the next? I never heard any noise and there wasn't ever any slow movement....
Default ...
not sure then, i shorted a circuit a while back causing my wipers and turn signals to stop working, ended up being a relay but that is probably not your problem if everythign else still works.
Old Jul 26, 2004 | 11:34 AM
Digit@lex's Avatar
AudiWorld Expert
Default It's possible. Can you check to see if there is voltage at the motor?
This is all assuming you can get to it. It's also possible that the stalk itself is damaged.
New Member
Default Re: ...
I found out that the relay number is 271 location 5. Is that the same as the turn signal relay?
 Michael S. Palmer
Old Jul 26, 2004 | 11:35 AM
New Member
Default Re: It's possible. Can you check to see if there is voltage at the motor?
I'm not sure if I know how to do that.
Old Jul 26, 2004 | 11:52 AM
not sure, although i would assume so as only 1 of mine needed to be replaced...
AUDIMAN3
Audi 100 / A6 (C4 Platform)
Nov 21, 2008 11:42 AM
SchwarzS6
Jul 3, 2006 12:55 PM
acidrane-teh jeweler
Dec 24, 2005 01:05 AM
Audi200T5000S
Sep 25, 2005 05:19 PM
poontz13
Sep 22, 2002 08:14 PM
