Engine Noise
Old May 24, 2006 | 03:54 PM
dorsal fin's Avatar
New Member
Default Engine Noise
I am having a terrible noise come from my engine area every so often when I am at idle in stop and go traffic, and when I step on the gas the noise goes away, but it makes a release sound as I move on down the road. Has anyone had this problem, or possibly know what is causing it, my ECM is orange on my dash, and it seems performance is down a little bit. any help would be awesome
Old May 24, 2006 | 04:47 PM
dorsal fin's Avatar
New Member
Default Re: Engine Noise
ok as an update, so I am not too general about the problem, a timing code has been one of two codes other than fuel too lean, as the result of running a diag. test. and the noise is more of a knocking than anything else, and if I am in neutral and press the gas to hold around 1100rpm, the noise goes away.
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
My guess is you have or installed a BOV.
Old May 24, 2006 | 05:39 PM
Ertman's Avatar
Default replace the BOV with a 710N DV before you ruin the engine...
Blow off valves are not good for these cars!! Keep it Euro, keep it clean, leave the BOV for the ricers!!!
Old May 24, 2006 | 07:07 PM
dorsal fin's Avatar
New Member
there is nothing on the car other than what came from the factory, so its not a BOV, or any other type of valve, so I have to rule that out, but thanks anyways
Old May 24, 2006 | 08:16 PM
Keeper of the Cash
Tech Guru
Default You suck at posting.
Get a VAG-COM, pull the code(s), and get back to us.
But not before you learn how to post/reply properly first.
russ0054
Q5/SQ5 MKI (8R) Discussion
22
Sep 14, 2011 04:05 PM
JP19640_0
Jul 16, 2011 12:17 AM
Don@STaSIS
Dec 4, 2002 12:14 PM
Mewho
Sep 23, 2001 04:02 PM
swong_88
Jun 4, 2001 05:14 PM
