failed plug=replace turbo
Old Feb 12, 2002 | 04:57 PM
AmishA4T's Avatar
New Member
Default failed plug=replace turbo
My 99.5 1.8TQS with 66,000 (highway) had the #1 cylinder plug break off @ the tip and get sucked into the turbo. Could have been worse, there were slight scuffings on the #1 piston, but no head/valve damage. Turbo was trashed. Audi is only willing to belly up 25% of the bill. Because I hadn't change the plugs @ 60K, they weren't willing to pay 100%. Dealer is going easy on the labor costs (3 days). Anybody had a Bosch plug break apart like this?
Old Feb 12, 2002 | 05:02 PM
Audi4orce's Avatar
Default First......who changed the plugs at 30K??? Audi uses NGK's not bosch...
If the dealer did U'r 30K and used bosch. that's on THEM!!
second, what ever happens. I think this it the time to call AWE and get the K04 kit($1200)*
DG
Sourdough Josh's Avatar
3 days? Turbo takes 4-6 hours to replace. What else are they doing?
Old Feb 12, 2002 | 05:03 PM
Boosting1Bar's Avatar
Are you sure? I thought Audi used Bosch.
$1700 For a K04, installed.
Old Feb 12, 2002 | 05:04 PM
Mirror|rorriM's Avatar
AudiWorld Expert
"Best way to make a car last is to do all scheduled maintanence"
Old Feb 12, 2002 | 05:28 PM
CMH's Avatar
CMH
Senior Member
Default Actually Audi uses a few different plugs. Depends on the supply they get at the time.
I have seen NGK's and bosch used.
Old Feb 12, 2002 | 05:30 PM
dubjay's Avatar
New Member
Default broken plug
I've seen the ceramics break off plugs before, but that was because of extreme detonation. Usually a highly modified motor w/o enough fuel.
Old Feb 12, 2002 | 07:34 PM
badmyan's Avatar
Junior Member
Making money
Old Feb 12, 2002 | 08:20 PM
a4turbo18t's Avatar
Audi used NGK's on the 225HP TT's and the '00 to present 1.8T motors
4Driver4
Dec 29, 2003 08:24 AM
Tbandido
Mar 17, 2003 08:26 PM
83UR-Dont-run
Quattro: Turbo / Ur / Sport
Oct 9, 2001 08:27 AM
TTinHK
May 15, 2000 04:15 AM
Roy S.
Sep 11, 1999 05:20 AM
