Fault Codes...
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Shareware Version. To Decode all DTCs
35-00 - Please Register/Activate
01372 - Shareware Version. To Decode all DTCs
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Shareware Version. To Decode all DTCs
01365 - Shareware Version. To Decode all DTCs
29-00 - Please Register/Activate
00991 - Interior Lights
28-00 - Short to B+
00955 - Shareware Version. To Decode all DTCs
09-00 - Please Register/Activate
00956 - Shareware Version. To Decode all DTCs
i fix things there that cost more the $50...
I do anything under. :-D
P10456 - engine coolant sensor - please replace this item as it is no longer working correctly, k thanx bai.
An understanding of how Motronic 5.9/7.1 works will clue you into how to interpret codes.
typically the ECU will store codes for the following three criteria (low values, electrical shorts, and high values) The parameters for when you actually get a CEL are pretty broad. Moreover, just because you have a fault code for a specific thing (i,e, misfire cylinder 2) the cause for it can be quite broad.
will they then see that code... and fix it? (so it'll have more life left then what the current one does)?
is that worth the $50 cpo fix? will they do it?
That code is common and pops up from time to time so if you aren't getting any codes in a week or two, you probably don't need to worry about it.
If you do get CLP codes again, or are currently experiencing lock / alarm problems, fix it before you need to shell out 500 + labor (if needed) for a new pump.
I didn't research the other Shareware codes so I don't know what they are but I'm sure they are related to locking and alarm system.
