First time using VAG COM, need help analyzing result..
Is there a way to find the code meaning to point me where I need to diagnose the problem indicated from the VAG test?
Here's the result:
VAG-COM Version: Release 409.1-US
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Skipping Address 15-Airbags
Address 35: Centr. Locks
Controller: 8LO 862 257 B
Component: CV-Pump,Alarm, RC
Coding: 12172
Shop #: WSC 65535
6 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Shareware Version. To Decode all DTCs
35-00 - Please Register/Activate
01374 - Shareware Version. To Decode all DTCs
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Shareware Version. To Decode all DTCs
01368 - Shareware Version. To Decode all DTCs
Here's the result:
Coding: 12172
Shop #: WSC 65535
6 Faults Found:
35-00 - -
35-00 - -
Re: car is fine
I'm looking for codes to see if there's any reason why the ECU is not resetting at all.
I can't pass smogged due to ECU resetting issue. If this is the only code I'm getting, do I have a failing ECU?
Any had this problem before?
Thanks for you quick reply.
not sure what you mean by ecu resetting - or why is it even suppoe to reset in the first place but
here is a link to fault code and usually the culprit<ul><li><a href="http://wiki.ross-tech.com/index.php/Category:Fault_Codes">http://wiki.ross-tech.com/index.php/Category:Fault_Codes</a</li></ul>
Here this is most likely the page you are looking for.
<ul><li><a href="http://www.bentleypublishers.com/tech/audi/audi.dtc.table.htm?stickyEmail=&ticket=none">L ink for DTC codes</a></li></ul>
Re:reset
SMog technician told me that my ECU is not ready for SMOG test. The ECU has to be in some monitoring mode (4 modules - I think).
I was instructed to drive the car at least 100 miles and ECU should reset and it'll be ready for smog. 2000 miles after, the ECU is still not ready.
